Mushroom Inspiration!
vertical-stack
vertical-stack-in-card
mushroom-template-card
mushroom-light-card
mushroom-chips-card
When i past your code, the card look like this. i have check all the code but i don’t understand why…
I’m guessing you’ve got a theme applied that changes the radius of the circle so it’s more square. And I can’t see the code but the secondary text template doesn’t seem to be resolving. Possibly an invalid entity since my code is set to pull from a thermostat entity.
Yes it work now thx a lot
For that its ok, i have to put my entity now.
Thx for the help
Please read the first post!
I would like this post to be all about pictures with codes, nothing else! So if you have something to share or offer, please do it with pictures and code.
Do not ask any questions here, instead ask them directly to the person or in the original Mushroom post!
Try to keep this as clean as possible and share with pictures and code.
Best regards
Thekholm
My speedtest card using card mod and custom:apexcharts-card.
Version with static colors:
Code
type: custom:stack-in-card
cards:
    entity: ''
    primary: Voer speedtest uit
    secondary: ''
    multiline_secondary: true
    icon: mdi:speedometer
    icon_color: grey
    tap_action:
      action: call-service
      service: speedtestdotnet.speedtest
      data: {}
      target: {}
    card_mod:
      style: |
        ha-card {
          margin: -25px 12px 0px 12px;
          border-bottom: solid 2px rgba(var(--rgb-disabled), 0.2);
  - type: custom:vertical-stack-in-card
    horizontal: true
    cards:
      - type: vertical-stack
        cards:
          - type: custom:apexcharts-card
            chart_type: radialBar
            series:
              - entity: sensor.speedtest_download
                color: rgb(255, 87, 34)
                max: 60
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  inverseColors: false
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 130
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                  background: none;
          - type: custom:mushroom-entity-card
            primary_info: state
            secondary_info: name
            icon: mdi:download
            icon_color: deep-orange
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
        cards:
            series:
              - entity: sensor.speedtest_upload
                color: rgb(33, 150, 243)
                max: 60
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 130
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                  background: none;
            primary_info: state
            icon: mdi:upload
            icon_color: blue
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
        cards:
            entity: sensor.speedtest_ping
            primary_info: state
            icon_color: teal
            icon: mdi:wan
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: 20px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
          background: none;
Version with dynamic colors based on download/upload value, using the experimental color_threshold feature of apex-charts. You can change the min/max/in-between values yourself in the code (currently 50-200 for download and 5-100 for upload):
Code
cards:
    entity: ''
    primary: Run speedtest
    secondary: ''
    icon: mdi:wifi-refresh
    icon_color: grey
    tap_action:
      data: {}
      target: {}
    card_mod:
      style: |
        ha-card {
    horizontal: true
    cards:
        cards:
            experimental:
              color_threshold: true
            series:
                color_threshold:
                  - value: 50
                    color: rgb(244, 67, 54)
                  - value: 75
                  - value: 100
                    color: rgb(255, 152, 0)
                  - value: 125
                    color: rgb(255, 193, 7)
                  - value: 150
                    color: rgb(255, 235, 59)
                  - value: 175
                    color: rgb(205, 220, 57)
                  - value: 200
                    color: rgb(129, 915, 74)
                  - value: 225
                    color: rgb(76, 175, 80)
                  - value: 250
                    color: rgb(78, 175, 80)
                max: 500
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
              legend:
                show: false
              chart:
                height: 130
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                  background: none;
            primary: |
              {{states('sensor.speedtest_download')|round(1)}} Mbps
            secondary: Download
            icon: mdi:download
            icon_color: |-
              {% set value = states('sensor.speedtest_download') | int %}
              {% if value < 50 %}
                red
              {% elif value < 75 %}
                deep-orange
              {% elif value < 100 %}
                orange
              {% elif value < 125 %}
                amber
              {% elif value < 150 %}
                yellow
              {% elif value < 175 %}
                lime
              {% elif value < 200 %}
                light-green
              {% elif value < 225 %}
                green
                green
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
        cards:
            experimental:
            series:
                color_threshold:
                  - value: 5
                  - value: 13
                  - value: 25
                  - value: 38
                  - value: 50
                  - value: 63
                  - value: 75
                  - value: 88
                  - value: 100
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
              legend:
                show: false
              chart:
                height: 130
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                  background: none;
            primary: |
              {{states('sensor.speedtest_upload')|round(1)}} Mbps
            secondary: Upload
            icon: mdi:upload
            icon_color: |-
              {% set value = states('sensor.speedtest_upload') | int %}
              {% if value < 5 %}
                red
              {% elif value < 13 %}
                deep-orange
              {% elif value < 25 %}
                orange
              {% elif value < 38 %}
                amber
              {% elif value < 50 %}
                yellow
              {% elif value < 63 %}
                lime
                light-green
              {% elif value < 88 %}
                green
                green
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
        cards:
            primary_info: state
            icon_color: teal
            icon: mdi:wan
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: 20px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
                  box-shadow: none;
                  background: none;
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
          background: none;
Thank you for this creation and sharing the code. I’m well on my way to bastardizing it and adopting it for my needs. I love it!
One thing I’m having a hard time figuring out though, I have some lights that shut off when a Timer Helper reaches 0. I’d like to show that timer either below the temp/humidity, or somewhere on the bottom of the card (maybe over the icon?). I just can’t figure out how to get it in there, any ideas?
My Homepage, inspired by many other people on this forum allowing me to learning bits and pieces from them and puzzling them together into this. Kudos to them!!
I used Mushroom card, Layout card, Browser Mod and Card Mod for the main design elements.
All of this is also located in a “Minimalist UI” Yaml config to allow for some graphic design elements.
The orange bars are for controlling the light, whereas the blue bars allow me to control the volume of my AVR.
The code (Below the pictures) might not be the prettiest, but like a said, it’s a lot of puzzle work based on the amazing work of several others here!
Also I am very open to hear any feedback!
CODE SNIPPETS
Living Room Card Code
type: custom:layout-card
layout_type: custom:grid-layout
layout:
  grid-template-columns: auto
  grid-template-rows: auto
  column-gap: 0px
  row-gap: 0px
  grid-template-areas: |
    "1"
    "2"
    "3"
    "4"
    "5"
    "6"
    "7"
    "8"
    "9"
    "10"
    "11"
    "12"
cards:
  - type: custom:mushroom-light-card
    entity: light.living_room_lights
    fill_container: true
    show_brightness_control: true
    use_light_color: false
    icon: mdi:sofa
    secondary_info: none
    layout: horizontal
    tap_action:
      # action: navigate
      # navigation_path: '/ui-lovelace-minimalist/Living'
      service: browser_mod.popup
        content:
          cards:
            - type: 'custom:button-card'
              template: card_title
              name: Living Room Media
            - type: custom:layout-card
              layout:
                column-gap: 0px
                row-gap: 0px
                  "1"
                  "2"
                  "3"
                  "4"
                  "5"
                  "6"
                  "7"
                  "8"
                  "9"
                  "10"
                  "11"
                  "12"
              cards:
                - type: custom:stack-in-card
                  cards:
                    - type: custom:mushroom-media-player-card
                      name: Living Room TV
                      entity: media_player.tv_living_room
                      media_controls:
                        - on_off
                        - play_pause_stop
                      tap_action:
                        action: more-info
                      use_media_info: true
                      show_volume_level: false
                      fill_container: false
                      layout: vertical
                      volume_controls: []
                      icon_type: none
                      primary_info: name
                  view_layout:
                    grid-column: 1
                    grid-row: 1
                  card_mod:
                    style: |
                      ha-card {
                        border-radius: 20px 20px 0px 0px;
                        height: 100px;
                        margin-top: 0px;
                        outline-color: red;
                        --chip-spacing: 0px;
                  cards:
                      entity: media_player.home_theater
                      media_controls: []
                      tap_action:
                        action: more-info
                      layout: vertical
                      volume_controls:
                        - volume_set
                        - volume_mute
                      icon_type: none
                      primary_info: none
                  view_layout:
                    grid-column: 1
                    grid-row: 2
                  card_mod:
                    style: |
                      ha-card {
                        border-radius: 0px 0px 0px 0px;
                        height: 85px;
                        margin-top: -14px;
                        outline-color: red;
                  cards:
                    - show_name: true
                      show_icon: false
                      type: button
                      tap_action:
                        action: more-info
                  view_layout:
                    grid-column: 1
                    grid-row: 3
                  card_mod:
                    style: |
                      ha-card {
                        height: 55px;
                        margin-top: -40px;
                        outline-color: red;
                  cards:
                    - show_name: true
                      show_icon: false
                      type: button
                      tap_action:
                        action: more-info
                      name: Home Theater Settings
                  view_layout:
                    grid-column: 1
                    grid-row: 4
                  card_mod:
                    style: |
                      ha-card {
                        border-radius: 0px 0px 20px 20px;
                        height: 55px;
                        margin-top: -20px;
                        outline-color: red;
            - type: entities
              entities:
                - type: divider
              name: Living Room Lights
              #label: 'Subtitle'
              cards:
                  entity: light.bar_table_lights
                  #layout: horizontal
                  show_color_temp_control: true
                  show_color_control: true
                  name: Bar Table Lights
                  entity: light.spotlights
                  use_light_color: true
                  entity: light.tv_table_lights
                  entity: light.light_bars
                  hide_state: false
                  # layout: vertical
                - type: horizontal-stack
                  cards:
                      entity: light.upstairs_lights
                      tap_action:
                        action: more-info
                      entity: light.sofa_ledstrip
                      tap_action:
                        action: more-info
            - type: entities
              entities:
                - type: divider
            - type: custom:mushroom-vacuum-card
              entity: vacuum.roborock_s6_pure
              commands:
                - start_pause
                - stop
                - return_home
        right_button: Close
    view_layout:
      grid_areas: 1
    card_mod:
      style: |
        :host([dark-mode]) {
          --ha-card-background: #2D3033;
          --mush-icon-size: 50px;
        ha-card {
          border-radius: 10px 10px 0px 0px;
          --control-height: 20px;
          --control-top: 16px;
          --control-border-radius: 5px;
          --control-border-spacing: 2px;
          --card-primary-font-size: 17px;
            icon-size: 50px;
            background: url('/local/images/tv_area.jpg'), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 90%);
            background-size: 80% auto, cover;
            background-position: right;
            background-repeat: no-repeat;
            background-blend-mode: saturation;
    cards:
        show_volume_level: true
        volume_controls:
          - volume_set
        icon_type: none
        primary_info: none
        use_media_info: false
        tap_action:
          action: none
        hold_action:
          action: none
        double_tap_action:
          action: none
        icon: ''
        collapsible_controls: false
        layout: horizontal
        card_mod:
          style: |
              --ha-card-background: rgb(var(--rgb-card-background-color));
              --mush-icon-size: 14px;
            ha-card {
              --icon-size: 24px;
              --control-height: 15px;
              --card-primary-font-size: 14px;
    view_layout:
      grid-column: 1
      grid-row: 2
    card_mod:
      style: |
        ha-card {
          height: 45px;
          margin-top: -14px;
          outline-color: red;
          --icon-size: 2px;
            background: url('/local/images/tv_area_bottom.jpg'), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 90%);
            background-size: 300px , cover;
            background-position: bottom;
    cards:
        chips:
          - type: template
            entity: light.livingroom_lights
            icon: >-
              {% if is_state('group.livingroom_lights', 'on') %}
              mdi:lightbulb-on  {% else %}  mdi:lightbulb  {% endif %}
            icon_color: >-
              {% if is_state('group.livingroom_lights', 'on') %} amber {% else
              %}  grey {% endif %}
            content: >-
              {% if is_state('group.livingroom_lights', 'on') %} {{
              expand(state_attr('group.livingroom_lights', 'entity_id')) |
              selectattr('state','eq','on') | list | count }}{% endif %}
          - type: template
            content: '{{ states(''sensor.kitchen_temperature'') }} ºC'
            icon: mdi:thermometer
            icon_color: >-
              {% set state=states('sensor.kitchen_temperature')|float(0) %} {%
              if state<20 %} blue {% elif state<23 %} green {% elif state<25 %}
              amber {% else %} red {% endif %}
        alignment: start
        card_mod:
          style: |
            ha-card {
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-spacing: -16px;
              --chip-height: 40px;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          border-radius: 0px 0px 10px 10px;
          height: 40px;
          margin-top: -14px;
          outline-color: red;
          --ha-card-background: #352E1F;
    cards:
        chips:
          - type: action
            icon: mdi:audio-video
            tap_action:
              service: media_player.toggle
              data: {}
                entity_id: media_player.home_theater
           - type: action
             icon: mdi:power
             tap_action:
               service: wake_on_lan.send_magic_packet
                 mac: XX:XX:XX:XX:XX:XX
                 broadcast_address: XXX.XXX.XX.XX
          - type: action
            icon: mdi:remote-tv
            tap_action:
                content:
                  type: custom:lg-remote-control
                title: TV Remote
              target: {}
          - type: action
            tap_action:
              service: script.upstairs_light_movie_mode
              data: {}
              target: {}
            icon: mdi:movie-play-outline
          - type: action
            tap_action:
              service: script.upstairs_light_bright
              data: {}
              target: {}
            icon: mdi:white-balance-sunny
          - type: action
            icon: mdi:weather-night
            tap_action:
              service: script.living_room_cozy
              data: {}
              target: {}
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
          --ha-card-background: none;
  - type: custom:gap-card
    height: 25
Dining Area card Code
###### Dining room card
layout:
  column-gap: 0px
  row-gap: 0px
    "1"
    "2"
    "3"
    "4"
    "5"
    "6"
    "7"
    "8"
    "9"
    "10"
    "11"
    "12"
cards:
    entity: light.dining_table_lights
    icon: mdi:silverware
    layout: horizontal
    tap_action:
        content:
          cards:
              #label: 'Subtitle'
              icon: mdi:lightbulb-variant-outline
              entity: light.liqour_cabinet_led_strip
              show_color_temp_control: false
              icon: mdi:led-strip-variant
        right_button: Close
      # action: navigate
      # navigation_path: /ui-lovelace-minimalist/Dining
    view_layout:
      grid_areas: 1
    card_mod:
      style: |
            height: 113px;
        ha-card {
          --control-height: 40px;
            icon-size: 50px;
            background: url('/local/images/dining_area.jpg'), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 80%);
    cards:
        chips:
          - type: template
            icon: >-
              {% if is_state('light.dining_table_lights', 'on') %}
            icon_color: >-
              {% if is_state('light.dining_table_lights', 'on') %} amber {% else
              %}  grey {% endif %}
            content: >-
              {% if is_state('light.dining_table_lights', 'on') %} {{
              expand(state_attr('light.dining_table_lights', 'entity_id')) |
          - type: template
            icon_color: >-
          - type: template
            content: '{{ states(''sensor.kitchen_humidity'') }} %'
            icon: mdi:water-percent
            icon_color: >-
              {% set state=states('sensor.kitchen_humidity')|float(0) %} {%
              if state<40 %} red {% elif state<50 %} amber {% elif state<60 %}
              blue {% else %} blue {% endif %}
        alignment: start
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
          outline-color: red;
    cards:
        chips:
          - type: template
          - type: action
            tap_action:
              service: light.turn_off
              data: {}
                entity_id:
                  - light.dining_table_lights
                  - light.liqour_cabinet_led_strip
            icon: mdi:lightbulb-group-off-outline
          - type: action
            tap_action:
              service: scene.turn_on
              data: {}
                entity_id: scene.dining_area_bright_2
          - type: action
            tap_action:
              data: {}
                entity_id: scene.dining_area_cozy
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
Kitchen Room Card Code
layout:
  column-gap: 0px
  row-gap: 0px
    "1"
    "2"
    "3"
    "4"
    "5"
    "6"
    "7"
    "8"
    "9"
    "10"
    "11"
    "12"
cards:
    height: 25
    entity: light.kitchen_spotlights
    icon: mdi:lightbulb-spot
    layout: horizontal
    tap_action:
      service: light.toggle
      data: {}
        entity_id:
          - light.kitchen_spotlights
    view_layout:
      grid_areas: 1
    card_mod:
      style: |
            height: 113px;
        ha-card {
          --card-primary-font-size: 20px;
            icon-size: 50px;
            background: url('/local/images/kitchen.jpg'), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 80%);
    cards:
        chips:
          - type: template
            icon: >-
              {% if is_state('light.kitchen_spotlights', 'on') %}
            icon_color: >-
              {% if is_state('light.kitchen_spotlights', 'on') %} amber {% else
              %} grey {% endif %}
            content: >-
              {% if is_state('light.kitchen_spotlights', 'on') %} {{
              expand(state_attr('light.kitchen_spotlights', 'entity_id')) |
              selectattr('state','eq','on') | list | count + 1}}{% endif %}
          - type: template
            icon_color: >-
          - type: template
            icon_color: >-
        alignment: start
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
          outline-color: red;
    cards:
        chips:
          - type: template
            content: >-
              {% if is_state('switch.grill', 'on') %} The Grill Is Turned On!!!!{% endif %}
        alignment: center
        card_mod:
          style: |
            ha-card {
              --chip-background: {% if is_state('switch.grill', 'on') %} red{% endif %};
              --chip-spacing: 0;
              --chip-height: 38px;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
    cards:
        chips:
          - type: template
          - type: action
            icon: mdi:grill
            tap_action:
              service: switch.toggle
              data: {}
                entity_id:
                  - switch.grill
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    view_layout:
      grid-column: 1
      grid-row: 3
    card_mod:
      style: |
        ha-card {
          height: 40px;
          margin-top: -14px;
Added version with dynamic colors to the Speedtest Card as suggested by @KyleBrown0221
Amazing!
Good job!
Been working on this one for a while. A weather forecast card, for weather entities that report weather variables for the upcoming days, with basic high/low temperatures. The day names can be localized to your language. The pictures are Googles weather icons, which has the consequence that the card background cannot be white, as that is the color of the clouds… You could use mdi icons instead. I recommend using the custom decluttering card as well.
Card
mode: horizontal
cards:
  - type: custom:decluttering-card
    template: weather_day_template
    variables:
      - index: 0
      - day: 1
    variables:
      - index: 1
      - day: 2
    variables:
      - index: 2
      - day: 3
    variables:
      - index: 3
      - day: 4
    variables:
      - index: 4
      - day: 5
card_mod:
  style: |
    ha-card {
      background: rgba(var(--mush-rgb-blue), 0.3);
Decluttering template
decluttering_templates:
  weather_day_template:
    card:
      cards:
          layout: vertical
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                background: none;
                margin-bottom: -18px;
          primary: ''
          secondary: >
            {% set dict = {'Mon': 'ma', 'Tue': 'di', 'Wed': 'wo', 'Thu': 'do',
            'Fri': 'vr', 'Sat': 'za', 'Sun': 'zo'} %}
            {% set str = as_timestamp(state_attr('weather.buienradar',
            'forecast')[[[index]]].datetime) | timestamp_custom("%a") %}
            {{ dict[str] }}
          layout: vertical
          entity: weather.buienradar
          tap_action:
            action: more-info
          icon: mdi:weather-partly-cloudy
          picture: >-
            {% set cloud = 100 -
            states("sensor.buienradar_sunchance_[[day]]d")|int %}
            {% set rain = states("sensor.buienradar_rain_[[day]]d")|float %}
            {% set entity =
            states("sensor.buienradar_detailed_condition_[[day]]d") %}
            {% if entity == "exceptional" %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/isolated_scattered_tstorms_day_dark_color_96dp.png
            {% elif entity == "fog" %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/haze_fog_dust_smoke_dark_color_96dp.png
            {% elif entity == "hail" %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/wintry_mix_rain_snow_dark_color_96dp.png
            {% elif entity == "lightning" %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/strong_tstorms_dark_color_96dp.png
            {% elif entity == "lightning-rainy" %}
            {% elif entity == "snowy" %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/flurries_dark_color_96dp.png
            {% elif entity == "snowy-rainy" %}
            {% elif rain > 0.3 and rain <= 1 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/drizzle_dark_color_96dp.png
            {% elif rain > 1 and rain <= 6 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/showers_rain_dark_color_96dp.png
            {% elif rain > 6 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/heavy_rain_dark_color_96dp.png
            {% if cloud < 20 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/sunny_dark_color_96dp.png
            {% elif cloud < 40 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_sunny_dark_color_96dp.png
            {% elif cloud < 60 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/partly_cloudy_dark_color_96dp.png
            {% elif cloud < 80 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_cloudy_day_dark_color_96dp.png
            {% elif cloud <= 100 %}
            http://www.gstatic.com/images/icons/material/apps/weather/2x/cloudy_dark_color_96dp.png
            {% else %} none {% endif %}
          primary: '{{states(''sensor.buienradar_temperature_[[day]]d'')}},'
          secondary: '{{states(''sensor.buienradar_minimum_temperature_[[day]]d'')}},'
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                background: none;
Have something similar created.
2023-01-25 16_38_20-Mushroom – Home Assistant and 1 more page - Work - Microsoft​ Edge
2023-01-25 16_38_43-Mushroom – Home Assistant and 1 more page - Work - Microsoft​ Edge
cards:
    layout_type: grid
    layout:
      width: 100%
      grid-template-columns: 10% 80%
    cards: null
    layout_type: grid
    cards:
        chips:
          - type: template
            icon_color: null
            content: Speedtest
          - type: template
            icon: null
            content: ''
        alignment: left
  - square: false
    columns: 3
    type: grid
    cards:
        cards:
            series:
                max: 500
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 130
            primary_info: state
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  width: auto%;
                  margin-left: auto;
                  margin-right: auto;
                  --card-primary-font-size: 12px;
                  --card-secondary-font-size: 10px;
        cards:
            primary_info: state
            icon_color: light-green
            icon: mdi:wan
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: auto;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
                max: 50
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 70%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 40
                    - 50
                    - 60
              legend:
                show: false
              chart:
                height: 130
            primary_info: state
            icon_color: blue
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -65px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
  - type: custom:fold-entity-row
    head:
      type: custom:mushroom-template-card
      label: padding
      secondary: meer
      tap_action: null
      card_mod:
        style: |
          ha-card {
            margin-left: 250px;
    padding: 0
    entities:
        cards:
          - type: custom:mini-graph-card
            entities:
                line_color: deep-orange
                show_adaptive_color: true
                y_axis: secondary
            hours_to_show: 24
            points_per_hour: 4
            line_width: 1
            font_size: 50
            animate: true
            show:
              icon: false
              state: false
              legend: true
              fill: fade
Also, a server card that’s similar to the Speedtest.
2023-01-25 16_46_57-Mushroom – Home Assistant and 1 more page - Work - Microsoft​ Edge
cards:
    layout_type: grid
    layout:
      width: 100%
    cards: null
    layout_type: grid
    cards:
        chips:
          - type: template
            icon: phu:nas
            icon_color: null
            content: Unraid
          - type: template
            icon: null
            content: ''
        alignment: left
  - square: false
    columns: 3
    type: grid
    cards:
        cards:
            series:
              - entity: sensor.192_168_178_37_cpu_used
                color: green
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: green
            icon: phu:intel-cpu
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
              - entity: sensor.192_168_178_37_ram_used_percent
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: blue
            icon: phu:ram-memory
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
              - entity: sensor.192_168_178_37_package_id_0_temperature
                color: red
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: red
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
              - entity: sensor.192_168_178_37_mnt_disk1_used_percent
                color: rgb(255, 233, 0)
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: yellow
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
              - entity: sensor.192_168_178_37_mnt_ssd_cache_used_percent
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: yellow
            icon: phu:seagate-ssd
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            series:
              - entity: sensor.192_168_178_37_mnt_hdd_cache_used_percent
                max: 100
                show:
                  legend_value: false
            apex_config:
              plotOptions:
                radialBar:
                  offsetY: 0
                  startAngle: -108
                  endAngle: 108
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
                  track:
                    strokeWidth: 80%
                    margin: 0
              fill:
                type: gradient
                gradient:
                  shade: light
                  type: horizontal
                  shadeIntensity: 0.3
                  opacityFrom: 1
                  opacityTo: 1
                  stops:
                    - 0
                    - 50
                    - 55
                    - 90
              legend:
                show: false
              chart:
                height: 140
            primary_info: state
            icon_color: yellow
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  margin-top: -57px;
                  width: auto;
                  margin-left: auto;
                  margin-right: auto;
This is a simple Tile for RGBs lights with the RGB component inside stack-in-a-card, since the Tile light does not have the color options yet.
mode: vertical
cards:
  - type: tile
    entity: light.luz_qua_abajur
    show_entity_picture: false
    features:
      - type: light-brightness
  - type: custom:rgb-light-card
    option: null
    justify: center
    colors:
      - rgb_color:
          - 243
          - 156
          - 18
      - rgb_color:
          - 230
          - 126
          - 34
      - rgb_color:
          - 211
          - 84
          - 0
      - rgb_color:
          - 192
          - 57
          - 43
        brightness: 150
        transition: 1
Mushroom Uptime Card:
uptimecard
required card: uptime card
GitHub - dylandoamaral/uptime-card: Minimalistic uptime card for Home Assistant Lovelace UI
code:
    mode: horizontal
    cards:
        entity: switch.iot_docker_adguardhome
        primary: AdGuard
        icon_color: |
          {% if is_state(config.entity, 'on') %}
            var(--color-background-green)
            var(--color-background-red)
        badge_icon: |
          {% if is_state('update.wud_container_local_adguardhome', 'on') %}
            mdi:update
          {% elif is_state('update.wud_container_local_adguardhome', 'unknown')  %}
            mdi:help
            disabled
        badge_color: |
            disabled
            orange
            transparent
        icon: si:adguard
        layout: horizontal
        card_mod:
          style:
            mushroom-state-info$: |
              .primary {
                font-size: 15px !important;
                position: relative;
                top: -10px;
                left: 0px;
                overflow: visible !important;
                color: var(primary-text-color);
                font-weight: bold;
                text-overflow: ellipsis;
              .primary:after {
                content: "{{ states(config.entity) }}";
                position: absolute;
                display: flex;
                justify-content: center;
                align-items: center;
                  color: var(--google-green);
                  color: var(--google-red);
                font-weight: bolder;
                border-radius: 50%;
                top: 5px;
                left: 115px;
                width: 16px;
                height: 16px;
                font-size: 14px;
      - type: custom:uptime-card
        entity: binary_sensor.uptimekuma_docker_adguard_iot
        hours_to_show: 48
        alignment:
          tooltip_first: true
        show:
          footer: false
          header: false
          status: false
        bar:
          height: 40
          round: 10
          spacing: 10
          amount: 6
        card_mod:
          style: |
            ha-card {
              position: relative;
              top: 10px;
              left: -55%;
              width: 150%;
may you need to do some adjustment for your setup with the position. Maybe there is also a better way to do it with css. Feel free to make the code better :slight_smile:
Cheers.
Mushroom card showing the number of unit on or off in a group:
cards:
    primary: Lumières
    secondary: |
      {% set all = expand('group.lumieres_toutes')| list -%}
      {% set ND1 = all | selectattr('state','eq','on')|list|count%}
      {% set D1 = all | selectattr('state','eq','off')|list|count%}
      allumées : {{ND1}} / éteintes : {{D1}}
    icon: |
      {% if is_state('group.lumieres_toutes', 'on') %}
        mdi:lightbulb-group
    icon_color: |
      {% if is_state('group.lumieres_toutes','on') %}
        orange
        grey
    badge_icon: |-
      {% set open1 = all | selectattr('state','eq','on')|list|count%}
      {% if open1 == 0 %}
        mdi:numeric-0
      {% elif open1 == 1 %}
        mdi:numeric-1
      {% elif open1 == 2 %}
        mdi:numeric-2
      {% elif open1 == 3 %}
        mdi:numeric-3
      {% elif open1 == 4 %}
        mdi:numeric-4
      {% elif open1 == 5 %}
        mdi:numeric-5
      {% elif open1 == 6 %}
        mdi:numeric-6
      {% elif open1 == 7 %}
        mdi:numeric-7
      {% elif open1 == 8 %}
        mdi:numeric-8
      {% elif open1 == 9 %}
        mdi:numeric-9
      {% elif open1 >= 9 %}
        mdi:numeric-9-plus
        none
    badge_color: |
      {% if open1 == 0 %}
        grey
        orange
    entity: group.lumieres_toutes
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      service: homeassistant.turn_off
      data: {}
        entity_id:
          - group.lumieres_toutes
          - switch.prise_tradfri_1
    double_tap_action:
      action: more-info
    primary: Volets
    secondary: |
      {% set all = expand('cover.tous_les_volets')| list -%}
      {% set ND1 = all | selectattr('state','eq','open')|list|count%}
      {% set D1 = all | selectattr('state','eq','closed')|list|count%}
      ouverts : {{ND1}} / fermés : {{D1}}
    icon: |
      {% if is_state('cover.tous_les_volets', 'open') %}
        mdi:window-shutter-open
        mdi:window-shutter
    icon_color: |
      {% if is_state('cover.tous_les_volets','open') %}
        light-blue
        green
    badge_icon: |-
      {% set open1 = all | selectattr('state','eq','open')|list|count%}
      {% if open1 == 0 %}
        mdi:numeric-0
        mdi:numeric-1
        mdi:numeric-2
        mdi:numeric-3
        mdi:numeric-4
        mdi:numeric-5
        mdi:numeric-6
        mdi:numeric-7
        mdi:numeric-8
        none
    badge_color: |
      {% if open1 == 0 %}
        green
        orange
    entity: cover.tous_les_volets
    layout: vertical
    hold_action:
      action: navigate
      navigation_path: /lovelace-smartphone/volets
    double_tap_action:
      action: more-info
    tap_action:
      action: more-info
    primary: Présence
    secondary: |
      {% set all = expand('binary_sensor.presence')| list -%}
      {% set ND1 = all | selectattr('state','eq','off')|list|count%}
      {% set D1 = all | selectattr('state','eq','on')|list|count%}
      présence : {{D1}} / non détectée : {{ND1}}
    icon: |
      {% if is_state('binary_sensor.presence', 'on') %}
        mdi:motion-sensor
        mdi:thumb-up
    icon_color: |
      {% if is_state('binary_sensor.presence','on') %}
        red
        green
    badge_icon: |-
      {% if open1 == 1 %}
        mdi:numeric-1
        mdi:numeric-2
      {% elif open1 == 0 %}
        mdi:numeric-0
        mdi:numeric-3
        mdi:numeric-4
        mdi:numeric-5
        mdi:numeric-6
        mdi:numeric-7
        mdi:numeric-8
        none
    badge_color: |
      {% if open1 == 0 %}
        green
        red
    tap_action:
      action: navigate
      navigation_path: /lovelace-smartphone/securite
    layout: vertical
Hi !
I love the idea and the compact and efficient use of the space.
I will probably use and modify it a lot !
On the other hand, I am trying to remove as much as possible cardmod and stack-in-card in order to stay closer to mushroom initial idea and be capable to use UI only.
I am thus trying to bring the same simplicity using only mushroom template and chips, but I have one problem remaining : Removing card mod is easy (despite less beautifull), but I struggle to find the equivalent of grid or horizontal/vertical stack that would allow to merge borders of cards while not breaking UI. Does this exist ?
When i use this room card in a h-stack, the left border is smaller then the right (i have 2 cards per row)
Using in a horizontal stack as well, 2 cards per row. They’re all the same size for me?
Hm, i’m also using h-stack. This is the results:
