OK lets try this -
as far as I can tell “unknown” happens when something occurs that has not been accounted for, and that is why the state becomes unknown, so let’s do a hacky workaround.
{% set o = states('sensor.doorlock_front_action_z2mtag666') %}
{% if value_json is defined and value_json['action'] is defined and value_json['action'] not in ['','unknown','unavailable','null'] %}
{{ value_json['action'] }}
{% else %}
{{ o }}
{% endif %}
I mean I guess it’s worth testing.
Note we are now checking is value_json is defined too, because for template sensors at least, when an error happens trying to render the template, then the state becomes unknown, which makes me wonder if something is being sent that cannot be decoded from JSON and that’s why it’s changing to unknown.
EDIT:
Playing with the template editor again… might have hit on the problem.
{{ json_value['action'] if (value_json['action'] is defined and value_json['action'] is not none and value_json['action'] != "") else states('sensor.doorlock_front_action_z2mtag666') }}
If the JSON is pasted into the template as a dictionary:
{% set j = {"action": null } %}
{{ j.action is defined }} #false
{{ j.action is not none }} #true
{% set j = '{"action": null }'|from_json %}
{{ j.action is defined }} #true
{{ j.action is not none }} #false
So when it is being converted from JSON to a dictionary, that action: null changes from not being defined, to becoming none.
- name: "DOORLOCK front action z2mtag1001"
unique_id: doorlock_front_action_z2mtag1001
state_topic: "zigbee2mqtt/DOORLOCK FRONT"
value_template: >-
{% set o = states('sensor.doorlock_front_action_z2mtag1001') %}
{% else %}
{{ o }}
{% endif %}
Just to improve my skills, why doesn’t my template from post 9 work?
{% if value_json.action is defined and value_json.action != "" and value_json.action != "None" and value_json.action != "null" %}
In this case, value_json.action would be “null” / undefined so shouldn’t pass the filter?
Or is the null state processed as “something that has not been accounted for” and bypasses the template to become unknown/None.
Therefore needs to be processed as json_value[‘action’] /index, where it is defined (“none”) and can be stripped by filtering “none” state?
Thanks for the clarifications, so both solutions below tested/working:
- name: "DOORLOCK front action z2mtag555"
unique_id: doorlock_front_action_z2mtag555
value_template: >-
{{ value_json['action'] if (value_json['action'] is defined and value_json['action'] is not none and value_json['action'] != "") else states('sensor.doorlock_front_action_z2mtag555') }}
- name: "DOORLOCK front action z2mtag333"
unique_id: doorlock_front_action_z2mtag333
value_template: >-
{% if value_json.action is defined and value_json.action is not none and value_json.action != "" %}
{{ value_json.action }}
{% else %}
{{ this.state }}
{% endif %}
One takeaway is that “none” state is not a string…
Thanks again for sharing your expertise, much appreciated
