I’m afraid you’ll have to explain that again. I don’t understand the problem.
Ok maybe I didn’t explain it correctly but now what happens is if I only use home assistant to open/close the door it is fine and won’t misfire because of the flag. The problem I am having is that if I open it with home assistant but then close it with a garage door opener then the NodeMCU will fire once because the state is no longer the same and the flag gets reset when the Reed switch state changes. I don’t know why the message is still being fired even after the state of the reed switch is changed. I think it has to do with the retain flag because my program reconnects to mqtt broker all the time but not sure how to fix that
To clear out any topics that have been set with the retain flag, you need to send a null payload with the retain flag sent e.g.
$ mosquitto_pub -t "topic" -r -n
Even so, sorting out the re connections does seem like the next step. Can you tell from the serial output if the network is disconnecting, or just the MQTT connection?
I believe it is just the MQTT connection. There have been a few times the network has gone out but it reconnects and does not seem to be the issue here.
How often you see the status messages on your broker? Maybe you are flooding the mqtt broker with this unnecessary updates.
home/garage/door3 0
home/garage/status 0
etc…
home/garage/door3 0
etc…
The only time home/garage/status is posted to the broker now is after a state change in the relay. This is also the time when the flag is set to zero. I commented out all the unnecessary stuff that was posting to the serial port and it seems to be running better however I still have the issue of if i were to open or close with a manual remote that does not post to mqtt like a car remote then it will try to open/shut the garage door one more time.
Ok so I think I figured it out although it is not perfect and not exactly how I want it but I think I will be ok with this. Thanks everyone for all the help I really appreciate it. So how I have it set up is that every time the open or close button is pushed in MQTT a hold flag is triggered and to reset this flag the stop button has to be pushed first then the open/close button can be pushed. The stop button also updates the state of the reed switch. Also I added some code so if the open/close button is pushed but the stop button was not pushed then after the counter reaches 500 it will update the status of the reed switch. So below is my code:
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
// Use these lines to setup MQTT Server and WiFi
#define MQTT_SERVER "XXXXXXXXXXXX"
const char* ssid = "XXXXXX";
const char* password = "XXXXXX";
// Define GPIO on NodeMCU
const int doorPin = 13;
const int relayPin = 14;
char* DOOR_CLOSED = "0";
char* DOOR_OPEN = "1";
char* DOOR_WAIT = "5";
char* DOOR_CLEAR = "8";
// Define Variables
//int garageRelay = 0;
bool isOpen = false;
int hold = 1;
int counter = 0;
// Topics to Publish to
char* relayTopic = "home/garage/door";
// Topics to Subscribe to
char* doorTopic = "home/garage/status";
WiFiClient wifiClient;
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
void setup() {
pinMode(doorPin, INPUT);
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH);
// Start the serial line for debugging
Serial.begin(115200); // com to computer
delay(100);
// Start wifi subsystem
WiFi.begin(ssid, password);
// Attempt to connect to the WIFI network and then connect to the MQTT server
reconnect();
// Get Initial Door State
bool doorState = digitalRead(doorPin);
if (doorState == 0) { //If Door is Closed
// Publish Door Closed to doorTopic
client.publish(doorTopic, DOOR_CLOSED); //send close
else if (doorState == 1) { //If Door is Open
// Publish Door Open to doorTopic
client.publish(doorTopic, DOOR_OPEN); //send close
// Wait for a bit before starting main loop
delay(2000);
void loop() {
// Reconnect if connection is lost
if (!client.connected() && WiFi.status() == 3) {
reconnect();
// Maintain MQTT connection
client.loop();
if(counter == 500){
if (doorState == LOW) { //if door is open and the state closed, publish
client.publish(doorTopic, DOOR_CLOSED); //send closed
client.publish(relayTopic, "3");
Serial.println("Low");
else if (doorState == HIGH) { //if door is closed and the state is open, publish
client.publish(doorTopic, DOOR_OPEN); //send open
Serial.println("High");
counter=0;
//grab the current garage door state
if (!doorState && !isOpen) { //if door is open and the state closed, publish
isOpen = true;
// hold = 0; // Set hold to 0 to allow MQTT
// Serial.println("Hold = 0");
else if (doorState && isOpen) { //if door is closed and the state is open, publish
isOpen = false;
// hold=0; // Set hold to 0 to allow MQTT
// Delay to allow ESP8266 WIFI functions to run
delay(50);
counter = counter + 1;
Serial.println(counter);
// MQTT callback function -(Use only if topics are being subscribed to)
void callback(char* topic, byte* payload, unsigned int length) {
// Convert topic to string to make it easier to work with
String topicStr = topic;
char byteToSend = 0;
// Handle relayTopic
if (topicStr.equals(relayTopic)) {
// Grab the current garage door state
if (hold == 0) {
if (payload[0] == '1') {
// Open Door
digitalWrite(relayPin, LOW);
delay(1000);
hold = 1;
// End Open Door
Serial.println("");
Serial.println("Open Called");
Serial.println("Hold = 1");
else if (payload[0] == '0') {
// Close Door
delay(1000);
hold = 1;
// End Close Door
Serial.println("");
Serial.println("Close Called");
if (payload[0] == '5') {
// isOpen = true;
// isOpen = false;
void reconnect() {
//attempt to connect to the wifi if connection is lost
if (WiFi.status() != WL_CONNECTED) {
//debug printing
Serial.print("Connecting to ");
Serial.println(ssid);
//loop while we wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
//print out some more debug once connected
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
//make sure we are connected to WIFI before attemping to reconnect to MQTT
if (WiFi.status() == WL_CONNECTED) {
// Loop until we're reconnected to the MQTT server
while (!client.connected()) {
//Serial.println("");
//Serial.print("Attempting MQTT connection...");
// Generate client name based on MAC address and last 8 bits of microsecond counter
String clientName;
clientName += "esp8266-";
uint8_t mac[6];
WiFi.macAddress(mac);
clientName += macToStr(mac);
//if connected, subscribe to the topic(s) we want to be notified about
if (client.connect("(char*) clientName.c_str()", "XXXXXX", "XXXXXX")) {
//Serial.print("\tMTQQ Connected");
// client.subscribe(doorTopic);
client.subscribe(relayTopic);
//otherwise print failed for debugging
else {
Serial.println("\tFailed.");
abort();
// Generate unique name from MAC addr
String macToStr(const uint8_t* mac) {
String result;
for (int i = 0; i < 6; ++i) {
result += String(mac[i], 16);
if (i < 5) {
result += ':';
return result;
