Mqtt publish_json how to convert sensor.state in string
Help for beginner
i need to send the state of a sensor in string
#define sensor
    # used as mqtt publisher
  - platform: uptime
    update_interval: ${publish_interval}
    on_value:
      - mqtt.publish_json:
          topic: domoticz/in
          payload: |-
            root["command"] = "addlogmessage";
            root["message"] = "Connexion MQTT depuis ESPHOME";
      - logger.log: MQTT log domoticz published
  #---dallas sensors
  - platform: dallas
    address: 0xAF012033B79C9F28
    on_value:
    #---Publisg sensors  content to domoticz via mqtt
          topic: domoticz/in
          payload: |-
            root["idx"] = 45;
            root["nvalue"] = 0;
            root["svalue"] = id(temp_piece).state;
      - logger.log: MQTT Temp piece published
Give:
{“command”:“udevice”,“idx”:45,“nvalue”:0,“svalue”:26.75}
Domoticz need sensor value between quotes:
{“command”:“udevice”,“idx”:45,“nvalue”:0,“svalue”:“26.75”}
Thanks for Help
Philippe
Welcome to the forum. Please edit your post and format your pasted code correctly as per point 11 here.
first : in fact mqtt.publish_json make the conversion from float to string
but quotes around the values are missing
so, I find a solution, i am not sure that it is the smarter one !!
i change the way of ,publishing,
instead of using mqtt.publish_json , i use mqtt.publish,
and i construct the payload by myself
  # Dallas sensors
  - platform: dallas
    on_value:
      - mqtt.publish:
          topic: domoticz/in
          payload: !lambda |-
            std::string messageO;
            char str[16];
            snprintf(str, sizeof(str), "%.2f", x);
            messageO += "{\"command\":\"udevice\",\"idx\":45,\"nvalue\":0,\"svalue\":\"";
            messageO += str;
            messageO += "\"}";
            return messageO;
and this give
{“command”:“udevice”,“idx”:45,“nvalue”:0,“svalue”:“26.75” }
