MQTT Sensor default value on startup ot after a periof of time
So I created a minimal application to to make it easy hopefully to identify what I’m doing wrong.
Any suggestions where my issue is?
import time
import ubinascii
from umqtt.simple import MQTTClient
import machine
import random, network
# Default  MQTT_BROKER to connect to
MQTT_BROKER = "192.168.1.68"   #home assistant
CLIENT_ID = ubinascii.hexlify(machine.unique_id())
SUBSCRIBE_TOPIC = b"garage_door/set"
PUBLISH_TOPIC = b"garage_door/state"
SSID = "myssid"
SSID_PASSWORD = "mypassword"
# Setup built in PICO LED as Output
led = machine.Pin("LED",machine.Pin.OUT)
# Publish MQTT messages after every set timeout
last_publish = time.time()
publish_interval = 5
# Received messages from subscriptions will be delivered to this callback
def sub_cb(topic, msg):
    print((topic, msg))
    if msg.decode() == "OPEN":
        led.value(1)
    else:
        led.value(0)
def reset():
    print("Resetting...")
    time.sleep(5)
    machine.reset()
def do_connect():
    sta_if = network.WLAN(network.STA_IF)
    if not sta_if.isconnected():
        print('12.connecting to network...')
        sta_if.active(True)
        sta_if.connect(SSID, SSID_PASSWORD)
        while not sta_if.isconnected():
            print("13.Attempting to connect....")
            utime.sleep(1)
    print('14.Connected! Network config:', sta_if.ifconfig())
#end do_connect()
def main():
    sta_if.active(True)
    for _ in range(10):
        time.sleep(1)
        print('15.Wifi failed to connect, retrying')
        if sta_if.isconnected():
            print('16.Wifi connected.')
            break
        time.sleep(11)
    else:
        print('17.Wifi Fail')
        led_state(WIFI_ERROR)
        time.sleep(100)
        reset()
    print(f"Begin connection with MQTT Broker :: {MQTT_BROKER}")
    mqttClient = MQTTClient(CLIENT_ID, MQTT_BROKER, keepalive=60)
    mqttClient.set_callback(sub_cb)
    mqttClient.connect()
    mqttClient.subscribe(SUBSCRIBE_TOPIC)
    print(f"Connected to MQTT  Broker :: {MQTT_BROKER}, and waiting for callback function to be called!")
    while True:
            # Non-blocking wait for message
            mqttClient.check_msg()
            global last_publish
            if (time.time() - last_publish) >= publish_interval:
                mqttClient.publish(PUBLISH_TOPIC, "closed")
            time.sleep(1)
if __name__ == "__main__":
    while True:
        try:
            main()
        except OSError as e:
            print("Error: " + str(e))
            reset()
OK finally, i don’t know what the purpose of value_template: “{{ value.x }}” is, but when I remove it the status finally gets through.
It was in the examples, so I left it in! Struggling to understand its purpose!
Now I can check the availability stuff, and try to get the rest working!
Thanks for all your help Tom.
I was hoping to be able to include an icon template as supported in the Cover state, but it doesn’t seem to be included in the MQTT cover state.
Have I missed something?
      icon_template: >-
        {% if is_state('cover.cover_garage_door', 'open') %}
          mdi:garage-open-variant
        {% else %}
          mdi:garage-variant
        {% endif %}
I missed that down the bottom of your config. Sorry. Yeah that is not correct.
A value_template is used to extract information from the received message. As your messages are already the correct match for the payloads you don’t need it. You could have used: value_template: "{{ value }}" but it is redundant.
As an example if your message was encoded as json with the format { "door": "open" } you would use value_template: "{{ value_json.door }]" to match the payload “open”.
Older integrations do not support an icon template. The only way to change the icon is by changing the device class.
