As long as no two automations trigger and try to run the same script at the same time. Don’t know how likely that is in your case, but I can tell you after many years of embedding programming, if it can happen, it will happen. But seriously, you’re probably pretty safe I’m guessin’.
You are right, it could happen, but it s really unlikely. I’m ok with that.
I’d like to add that there are some '
signs missing in the above shown examples. This might be important for others.
So in the script, ir should look like this
is_home_notify_user1:
sequence:
- condition: template
value_template: "{{ is_state('device_tracker.user1', 'home') }}"
- service_template: notify.user1
data_template:
message: "{{ message }}"
instead of this
value_template: "{{ is_state(device_tracker.user1, 'home') }}"
I will edit this in my examples above.
You may have missed it, but you don’t need to use service_template here. The service is not being specified by a template, so by using service_template you’re just making it less efficient. Not a huge issue, but no reason not to change it to just service. data_template, however, is needed here, since message is specified via a template.
Ok, so I used this for a long time:
is_home_notify:
sequence:
- condition: state
entity_id: person.XXX
state: 'home'
- service_template: "{{ notify }}"
data_template:
and it works fine. Now I read about that new functionality with replacing notifications and I’d like to add that to the script. I was able to add it to the script but with that code included I can’t use the script without “replacing notifications” any more.
So what I tried is this:
script:
is_home_notify:
sequence:
- condition: state
state: 'home'
- service: notify.ios_XXX
data_template:
push:
category: "{{ category }}"
apns_headers:
'apns-collapse-id': "{{ collapse_id }}"
in automation:
this works:
- service: script.is_home_notify_XXX
message: "some message"
category: "some category"
collapse_id: somecollapseid
but this won’t work any more:
because it seems like it needs the collapse id.
I also tried this, but this won’t work in any case:
apns_headers:
"{{collapse_id}}"
collapse_id: "'apns-collapse-id': 'collapse_gang'"`
Is it possible to integrate it somehow or do I have to use a separate script for that?
separate script
ok thank you
