Multiple errors installing HA on Windows with VirtualBox
I’m jumping into Home Assistant for the first time and running into some issues. For context, I’m running it in VirtualBox on Windows 11 with a wired ethernet connection. I installed the latest version of VirtualBox, Python, and Home Assistant. I followed the installation instructions on the HA website and have retried it three times now.
At one point I got an error that required me to go into my BIOS and enable a virtualization setting, but after that I got the VM running in VirtualBox. And the HA CLI looks like it’s working fine.
But when I go to homeassistant.local:8123 I get the “Error installing Home Assistant” message. I’ve tried googling solutions to the errors in red, but haven’t been able to find any solutions that work for me.
The errors seem to be about a few things:
  • A few errors about not being able to access things on github
  • Watchdog restart failed
  • Bunch of errors in yellow about not being able to read supervisor store data
  • A few red errors about not being able to install home assistant
I feel like there’s something basic I’m missing and would love any help on this. The full logs are below. And thanks in advanced!
Logs
(I hit the character limit for posts so I trimmed the first bit of the logs that seemed fine.)
23-11-17 02:08:48 INFO (MainThread) [__main__] Initializing Supervisor setup
23-11-17 02:08:48 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-11-17 02:08:48 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-11-17 02:08:48 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.10.0
23-11-17 02:08:48 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-11-17 02:08:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-11-17 02:08:49 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-17 02:08:49 INFO (MainThread) [__main__] Setting up Supervisor
23-11-17 02:08:49 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-11-17 02:08:49 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-11-17 02:08:49 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-11-17 02:08:49 INFO (MainThread) [supervisor.host.services] Updating service information
23-11-17 02:08:49 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-11-17 02:08:49 INFO (MainThread) [supervisor.host.network] Updating local network information
23-11-17 02:08:49 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-11-16 21:08:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-11-16 21:08:49 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-11-16 21:08:49 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-11-16 21:08:49 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-11-16 21:08:50 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-11-16 21:08:50 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-11-16 21:08:50 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-11-16 21:08:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-11-16 21:08:50 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-11-16 21:08:51 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-11-16 21:08:51 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-11-16 21:08:51 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
23-11-16 21:08:51 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
23-11-16 21:08:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-11-16 21:08:51 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-11-16 21:08:51 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-11-16 21:08:51 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-11-16 21:08:51 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-11-16 21:08:51 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
23-11-16 21:08:51 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-11-16 21:08:51 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-11-16 21:08:51 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-11-16 21:08:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
  stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Could not resolve host: github.com
23-11-16 21:08:56 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-11-16 21:08:56 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][3]. Got 'homeassistant_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:08:56 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][2]. Got 'homeassistant_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'homeassistant_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
23-11-16 21:08:56 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:08:56 INFO (MainThread) [supervisor.store] Loading add-ons from store: 57 all - 57 new - 0 remove
23-11-16 21:08:56 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-11-16 21:08:56 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-11-16 21:08:56 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-11-16 21:08:56 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-11-16 21:08:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-16 21:08:56 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-11-16 21:08:56 INFO (MainThread) [__main__] Running Supervisor
23-11-16 21:08:56 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-11-16 21:08:56 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-11-16 21:08:56 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-11-16 21:08:56 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.11.3
23-11-16 21:08:56 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.11.3.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[02:17:26] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[02:17:26] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
23-11-17 02:17:27 INFO (MainThread) [__main__] Initializing Supervisor setup
23-11-17 02:17:27 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-11-17 02:17:27 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.10.0
23-11-17 02:17:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-11-17 02:17:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-17 02:17:27 INFO (MainThread) [__main__] Setting up Supervisor
23-11-17 02:17:27 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-11-17 02:17:27 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-11-17 02:17:27 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-11-17 02:17:27 INFO (MainThread) [supervisor.host.services] Updating service information
23-11-17 02:17:27 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-11-17 02:17:27 INFO (MainThread) [supervisor.host.network] Updating local network information
23-11-17 02:17:27 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-11-16 21:17:27 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-11-16 21:17:27 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-16 21:17:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-11-16 21:17:28 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-11-16 21:17:28 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-11-16 21:17:28 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-11-16 21:17:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-11-16 21:17:28 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-11-16 21:17:28 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-11-16 21:17:28 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-11-16 21:17:28 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-11-16 21:17:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-11-16 21:17:28 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-11-16 21:17:28 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
23-11-16 21:17:29 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-11-16 21:17:29 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-11-16 21:17:29 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-11-16 21:17:29 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-11-16 21:17:29 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
23-11-16 21:17:29 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-11-16 21:17:29 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-11-16 21:17:29 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-11-16 21:17:29 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-11-16 21:17:29 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-11-16 21:17:29 ERROR (MainThread) [supervisor.homeassistant.core] Watchdog restart of Home Assistant failed!
23-11-16 21:17:29 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-11-16 21:17:29 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
23-11-16 21:17:29 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:29 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:29 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
23-11-16 21:17:30 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:30 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-11-16 21:17:30 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
23-11-16 21:17:30 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
23-11-16 21:17:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
23-11-16 21:17:33 INFO (MainThread) [supervisor.store] Loading add-ons from store: 60 all - 60 new - 0 remove
23-11-16 21:17:33 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-11-16 21:17:33 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-11-16 21:17:33 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-11-16 21:17:33 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-11-16 21:17:33 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-11-16 21:17:33 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-11-16 21:17:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-11-16 21:17:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-16 21:17:33 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-11-16 21:17:33 INFO (MainThread) [__main__] Running Supervisor
23-11-16 21:17:33 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-11-16 21:17:33 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-11-16 21:17:33 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-11-16 21:17:33 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.11.3
23-11-16 21:17:33 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.11.3.
Based on the first error looks like the vm has DNS resolution problems.
Any suggestions on how I can resolve that?
The DNS on my PC is set to Automatic and the DNS on my router is 1.1.1.1. I already tried switching the DNS on my router to 8.8.8.8 based on suggestions from other posts, but that didn’t help.
Also many of the posts I saw that suggestion in were about switching the DNS in the Home Assistant UI, which I don’t think I can get to in the current state?
The DNS settings on your PC and the server your router is pointed to have little bearing on this. As long as the vm can reach the router to acquire the network settings it should be able to resolve hostnames and reach the Internet. Did you verify that the vm can talk to the network outside of the PC? Also, it would be a good idea to create in your router a DHCP reservation for the vm. That’ll also allow you to verify whether the vm is able to reach it.
I created a DHCP reservation for it and it started working! The weird thing is that I tried it 3 times and messed with a bunch of other things and then it randomly started working the last time I recreated the vm and installed home assistant. So I assume the DHCP reservation was what fixed it, but not sure why it didn’t fix it the first time I tried it.
But regardless, thank you!
I spoke too soon. I got to the screen where HA was installing and it said it can take up to 20 mins. Then I hit an error again. This time it’s not as many, so that’s an improvement.
These are the errors in red I’m getting now:
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
It keeps retrying and gets the same errors.
Sounds like it’s still some kind of network error?
Yes, looks like docker can’t pull the image. If it’s still failing, boot the vm from a cd with any network tools (ie, an OS installer) and verify that you can resolve, ping and wget stuff from the Internet.
Board/chipset: ich9
Network: bridge. Promiscuous: allow all
500 server error is an error on the GitHub server.
Wait and it should solve itself.
tried disabling IPv6 ?
I’ve the same issue. Can’t update from 2023.10.3 to 2023.11.3.
Error messae:
23-11-25 15:08:23 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2023.11.3/json: Internal Server Error (“readlink /mnt/data/docker/overlay2: invalid argument”)
23-11-25 15:08:23 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
Changed DNS into 1.1.1.1. IPv6 is disabled. All the other updates (NodeRed, Terminal, Studio Code Server etc…) update normally.
Running HA from a Virtualbox (6.1.40) in Windows.
Anyone an idea what to do?
SOLVED! See this post: Update 11.3 doesn't work - #8 by catch-33
Looks like the issue was my Netgear Nighthawk router. I read that others had issues with Netgear Nighthawk routers, so I bought a random TP-Link router to test the theory and HA is working fine now!
In case anyone runs into this issue, the router that didn’t work is a Netgear Nighthawk AC1750 R6700v2. No amount of changing DNS, IP addresses, resetting the router, or even changing physical addresses with a different internet connection worked. It’s just something with the router.
