I’m not understanding this section of the help page.
The example shows, the value_json.on
(references the “on” in the msg?) grabs the value “true”? So I thought I would duplicate this in mine, but I get the error below.
My MQTT sensor:
- platform: mqtt
unique_id: '123456HomeAssistantShutDown'
state_topic: "homeassistant/CMD/shutdown"
value_template: "{{ value_json.cmd }}"
My MQTT payload:
{"type":"HA","cmd":"SHUTDOWN"}
When I send that msg I get this error in the logs:
Logger: homeassistant.helpers.template
Source: helpers/template.py:1791
First occurred: 12:22:40 PM (1 occurrences)
Last logged: 12:22:40 PM
Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.cmd }}’
koying
(Chris B)
January 2, 2022, 5:55pm
2
Did you use, e.g., MQTT Explorer to ensure what you think you sent is actually in the specified topic?
koying
(Chris B)
January 2, 2022, 6:12pm
4
Well, what you show lacks the double quotes needed to make it proper JSON.
As it’s not valid json, value_json
is undefined.
Random example:
Isn’t that something… here is the entire command,. isn’t this correct? Do I need 2 sets of double quotes?
-h 192.168.1.26 -t homeassistant/CMD/shutdown -m {“type”:“HA”,“cmd”:“SHUTDOWN”}
I checked the json format and it shows valid.
I’m wondering now if this is an artifact of using mosquitto_pub command line interface. Stripping the quotes.? Hmmmm
Holy crap… That was it…
I needed to escape the quotes… Aye Caramba…
{\"type\":\"HA\",\"cmd\":\"SHUTDOWN\"}
Thank you for the clarity from your question / response. That’s what let to the solution.
