Will it be possible to change Profiles with it one day?
I created a MQTT adapter for the Open CUE service, which is a project of mine to control the profiles of iCUE just like some games do it. I use it with openHAB but it should be also possible to control it with HA.
I tried using Legion2’s Open Cue service which works very well! The service runs fine as a scheduled task, however the adapter open-cue-mqtt.bat only works if it’s run in a command prompt and not a scheduled task. Has anyone been able to get that part working?
I run both programs as scheduled tasks. The service is started on pc start and the mqtt adapter is started when the user logs in.
I tried setting it up as you described, the service works fine as it’ll pickup messages from the MQTT adapter (if run from cmd prompt)
I setup the scheduled task for the mqtt adapter to run as SYSTEM and my username, neither works. The action is “start a program”, the program/script is “C:\Program Files\open-cue-mqtt-windows-x64\open-cue-mqtt.bat” with no arguments nor “start in” entry.
@Hydrazine sorry for the late reply I missed your response.
Here is my exported scheduled task, it runs as my personal windows account. I removed some information and replaced them with ***
<?xml version="1.0" encoding="UTF-16"?>
<Task version="1.4" xmlns="http://schemas.microsoft.com/windows/2004/02/mit/task">
<RegistrationInfo>
<Date>2020-04-27T17:41:14.1752403</Date>
<Author>***</Author>
<URI>\Start Open CUE MQTT Adapter</URI>
</RegistrationInfo>
<Triggers>
<LogonTrigger>
<Enabled>true</Enabled>
<UserId>***</UserId>
<Delay>PT30S</Delay>
</LogonTrigger>
</Triggers>
<Principals>
<Principal id="Author">
<LogonType>S4U</LogonType>
<RunLevel>LeastPrivilege</RunLevel>
</Principal>
</Principals>
<Settings>
<MultipleInstancesPolicy>StopExisting</MultipleInstancesPolicy>
<DisallowStartIfOnBatteries>true</DisallowStartIfOnBatteries>
<StopIfGoingOnBatteries>true</StopIfGoingOnBatteries>
<AllowHardTerminate>true</AllowHardTerminate>
<StartWhenAvailable>false</StartWhenAvailable>
<RunOnlyIfNetworkAvailable>false</RunOnlyIfNetworkAvailable>
<IdleSettings>
<StopOnIdleEnd>true</StopOnIdleEnd>
<RestartOnIdle>false</RestartOnIdle>
</IdleSettings>
<AllowStartOnDemand>true</AllowStartOnDemand>
<Hidden>false</Hidden>
<RunOnlyIfIdle>false</RunOnlyIfIdle>
<DisallowStartOnRemoteAppSession>false</DisallowStartOnRemoteAppSession>
<UseUnifiedSchedulingEngine>true</UseUnifiedSchedulingEngine>
<WakeToRun>false</WakeToRun>
<ExecutionTimeLimit>PT72H</ExecutionTimeLimit>
<Priority>7</Priority>
</Settings>
<Actions Context="Author">
<Exec>
<Command>C:\Users\***\AppData\Roaming\open-cue-mqtt\open-cue-mqtt.bat</Command>
<WorkingDirectory>C:\Users\***\AppData\Roaming\open-cue-mqtt</WorkingDirectory>
</Exec>
</Actions>
</Task>
Does this work for iCUE 4? Not able to get this going…
Do I need the specific dotnet version? The older versions aren’t available on the website anymore (links in the readme are dead).
bump, does this work with icue 4?
@tobinbrooke you should add support for setting the G buttons up as buttons in Home Assistant (for keyboards). Would be awesome to trigger automations or other things using the macro buttons on my keyboard. I was actually going to make something that did this myself but then came across this. Good work!
Hi, good suggestion, unfortunately, I do not believe the iCue SDK exposes much more than LEDs. Would have to add macros that can be configured to set the led and carry out a pre-defined list of available actions that simulate some of what the G buttons can do
Hello how are you? I was very impressed with the service provided. I have a suggestion, is it possible to do the opposite way? For example, when I change the color, or receive a notification on the computer, can I change the color of the lamp or led strip? It may be possible using the home assistant’s MQTT server, such as Mosquitto broker
Nice, thanks !
