MQTT Light/Templating Help
I’m running two instances of HASS. One runs my Zwave network and the other is my “main” instance. (I’ve looked at zwave2mqtt but it won’t work for what i need). I’m basing my work off this thread: Automating the sharing of sensors and switches between HA's using MQTT Discovery and Statestream
And here is a copy/paste from MQTT-Explorer that shows all the values in MQTT. Includes the payload (what I want it to be).
last_updated = 2019-07-16T11:29:24.263374+00:00
brightness = 255
node_id = 50
value_index = 0
value_instance = 1
value_id = "72057594881605633"
friendly_name = "Office"
supported_features = 33
last_changed = 2019-07-16T11:29:24.263374+00:00
state = on
set = {"state": "on", "brightness": "255", "transition": "2"}
Edit: Maybe the issue is this. I’m trying to set the light based on the MQTT topics, which don’t have JSON values, and the light doesn’t pass the MQTT value in JSON (ie it uses the state and brightness topics, not what is in the set topic. So maybe I need to be using the json schema for lights instead? I just couldn’t get that working.
