MQTT based sprinkler control
it says in this post.
Thanks, looks like that weather service is specific to your area. Seems ones I use don’t have any rainfall data. I will have to see how the moisture sensors work. IDK how I’d do it because they are BLE. Might have issues with distance.
Try this. Then you can use weather.home https://www.home-assistant.io/integrations/met
I live in USA and use this.
Does this do rain accumulation based on local data? I’m just curious of how the data is interpreted.
Thanks!
I know you can make a sensor to reset every so often, I dont think it stores anything, just shows future.
For future reference, when the breaking change (deprecation of entity_id) is implemented in the Template integration, here is a version of your Template Binary Sensor that should be compatible.
First, you will need to define a group containing the input_booleans representing the weekdays:
group:
  zone_1_weekdays:
    name: Zone 1 Weekdays
    entities:
      - input_boolean.zone_1_mon
      - input_boolean.zone_1_tue
      - input_boolean.zone_1_wed
      - input_boolean.zone_1_thu
      - input_boolean.zone_1_fri
      - input_boolean.zone_1_sat
      - input_boolean.zone_1_sun
The following template expands that group and also employs sensor.date.
  binary_sensor:
      sensors:
        zone_1_day_active:
          friendly_name: Irrigation Day Active
          value_template: >-
            {% set today = states.sensor.date.last_updated.timestamp()
                 | timestamp_custom('%a') | lower %}
            {% set weekdays = expand('group.zone_1_weekdays')
                 | selectattr('state', 'eq', 'on')
                 | map(attribute='object_id')
                 | map('replace', 'zone_1_', '')
                 | list %}
            {{ today in weekdays }}
How it works:
  • It gets the current weekday’s abbreviation (mon, tue, wed, etc) from sensor.date and assigns it to a variable called today.
  • It expands the group, selects only the input_booleans that are on, gets their object_id (i.e. ā€œzone_1_thuā€), discards the ā€œzone_1_ā€ portion thereby only leaving the weekday abbreviation, and finally generates a list (like ['tue', 'thu']) and assigns it to the variable weekdays.
  • The final line simply checks if the value of today is in weekdays list and, if it is, returns true (otherwise, false).
I’m actually thinking of moving all my schedules over to the custom scheduler card which should simplify things a bit.
How would I convert this to inches? i know there is rain tomorrow.
   sensors:
    predict_rain_today:
      friendly_name: 'Predicted Rain Today'
      entity_id:
        - sensor.dark_sky_precip_probability_1d # always a single int
        - sensor.dark_sky_daily_max_precip_intensity_1d # two formats. Single int or "int_1 to int_2" e.g. "3 to 4"
      unit_of_measurement: in
      value_template: >
        {% set chance = states('sensor.dark_sky_precip_probability_1d')|int /100 %}
        {% if 'to' in states('sensor.dark_sky_daily_max_precip_intensity_1d') %}
          {% set amount =  states('sensor.dark_sky_daily_max_precip_intensity_1d').split(' to ')  %}
          {% set amount1 = amount[0] | float %}
          {% set amount2 = amount[1] | float %}
          {% set amount_avg = (amount1 + amount2) / 2 %}
        {% else %}
          {% set amount_avg = states('sensor.dark_sky_daily_max_precip_intensity_1d') | int %}
        {% endif %}
        {{ (chance * amount_avg)|round(1) }}
Please format your pasted config.
Basically, if it’s in mm, divide by 25.4 in the final amount template.
Awesome thread.
I would be nice if anyone could share rough estimates/suggestions for the values of min_moisture, max_moisture, and min_conductivity for a typical lawn.
Thanks in advance and kind regards!
Is this config still working. I keep getting an error in log - entity_id is deprecated (I think in template, it is).
I got everything to work except the automation.
Hey guys
Really awesome thread, I’ve spent quite a bit of time getting this setup and it seems with the end in sight I’ve stopped short of the finish line :flushed:
I suspect it has something to do with the entity_id but don’t know how to fix it.
I’m getting the error ā€œEntity not available: sensor.zone_1_time_remainingā€ and I’ve tried a few things but just cannot get that to come up for some reason. The automations are also not being activated and I’m not sure if its because of this sensor?
A nudge in the right direction would be greatly appreciated, my config files and screenshot below, thanks in advance.
binarysensors.yaml
  sensors:
    zone_1_day_active:
      value_template: >-
             | list %}
  sensors:
    zone_1_time_remaining:
      friendly_name: 'Time Remaining'
      entity_id:
        - input_number.zone_1_time_remaining
        - sensor.time
        - switch.irrigation_z1
      value_template: "{{ [ (states('input_number.zone_1_run_time') | int - (as_timestamp(now()) - as_timestamp(states.switch.irrigation_z1.last_changed)) / 60) | round(0) ,0 ] | max }}"
##      unit_of_measurement: "min"
groups.yaml
  zone_1_weekdays:
    entities:
automation.yaml
- id: '1608027082816'
  alias: Irrigation Zone 1 AM
  description: ''
    value_template: '"{{ states(''sensor.time'') == states(''input_datetime.zone_1_am_on_time'').rsplit('':'',1)[0]
  condition:
  - condition: state
    entity_id: binary_sensor.zone_1_day_active
    state: 'on'
  - service: switch.turn_on
    data: {}
    entity_id: switch.irrigation_z1
  - service: notify.mobile_app_paul_s9
      title: '*Information*'
      message: Zone 1 sprinklers turned on (AM Schedule).
  mode: single
- id: '1608028549476'
  alias: Irrigation Zone 1 PM
  description: ''
    value_template: '"{{ states(''sensor.time'') == states(''input_datetime.zone_1_pm_on_time'').rsplit('':'',1)[0]
  condition:
  - condition: state
    state: 'on'
    data: {}
      message: Zone 1 sprinklers turned on (PM Schedule).
  mode: single
Hi mate. You’ll have to scroll back a little to see how my interface and config are done. I set the zone_1_day_active sensor as a binary sensor with the config below and the other as a non-binary sensor (to carry the changing minute value as it counts down). Noting the differences my working config is below for you. This is in a single package yaml file too.
  binary_sensor:
      sensors:
        zone_1_day_active:
          value_template: >-
            {{ (is_state('input_boolean.zone_1_am_enable_schedule', 'on')
            or is_state('input_boolean.zone_1_pm_enable_schedule', 'on'))
            and (( is_state('input_boolean.zone_1_mon', 'on') and now().weekday() == 0 )
            or ( is_state('input_boolean.zone_1_tue', 'on') and now().weekday() == 1 )
            or ( is_state('input_boolean.zone_1_wed', 'on') and now().weekday() == 2 )
            or ( is_state('input_boolean.zone_1_thu', 'on') and now().weekday() == 3 )
            or ( is_state('input_boolean.zone_1_fri', 'on') and now().weekday() == 4 )
            or ( is_state('input_boolean.zone_1_sat', 'on') and now().weekday() == 5 )
            or ( is_state('input_boolean.zone_1_sun', 'on') and now().weekday() == 6 )) }}
      sensors:
          #Check if the zone switch is on or off before providing the number
          value_template: >
            {% if is_state("switch.garden_sprinklers_zone_1", "off") %} 0
            {% else %}
            {% set countdown_timer = [ (states('input_number.zone_1_run_time') | int - (as_timestamp(now()) - as_timestamp(states.switch.garden_sprinklers_zone_1.last_changed)) / 60) | round(0) ,0 ] | max %} {{ countdown_timer }}
            {% endif %}
@jward101 thanks for your post, I’ll see if I can get it working that way…
Hello guys,
Super thread exactly that I need :).
I working to an irrigator for my backyard. In present I use home assistant with node-red and an Arduino mega with Ethernet shield W5100, 4 relay’s and few sensors. My problem is then I want to change time or day I need to change in node-red in 4 places :frowning:.
So I try to add more controls in dashboard.
I adapted code above in this trade but I have some errors and I really need your help :slight_smile:
This is my config.yaml
default_config:
mqtt:
    broker: core-mosquitto
    username: home
    password: homep
#                Packages/Garden Reticulation                   #
#     This is a full reticulation control package using BOM     #
#   weather prediction to prevent watering if rain is expected, #
#   or occured recently with local moisture sensor data as well #
switch:
    - platform:mqtt
      name:"Garden Sprinklers Zone 1"
      state_topic:"ha/zona/z1"
      command_topic:"ha/zona/z1/set"
      qos:1
      payload_on:"ON"
      payload_off:"OFF"
      retain:false
    - platform:mqtt
      name:"Garden Sprinklers Zone 2"
      qos:1
      payload_on:"ON"
      payload_off:"OFF"
      retain:false
#    Zone 1 = Front Lawn          Zone 2 = Side Garden          #
#                  Is today a Sprinkler Day?                   #
binary_sensor:
      sensors:
        zone_1_day_active:
          entities:
            - sensor.date
            - input_boolestatisan.zone_1_am_enable_schedule
            - input_boolean.zone_1_pm_enable_schedule
          value_template: >-
      sensors:
        zone_2_day_active:
          entities:
            - sensor.date
            - input_boolean.zone_2_am_enable_schedule
            - input_boolean.zone_2_pm_enable_schedule
            - input_boolean.zone_2_mon
            - input_boolean.zone_2_tue
            - input_boolean.zone_2_wed
            - input_sboolean.zone_2_thu
            - input_boolean.zone_2_fri
            - input_boolean.zone_2_sat
            - input_boolean.zone_2_sun
          value_template: >-
            {{ (is_state('input_boolean.zone_2_am_enable_schedule', 'on')
            or is_state('input_boolean.zone_2_pm_enable_schedule', 'on'))
            and (( is_state('input_boolean.zone_2_mon', 'on') and now().weekday() == 0 )
            or ( is_state('input_boolean.zone_2_tue', 'on') and now().weekday() == 1 )
            or ( is_state('input_boolean.zone_2_wed', 'on') and now().weekday() == 2 )
            or ( is_state('input_boolean.zone_2_thu', 'on') and now().weekday() == 3 )
            or ( is_state('input_boolean.zone_2_fri', 'on') and now().weekday() == 4 )
            or ( is_state('input_boolean.zone_2_sat', 'on') and now().weekday() == 5 )
            or ( is_state('input_boolean.zone_2_sun', 'on') and now().weekday() == 6 )) }}
#         Countdown timer from when Sprinklers start            #
    # Used to pull a max_value from the statistics sensor
    # Refer: https://www.home-assistant.io/integrations/statistics/
    # The max_value is templated into a sensor.  See 48hour_rain_figure below
      sensors:
          entities:
            - input_number.zone_1_run_time
            - sensor.time
            - switch.garden_sprinklers_zone_1
          value_template: >
            {% else %}
            {% endif %}
        zone_2_time_remaining:
          entities:
            - input_number.zone_2_run_time
            - sensor.time
            - switch.garden_sprinklers_zone_2
          value_template: >
            {% if is_state("switch.garden_sprinklers_zone_2", "off") %} 0
            {% else %}
            {% set countdown_timer = [ (states('input_number.zone_2_run_time') | int - (as_timestamp(now()) - as_timestamp(states.switch.garden_sprinklers_zone_2.last_changed)) / 60) | round(0) ,0 ] | max %} {{ countdown_timer }}
            {% endif %}
#                    Set Start/Finish Times                     #
input_datetime:
    zone_1_am_on_time:
      name: AM On Time
      has_date: false
      has_time: true
    zone_1_pm_on_time:
      name: PM On Time
      has_date: false
      has_time: true
    zone_2_am_on_time:
      name: AM On Time
      has_date: false
      has_time: true
    zone_2_pm_on_time:
      name: PM On Time
      has_date: false
      has_time: true
#                  Set the days you Water here                  #
input_boolean:
# Zone 1 Days
    zone_1_mon:
      icon: mdi:calendar
    zone_1_tue:
      icon: mdi:calendar
    zone_1_wed:
      icon: mdi:calendar
    zone_1_thu:
      icon: mdi:calendar
    zone_1_fri:
      icon: mdi:calendar
    zone_1_sat:
      icon: mdi:calendar
    zone_1_sun:
      icon: mdi:calendar
# Zone 1 Automation Switches
    zone_1_am_enable_schedule:
      name: Enable AM Schedule
      icon: mdi:weather-sunny
    zone_1_pm_enable_schedule:
      name: Enable PM Schedule
      icon: mdi:weather-sunset
# Zone 2 Days
    zone_2_mon:
      icon: mdi:calendar
    zone_2_tue:
      icon: mdi:calendar
    zone_2_wed:
      icon: mdi:calendar
    zone_2_thu:
      icon: mdi:calendar
    zone_2_fri:
      icon: mdi:calendar
    zone_2_sat:
      icon: mdi:calendar
    zone_2_sun:
      icon: mdi:calendar
# Zone 2 Automation Switches
    zone_2_am_enable_schedule:
    zone_2_pm_enable_schedule:
#              Set the run-time for each Zone below             #
input_number:
    zone_1_run_time:
      min: 5
      max: 30
      step: 5
      unit_of_measurement: min
      icon: mdi:clock
    zone_2_run_time:
      min: 1
      max: 10
      step: 1
      icon: mdi:clock
sensor rain:
  - platform: mqtt
    state_topic: "ha/zona/rain"
# Text to speech
#custom-ui
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Log errors:
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:454
Integration: Hass.io (documentation, issues)
First occurred: 6:22:34 PM (4 occurrences)
Last logged: 6:31:04 PM
Invalid config for [sensor.template]: [entities] is an invalid option for [sensor.template]. Check: sensor.template->sensors->zone_1_time_remaining->entities. (See ?, line ?). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 29). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 29). Invalid config for [binary_sensor.template]: [entities] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_1_day_active->entities. (See ?, line ?). Invalid config for [binary_sensor.template]: [entities] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_2_day_active->entities. (See ?, line ?).
Invalid config for [sensor.template]: [entity] is an invalid option for [sensor.template]. Check: sensor.template->sensors->zone_1_time_remaining->entity. (See ?, line ?). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 29). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 29). Invalid config for [binary_sensor.template]: [entity] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_1_day_active->entity. (See ?, line ?). Invalid config for [binary_sensor.template]: [entity] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_2_day_active->entity. (See ?, line ?).
Invalid config for [sensor.template]: [entities] is an invalid option for [sensor.template]. Check: sensor.template->sensors->zone_1_time_remaining->entities. (See ?, line ?). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 24). Invalid config for [switch]: expected a dictionary. Got OrderedDict([('default_config', {}), ('mqtt', OrderedDict([('broker', 'core-mosquitto'), ('username', 'home'), ('password', 'homep'), ('will_message', {'topic': 'homeassistant/status', 'payload': 'offline', 'qos': 0, 'retain': False}), ('tls_version', 'auto'), ('port', 1883), ('birth_message', {'topic': 'homeassistant/status', 'payload': 'online', 'qos': 0, 'retain': False}), ('discovery', True), ('keepalive', 60), ('discovery_prefix', 'homeassistant'), ('protocol', '3.1.1')])), ('switch', ['.... (See /config/configuration.yaml, line 24). Invalid config for [binary_sensor.template]: [entities] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_1_day_active->entities. (See ?, line ?). Invalid config for [binary_sensor.template]: [entities] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->zone_2_day_active->entities. (See ?, line ?).
Thanks, for any advice.
Can anybody help in script? I’d like to make a script which:
  1. turns on the first switch of irrigation
  2. Waits until the remaining time goes to 0. "Or if it set 0 by default just contionue to the next step)
  3. Turns on the 2nd switch
    etc.
My problem, I don’t know how to set the ā€œwait until remaining time sensorā€ goes to 0 on the Script UI of HA.
How could you cumulate the running times of each zones into one remaining time value? Like in your screeshot’s Back Yard 2nd row.
for whole week i’ve been trying to setup sprinker system based on this topic. I’ve managed to do only half and after searching for online solution left no choice, but to ask help here. I’m using the latest version of homeassistant. This is error i get in lowlace. Please guide me, what i’m doing wrong? I’m not a developer and will not be able to write code.
This is my config for sensor:
    sensors:
          value_template: >
            {% if is_state("switch.laistymo_sistema", "off") %} 0
            {% else %}
            {% set countdown_timer = [ (states('input_number.zone_1_run_time') | int - (as_timestamp(now()) - as_timestamp(states.switch.laistymo_sistema_zone_1.last_changed)) / 60) | round(0) ,0 ] | max %} {{ countdown_timer }}
            {% endif %}
and for binary_sensor:
      sensors:
        zone_1_day_active:
          value_template: >-
did you create all the input in the Helper menu ?
I did not notice any mention of Helper menu. What is it?
