Agree with above but from just looking at what you have posted it looks like you need to put a new “platform” and a - in front of each “platform”. That’s what turns it into list. Otherwise it just sees two hosts in the same entity and can’t figure out what you mean.
Yes, it seems very likely he used the ###### as a separator instead of the yaml list item. But why loose an opportunity to teach a little about the forum usage?
Broadlink as a switch platform. This is the way I do for multiple broadlinks
configuration.yaml
switch: !include_dir_list config/switches/ -
create config folder and switches as sub-folder inside config folder
make individual broadlink.yaml file example broalink1.yaml and broadlink2.yaml inside switch folder
broadlink1.yaml
platform: broadlink
host: !secret ip_pro1
mac: !secret mac_pro1
timeout: 30
friendly_name: “Pro1”
type: rm
switches:
#Talaykaew 5
kitchen_light_2:
friendly_name: “kitchen light 2”
command_on: ‘sgCMAAojCyMLIwsjCiMjDAsjIwwLIyMMIwwjDCMMCyMLIwsjCwABXwwiCyMjDAsjIwwKJCMMCyILJAsiCyMLIwsjIwwLIyMMCiQiDCMNIwwiDQsiDCIMIwoAAWALIwsjIwwLIyMMCyMiDQsjCiMLIwsjCyMLIyMMCyMjDAsjIg0jDCMMIwwLIwsjCyMLAAXcAAAAAAAAAAAAAAAA6QpCAN8JFgkWCRYJFgkJFhYJFgkJFgkWFgkWCQkWFgkWCRYJCRYWCRYJCRYWCRYJFgkJFgkWCRYJFgkWCRYJFhYJCRYJFukKQgDfCRYJFgkWCRYJCRYWCRYJCRYJFhYJFgkJFhYJFgkWCQkWFgkWCQkWFgkWCRYJCRYJFgkWCRYJFgkWCRYWCQkWCRY=’
command_off: ‘sn40AAwjJA0MIyUMDSMkDCUMJAwNIyUMDCMMIwwAAWMMIwwjJAwMIyQMDCMkDAwjDCMMIwwjDCMAAAAA’
kitchen_aircon:
friendly_name: “kitchen aircon”
command_on: ‘JgBAAGoAAUESMxESEBIQEhA0EBIREREREREREREREREREhERERESEBIyEhARMxIQEhASMhIQEhASMhIyETMSEBEADQUAAAAAAAAAAA==’
command_off: ‘JgBAAGYAAUYPNQ8TDxMPEw81DxMPEw8TDzYONg8TDxMPEw8TDxMPEw8TDxMPFA4TDxMQNA8UDjYREQ8TDxMPNQ8ADQUAAAAAAAAAAA==’ -
broadlink2.yaml
platform: broadlink
host: !secret ip_pro2
mac: !secret mac_pro2
timeout: 30
friendly_name: “Pro2”
type: rm
switches:
#kitchen
dining_light:
friendly_name: “dining light”
command_on: ‘shY0AA0jJAskDA0jDSIkDA0jDSMMIyQLDQABYw0jDSIkDA0jDSIkDCQMDCMNIg0jDSINIyQMJAsAAAAA’
command_off: ‘sgY0AA0jJQwNIg0jJAwkDA0jDSINIg4iDSIkDCUMDSMkCyQMDSINIyQMDSMNIiUMDSMNAAFkDSMAAAAA’
kitchen_light:
friendly_name: “kitchen light”
command_on: ‘sgY0AA0jJQwNIg0jJAwkDA0jDSINIg4iDSIkDCUMDSMkCyQMDSINIyQMDSMNIiUMDSMNAAFkDSMAAAAA’
yup. I did agree with you first!
Today i learned the existance of command !include_dir_list
. Thanks
Here is also what you can do if you don’t want to split the config into multiple files as Sunonline suggested:
- platform: broadlink
host: 192.168.1.121
mac: '34:EA:34:D0:AB:19'
timeout: 15
switches:
tv_phillips:
friendly_name: "Phillips Tv Power"
command_on: 'JgAcAB0dHB44HhweGx4cHR06HB0cHhwdHB8bHhwADQUAAAAAAAAAAAAAAAA='
command_off: 'JgAaABweOR4bHhwdHB4dHRw6HhsdHR0dOTocAA0FAAAAAAAAAAAAAAAAAAA='
host: 192.168.1.125
mac: '32:EF:56:D9:AH:23'
timeout: 15
switches:
master_bedroom_light:
friendly_name: "Master Bedroom Light"
command_on: 'sgB4Ag4NDQ0NDQ4MDgwODQ0NDQ0ODA4NDQ0NqhsNDRobDA4aDRobDA4aGwwbDA4aGwwOGRsNDRobDA4aDRobDA4aDRobDRoNDhkOGQ4aDhkOGhoNDhkOGhoNGwwbDRoNDhkbDRoNGw0NGhoNGwwOGg0aDhoaDQ0aDhkOGg0aDhkOGg0aDhkbDRsMGw0NGhsMGw0aDRsMGw0aDRsMGw0NAANJDgwODA4NDQ0NDQ4MDg0NDQ0NDgwODA6qGwwOGhsMDhkOGhsMDhkbDRsMDhkbDQ0aGw0NGhsMDhoNGhsMDhoNGhsMGw0NGg4ZDhoNGg4ZGw0NGg4ZGw0aDRsMGw0NGhsMGw0aDQ4ZGw0bDA4ZDhoNGhsMDhoNGg4aDRoNGg4aDRoOGRsNGg0bDA4aGg0bDBsNGg0bDBsNGg0bDA4AA6YNDQ4MDgwODQ0NDQ0ODA4MDg0NDQ4MDqobDA4ZGw0NGg4ZGw0NGhsNGg0OGRsNDRobDA4aGg0OGQ4aGg0OGQ4aGg0bDA4aDRoOGQ4aDRobDA4aDRobDRoNGwwbDQ0aGwwbDBsNDRobDBsNDhkOGg0aDRoOGg0aGwwOGg0aGwwbDQ0aGwwbDRoNGwwbDRoNDhoaDRoNDhkOGhoNDgADSQ0NDQ0NDQ0ODQ0NDQ0NDQ0ODQ0NDQ0OqhoNDRsaDQ0aDRsaDQ0aGg0bDQ0aGg4NGhoNDRsaDQ0aDhoaDQ0aDRsaDRoNDRsNGg0aDhoNGhsMDRsNGhoNGw0aDRoNDhoaDRsNGg0NGhoNGw0NGg0aDhoNGg0bDRoaDQ0bDRoaDRoODRoaDRsNGg0aDRsNGg0NGhsNGg0NGg4aGg0NAAXc'
command_off: 'sgB4Ag4NDQ0NDQ4MDgwODQ0NDQ0ODA4NDQ0NqhsNDRobDA4aDRobDA4aGwwbDA4aGwwOGRsNDRobDA4aDRobDA4aDRobDRoNDhkOGQ4aDhkOGhoNDhkOGhoNGwwbDRoNDhkbDRoNGw0NGhoNGwwOGg0aDhoaDQ0aDhkOGg0aDhkOGg0aDhkbDRsMGw0NGhsMGw0aDRsMGw0aDRsMGw0NAANJDgwODA4NDQ0NDQ4MDg0NDQ0NDgwODA6qGwwOGhsMDhkOGhsMDhkbDRsMDhkbDQ0aGw0NGhsMDhoNGhsMDhoNGhsMGw0NGg4ZDhoNGg4ZGw0NGg4ZGw0aDRsMGw0NGhsMGw0aDQ4ZGw0bDA4ZDhoNGhsMDhoNGg4aDRoNGg4aDRoOGRsNGg0bDA4aGg0bDBsNGg0bDBsNGg0bDA4AA6YNDQ4MDgwODQ0NDQ0ODA4MDg0NDQ4MDqobDA4ZGw0NGg4ZGw0NGhsNGg0OGRsNDRobDA4aGg0OGQ4aGg0OGQ4aGg0bDA4aDRoOGQ4aDRobDA4aDRobDRoNGwwbDQ0aGwwbDBsNDRobDBsNDhkOGg0aDRoOGg0aGwwOGg0aGwwbDQ0aGwwbDRoNGwwbDRoNDhoaDRoNDhkOGhoNDgADSQ0NDQ0NDQ0ODQ0NDQ0NDQ0ODQ0NDQ0OqhoNDRsaDQ0aDRsaDQ0aGg0bDQ0aGg4NGhoNDRsaDQ0aDhoaDQ0aDRsaDRoNDRsNGg0aDhoNGhsMDRsNGhoNGw0aDRoNDhoaDRsNGg0NGhoNGw0NGg0aDhoNGg0bDRoaDQ0bDRoaDRoODRoaDRsNGg0aDRsNGg0NGhsNGg0NGg4aGg0NAAXc'
master_bedroom_fan_1:
friendly_name: "Master Bedroom Fan Low"
command_on: 'sgA8AQ4NDQ0NDQ4MDgwODQ0NDgwODA4NDQ0NqhsNDRobDA4aDhkbDQ0aGwwbDQ0aGg0OGhoNDhkbDQ0aDhkbDQ0aDhkbDRoNDhkOGg0aDhkOGhoNDhkOGhsMGwwbDRsMDhkbDRsMGw0NGhsMGw0NGg4ZDhoNGg4ZDhoNGg4ZDhoNGhsMDhoaDRsMGw0aDRsMGw0aDRsMGw0bDA4ZGw0NAANJDgwODQ0NDQ0ODA4MDgwODQ4MDgwODQ2qGwwOGhoNDhkOGhsMDhoaDRsMDhkbDQ4ZGwwOGhsMDhoNGhsMDhkOGhsMGw0NGg4ZDhoNGg4ZGw0NGg4ZGw0bDBsNGg0OGRsMGw0bDA4ZGw0bDA4ZDhoOGQ4ZDhoOGQ4aDRoOGQ4ZGw0OGRsNGg0bDBsNGg0bDBsNGwwbDBsNDRobDA4ABdwAAAAAAAAAAAAAAAA='
command_off: 'sgA8AQ4NDQ0NDQ4MDgwODQ0NDgwODA4NDQ0NqhsNDRobDA4aDhkbDQ0aGwwbDQ0aGg0OGhoNDhkbDQ0aDhkbDQ0aDhkbDRoNDhkOGg0aDhkOGhoNDhkOGhsMGwwbDRsMDhkbDRsMGw0NGhsMGw0NGg4ZDhoNGg4ZDhoNGg4ZDhoNGhsMDhoaDRsMGw0aDRsMGw0aDRsMGw0bDA4ZGw0NAANJDgwODQ0NDQ0ODA4MDgwODQ4MDgwODQ2qGwwOGhoNDhkOGhsMDhoaDRsMDhkbDQ4ZGwwOGhsMDhoNGhsMDhkOGhsMGw0NGg4ZDhoNGg4ZGw0NGg4ZGw0bDBsNGg0OGRsMGw0bDA4ZGw0bDA4ZDhoOGQ4ZDhoOGQ4aDRoOGQ4ZGw0OGRsNGg0bDBsNGg0bDBsNGwwbDBsNDRobDA4ABdwAAAAAAAAAAAAAAAA='
thank you Sunonline and finity, both options works. many thanks all.
If you use rm pro. When you finish add the switch platform. You can have that in sensor platform to get the temperature from rm pro as well. This will give you sensor.office_temperature
platform: broadlink
update_interval: 60
icon: mdi:temperature-celsius
monitored_conditions:
- temperature
Hi Sunonlin, thanks very much, I have the two broadlinks on one yaml file called tv.yaml, do I add the ip address for the broadlink again for the sensor?
O got it, I have to, thanks.
yes same broalink ip that you use but in different platform.
First platform is switch platform to get the switch.
Second platform is sensor platform to get the temperature.
After get temperature working. You might find this post also very interesting.
very nice. since you have so many tab. you can change tab name to icon. also the thunder icon by use group platform and homeassistant customize platform.
I see, I will look into it, more youtube searching, my wife is not going to be happy. haha
icon for ha can be found here https://materialdesignicons.com/
###Groups Tab view###
#Office
office_view:
view: yes
icon: mdi:atom
entities:
- group.office
- group.mp_1
- group.sensor_node_1_card
Customzie:
switch.kitchen_aircon: <== entity_id
friendly_name: Kitchen Aircon <== name to display frontend
icon: mdi:air-conditioner <== icon
great, many thanks.
How about creating my own icon? can I do that?
yes you can. from the post below
entity_picture: /local/toaster.jpg <=== /local/ means www folder inside ha config folder. the picture name toaster.jpg is inside www folder
Thanks again!
