Sure,
I am glad you are helping me. any time is ok.
Thank you for your time!
Sure,
what other states are you looking for?
Here’s a dumb example using your current icon_color
icon_color: "{{ 'green' if states('light.study') in ['on','off'] else 'red' }}"
…icon_color
will always be green in this example as the only two states for light are on
and off
well i have a state for my airco.
and now i have this code:
icon_color: >-
{{ 'green' if states('climate.146235046522113_climate') == 'auto' else
'red' }}
However i need these also auto, cool, fan_only, heat
So try this:
icon_color: "{{ 'green' if states('climate.146235046522113_climate') in ['auto','cool','fan_only','heat'] else 'red' }}"
However, if the only other option is off
, its’s easier to just reverse it:
icon_color: "{{ 'red' if states('climate.146235046522113_climate') == 'off' else 'green' }}"
Thank you verry much.
The first line is working perfectly!
bonjour,
je débute en yaml…
pourriez vous publier le yaml de toute la carte ?
merci
Il y en a trop.
Que voulez-vous faire ?
Hi, can you help me please. I’ve followed this thread but mine aren’t changing colour.
type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.wp66lsd_plug_state
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
icon_color: "{{ 'green' if states('sensor.wp66lsd_plug_state') == 'plugged' else 'red' }}"
Device is plugged in and it’s state is ‘plugged’.
I’ve gone to developer tools > states and these are all the available states the devices do:
options:
Not sure what I’m doing wrong, as I’ve picked the correct state option.
you can’t change colour with an entity card, you need the template card:
chips:
- type: template
I have farted around with for months, just like Mick I couldn’t get no satisfaction. Finally just changed to custom button cards, can make them look just like chips card with a lot more formatting options!
Found this theme, read almost all. For the future guys, it should look like this:
chips:
- type: template
entity: switch.someswitch
icon: mdi:desktop-tower-monitor
icon_color: |
{% if is_state(entity,'on') %}
#6b11b4
{% else %}
gray
{% endif %}
hold_action:
action: none
double_tap_action:
action: none
content: ChipsTitle
Hi Sorry,
Would anyone be able to help with this?
I am trying to change the battery colour on the %
at the moment the iphone battery is 46% and shows red?
```- type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.my_iphone_battery_level
- type: entity
entity: device_tracker.my_iphone
content_info: state
icon_color: white
icon: mdi:home
alignment: start
card_mod:
style: |
ha-card {
{% if states('sensor.my_iphone_battery_level') > '50' %}
--card-mod-icon-color: green;
{% elif states('sensor.sensor.my_iphone_battery_level') < '49' %}
--card-mod-icon-color: orange;
{% elif states('sensor.my_iphone_battery_level') < '5' %}
--card-mod-icon-color: red;
{% endif %}
columns: 2
Please try this. Values need to be integers, no quotes.
chips:
- type: entity
- type: entity
entity: light.pc_hue_bar
content_info: state
icon_color: white
icon: mdi:home
alignment: start
card_mod:
style: |
ha-card {
{% if states('sensor.my_iphone_battery_level') | int > 50 %}
{% elif states('sensor.my_iphone_battery_level') | int < 49 %}
{% elif states('sensor.my_iphone_battery_level') | int < 5 %}
{% endif %}
columns: 2
Hi, I’ve noticed that I’m unable to change the color of the mushroom chips icon if the entity is a script (and doesn’t really have any state). No matter what color I put into the icon_color
property it’s ignored. Using card_mod
doesn’t help neither
any thoughts?
I didn’t have any color issues with card_mod or icon_color. Add the type:template
setting for more control.
chips:
- type: template
entity: script.fan_speed_1
icon: mdi:mushroom
- type: template
entity: script.fan_speed_2
icon: mdi:mushroom
- type: template
entity: script.fan_speed_3
icon: mdi:mushroom
card_mod:
style:
mushroom-template-chip:nth-child(1)$: |
ha-state-icon {
color: red !important;
mushroom-template-chip:nth-child(2)$: |
ha-state-icon {
color: yellow !important;
mushroom-template-chip:nth-child(3)$: |
ha-state-icon {
color: lime !important;
chips:
- type: template
icon: mdi:mushroom
icon_color: red
- type: template
icon: mdi:mushroom
icon_color: red
- type: template
icon: mdi:mushroom
icon_color: red
it changes to the desired color only when I press then button (toggle). I’ve tried all sort s of overrides and importants, no luck. I’m giving up for now. Script is a simple call to a service.
[UPDATE] I’ve now noticed that you are using a type: template
where as I was using an entitiy chip. This one now works. Thanks!
thank you for this
