MQTT payload as input number
Which code are you talking about?
You included code from your automation in your first post that was:
service: input_number.set_value
  entity_id: input_number.niveau_eau_cuves_verger
data: "{{ states('sensor.node_1_payload') | int(0) }}"
You said this was giving an error. Change it to this:
  value: "{{ states('sensor.node_1_payload') | int(0) }}"
and see if that fixes it.
Hallelujah! It is working as expected. I didn’t see the value line. I had to read several times. Thanks you all for your help. I learned a lot.
This topic can be close.
