@goeste Could you share your setup please?
Best regards
@KaherdinTristan @animeshp1: sry for coming back only now… also i got rid of the AM… and switched to a bme280
this is my complete config: unfortunately there is no diagram, but according to the pins you should be able to figure it all out. I connected nearly all grounds to one single GND though
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
### WIFI
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-xxxxxx"
password: "xxxxxx"
# Los geht's
captive_portal:
# I2C
i2c:
- id: bus_a
sda: 16
scl: 17
scan: true
# BinarySensors
binary_sensor:
- platform: gpio
device_class: moisture
pin:
number: GPIO14
inverted: True
mode:
input: True
pullup: True
#Regenmenge
- platform: gpio
device_class: window
pin:
number: GPIO26
inverted: True
mode:
input: True
pullup: True
# Sensors
#Helligkeit
# - platform: bh1750
# i2c_id: bus_b
# name: "Lux Garage"
# address: 0x23
# #address: 0xc5
# update_interval: 30s
# filters:
# - sliding_window_moving_average:
# window_size: 10
# send_every: 10
# send_first_at: 1
# - or:
# - throttle: 60s
# - delta: 10
#Temperatur
- platform: bme280
i2c_id: bus_a
temperature:
name: "Garage Temperature"
oversampling: 16x
pressure:
name: "Garage Pressure"
humidity:
name: "Garage Humidity"
address: 0x76
update_interval: 5s
#Windsensor
- platform: pulse_meter
pin:
number: GPIO20
mode: INPUT_PULLUP
name: 'Garage Windgeschwindigkeit'
icon: 'mdi:weather-windy'
unit_of_measurement: 'm/s'
internal_filter: 13us
timeout: 5s
filters:
- multiply: 0.005560619
window_size: 5
send_every: 5
# Switches
switch:
- platform: restart
I think this comment just saved my day. Thanks alot @tom_l I was really starting to get crazy…
I’m facing quite same problem handling multiple I2C elements linked to my ESP32 using espHome.
In fact I would like both BH1750 and esp32cam to work together on same board.
For now I suceeded making only one working at a time.
I found the Pinout of the board Here https://github.com/Freenove/Freenove_Basic_Starter_Kit_for_ESP32/blob/5e168c36288cd304ef906464573b25e59ed3ef6a/Datasheet/ESP32-Pinout.pdf
Here is my yaml file
esphome:
friendly_name: illuminance-mezzanine
esp32:
board: esp32dev
framework:
type: arduino
captive_portal:
i2c:
- sda: 26
scl: 27
scan: True
- platform: bh1750
name: "BH1750 illuminance"
update_interval: 1s
i2c_id: bus_a
#address: 0x5c
switch:
- platform: restart
As for now Camera seams to be found using the scan parameter but not accessible.
When I tried to add the esp32cam component it obviously failed due to same pin usage.
Is someone can help me find out a way to share the pins or maybe to find some other I2C pins that are not used by the camera ?
