Nice!! Thank you!
I really like this! I had been playing around with expanding the slider and reducing the device name to solve for the wasted space, but using shorter names wasnāt always viable. I tweaked your code a bit to preserve the accessibilty of the slider on the end and make the text a little easier to read when brightness is reduced.
card_mod:
style:
mushroom-state-info$:
.container: |
.primary {
flex-shrink: 1;
flex-grow: 1;
padding-left: 5px;
{% if state_attr(config.entity, 'rgb_color') == none %}
{% if states(config.entity) == 'on' %}
--primary-text-color: #1a1a1a;
{% else %}
{% endif %}
{% else %}
{% if (state_attr(config.entity,'rgb_color')[0] * 0.21 | float) + (state_attr(config.entity,'rgb_color')[1] * 0.72 | float) + (state_attr(config.entity,'rgb_color')[2] * 0.07 | float) >= 100 and state_attr(config.entity, 'rgb_color') != none %}
text-shadow: 0px 0px 7px rgba{{state_attr(config.entity,'rgb_color')[0] * 1, state_attr(config.entity,'rgb_color')[1] * 1, state_attr(config.entity,'rgb_color')[2] * 1, 1}};
{% else %}
text-shadow: 0px 0px 7px rgba{{state_attr(config.entity,'rgb_color')[0] * 0.5, state_attr(config.entity,'rgb_color')[1] * 0.5, state_attr(config.entity,'rgb_color')[2] * 0.5, 1}};
--primary-text-color: #fafafa;
{% endif %}
{% endif %}
.secondary {
flex-shrink: 1;
flex-grow: 0;
margin-right: 10px;
padding: 0 5px;
--secondary-text-color: #1a1a1a;
{% else %}
{% endif %}
{% else %}
{% else %}
text-shadow: 0px 0px 7px rgba{{state_attr(config.entity,'rgb_color')[0] * 0.5, state_attr(config.entity,'rgb_color')[1] * 0.5, state_attr(config.entity,'rgb_color')[2] * 0.5, 0.5}};
--secondary-text-color: #fafafa;
{% endif %}
{% endif %}
.container {
display: flex;
z-index: 1;
flex-direction: row !important;
align-items: baseline;
pointer-events: none !important;
margin-left: 10px;
margin-right: -8px;
{% else %}
{% endif %}
mushroom-button:nth-child(2)$: |
:host {
z-index: 1;
# margin-right: 5px !important;
--bg-color: rgba(var(--rgb-disabled),0.5) !important;
--icon-color: #1a1a1a !important;
{% else %}
--bg-color: rgba{{state_attr(config.entity,'rgb_color')[0] * 0.5, state_attr(config.entity,'rgb_color')[1] * 0.5, state_attr(config.entity,'rgb_color')[2] * 0.5, 0.5}} !important;
--icon-color: rgba{{state_attr(config.entity,'rgb_color')[0], state_attr(config.entity,'rgb_color')[1], state_attr(config.entity,'rgb_color')[2], 0.9}} !important;
{% else %}
# --icon-color: #dedede !important;
{% endif %}
{% endif %}
mushroom-button:nth-child(3)$: |
:host {
z-index: 1;
{% else %}
{% else %}
{% endif %}
{% endif %}
mushroom-light-brightness-control$:
mushroom-slider$: |
.container {
position: absolute;
flex-basis: max-content;
{% if (config.show_color_control == true and config.show_color_temp_control == true) %}
width: calc(100% - 190px);
{% elif (config.show_color_control == false and config.show_color_temp_control == true) %}
width: calc(100% - 136px);
{% elif (config.show_color_control == true and config.show_color_temp_control == false) %}
{% else %}
width: calc(100% - 80px);
{% endif %}
left: 68px;
top: 18.2%;
.slider-track-background {
background-color: rgba{{state_attr(config.entity,'rgb_color')[0] * 0.75, state_attr(config.entity,'rgb_color')[1] * 0.75, state_attr(config.entity,'rgb_color')[2] * 0.75, 0.5}} !important;
mushroom-light-color-control$:
mushroom-slider$: |
.container {
position: absolute;
{% if (config.show_color_temp_control == true) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
mushroom-light-color-temp-control$:
mushroom-slider$: |
.container {
position: absolute;
{% if (config.show_color_control == true) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
.actions {
display: flex;
flex-basis: min-content;
align-items: flex-end !important;
justify-content: flex-end !important;
flex-grow: 0;
flex-shrink: 0;
mushroom-state-info {
display: flex;
Edit: For some reason, lights without RGB or tunable white would not show correctly. I made an adjustment to the CSS in order to address this. Thereās probably a ābetterā way to align the brightness percentage text using flexbox, but this works well enough:
card_mod:
style:
.container: |
.primary {
{% if state_attr(config.entity, 'supported_color_modes')|contains('brightness') == true %}
flex-shrink: 0;
flex-grow: 0;
{% else %}
flex-shrink: 1;
flex-grow: 1;
{% endif %}
padding-left: 5px;
text-shadow: 0px 0px 7px orange;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.secondary {
position: absolute;
right: 15px;
top: 23px;
{% else %}
{% endif %}
{% else %}
flex-shrink: 1;
{% endif %}
flex-grow: 0;
margin-right: 10px;
padding: 0 5px;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.container {
display: flex;
z-index: 1;
margin-left: 10px;
margin-right: -8px;
{% else %}
{% endif %}
mushroom-slider$: |
.container {
position: absolute;
{% set rgb = (state_attr(config.entity, 'supported_color_modes')|contains('rgb') or state_attr(config.entity, 'supported_color_modes')|contains('xy')) and config.show_color_control != false %}
{% set color_temp = state_attr(config.entity, 'supported_color_modes')|contains('color_temp') and config.show_color_temp_control != false %}
{% if (rgb == true and color_temp == true) %}
{% elif (rgb == false and color_temp == true) %}
{% elif (rgb == true and color_temp == false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%;
mushroom-slider$: |
.container {
position: absolute;
{% if (state_attr(config.entity, 'supported_color_modes')|contains('color_temp') == true and config.show_color_temp_control != false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
mushroom-slider$: |
.container {
position: absolute;
{% if ((state_attr(config.entity, 'supported_color_modes')|contains('rgb') or state_attr(config.entity, 'supported_color_modes')|contains('xy') == true) and config.show_color_control != false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
.actions {
display: flex;
flex-grow: 9;
flex-shrink: 1;
{% else %}
flex-grow: 0;
flex-shrink: 0;
{% endif %}
display: flex;
Can I ask: How did you set up which batteries will be shown?
Yes you can, and are welcome to, but please
That would be this one:
Thanks a lot!
Nice. I really appreciate this as a layout.
A few minor comments I am going to try and fix.
I think the width should be governed by state_attr(config.entity.āsupported_color_modesā) and not whether you say to show/hide controls (that you cannot have maybe). I would be surprised if people do not want to display some control if it is available but then again for generic implementation probably needs both like if light supports HS and you choose to show that control, then ā¦
IMHO ā¦ the color of the ābuttonsā for temp, hs should not have anything to do with the color of the light (greatly simplifying this). The color of the state on the left is already there as well as the bar, the others are buttons and really should not take on characteristics of the rgb_color.
Iām actually using this with decluttering-card and wanted the option to disable the controls for a couple of lights that erroneously report RGB support despite being temperature/brightness only, but I agree that this is a super specific use case not generally applicable to most people. My non-decluttered (āclutteredā? lol!) version looks like this:
type: custom:mushroom-light-card
entity: light.craft_room_wall_sconce
icon: mdi:wall-sconce
show_brightness_control: true
show_color_control: >-
{{ state_attr(config.entity, 'supported_color_modes')|contains('rgb') or
state_attr(config.entity, 'supported_color_modes')|contains('xy') }}
show_color_temp_control: >-
{{ state_attr(config.entity, 'supported_color_modes')|contains('color_temp')
use_light_color: true
collapsible_controls: true
fill_container: true
tap_action:
action: toggle
hold_action:
action: more-info
double_tap_action:
action: none
layout: horizontal
card_mod:
style:
.container: |
.primary {
flex-shrink: 1;
flex-grow: 1;
padding-left: 5px;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.secondary {
flex-shrink: 1;
flex-grow: 0;
margin-right: 10px;
padding: 0 5px;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.container {
display: flex;
z-index: 1;
margin-left: 10px;
margin-right: -8px;
{% else %}
{% endif %}
:host {
{% else %}
{% else %}
{% endif %}
{% endif %}
:host {
{% else %}
{% else %}
{% endif %}
{% endif %}
mushroom-slider$: |
.container {
position: absolute;
{% set rgb = (config.show_color_control != false) %}
{% set color_temp = (config.show_color_temp_control != false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%;
mushroom-slider$: |
.container {
position: absolute;
{% if (config.show_color_temp_control != false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
mushroom-slider$: |
.container {
position: absolute;
{% if (config.show_color_control != false) %}
{% else %}
{% endif %}
left: 68px;
top: 18.2%
.actions {
display: flex;
flex-grow: 0;
flex-shrink: 0;
display: flex;
If you want the righthand buttons to follow the default color scheme rather than the RGB of the light, you could remove the mushroom-button:nth-child(2)$
and mushroom-button:nth-child(3)$
sections. Iāve tried both ways and Iām on the fence about which I prefer, but I see the appeal!
I like it. I also use decluttering (in fact this entire thing is 7 decluttering cards). These actually include other decluttering cards for mushroom-light, mushroom-chip for quick colors and currently custom button until I change them to mushroom for the 8 modes built-in plus speed control of the modes. SO easy to manage this way, decluttering is the best!
Going to make the modification now to extend the slider bar for the RGBW lights.
Sorry, was viewing the wrong group when I composed - previous issue was resolved with some hacking about at the css.
Hereās what Iāve managed to create from Rhys cards and the guide from Dimitri to replace my ui minimalist layout:
Dark:
Light:
Room Card: Room card with card mod (no UI minimalist) - Pastebin.com
card mod changes to Rhys top bar:
card_mod:
style: |
ha-card {
/* Set padding of card */
padding: 8px 8px 12px;
/* Move card up to match header card */
margin-top: -8px;
/* Styling of card background */
background: color-mix(in srgb, var(--card-background-color) 40%, var(--primary-background-color)) !important;
border-radius: var(--ha-card-border-radius, 12px) var(--ha-card-border-radius, 12px) 0px 0px ;
transition: all 0s;
/* Make card sticky at top of page */
:host {
position: sticky;
z-index: 9;
top: 0px;
Iāve only just started rooms, but will be using the light control from Tyler, which will work great in rooms that have two ceiling lights:
Light control: Mushroom Cards - Build a beautiful dashboard easily š - #7498 by Numotiv
Hi, if you feel like it, insert the code here like everyone else who posts examples here.
Hi Karoly, certainly, Iām just cleaning it up a bit then Iāll update the post with the code + sources.
Would you care sharing the yaml and theme? Itās the perfect theme I have been looking for.
Iāve been using your theme for a few months now, it makes it much easier to use on mobile.
Since version 2023.10, however, it no longer seems to work. Have you already created a new version?
could you show whatās not working?
donāt have any problems on my side
Mushroom-inspired Home Energy Card
Made with Button-Card and ApexCharts-Card.
The card shows
- the house-consumed energy in the center area
- the energy consumed from grid on the left area
- the energy consumed from your pv / home-battery on the right area
The colors will automaticly match your energy-dashboard-colors.
You just to need to fill in your entities in the āvariables:ā-section.
Variables:
- house_consumed_entity = entity that has the daily value of your house consumption
- house_consumed_label = text to display for that entity
- from_grid_entity = entity that has the daily value of energy from grid for your house consumption
- from_grid_label = text to display for that entity
- from_pv_entity = entity that has the daily value of energy from your pv / your home-battery for your house consumption
- from_pv_label = text to display for that entity
YAML-Code
type: custom:button-card
variables:
house_consumed_entity: sensor.house_consumed_daily
house_consumed_label: Haus
from_grid_entity: sensor.grid_imported_daily
from_grid_label: aus Netz
from_pv_entity: sensor.hausverbrauch_aus_solar_heute
from_pv_label: von PV
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
- border: none
- box-shadow: none
grid:
- grid-template-areas: '"karte"'
- grid-template-columns: 100%
- grid-template-rows: 100%
custom_fields:
karte:
- filter: opacity(100%)
- overflow: visible
custom_fields:
karte:
card:
type: custom:stack-in-card
card_mod:
style: |
ha-card {
padding: 0px;
mode: vertical
keep:
background: false
border_radius: true
box_shadow: false
margin: false
outer_padding: false
cards:
- type: grid
columns: 3
square: false
cards:
- type: custom:button-card
entity: '[[[ return variables.from_grid_entity ]]]'
icon: mdi:transmission-tower-export
show_icon: true
show_name: false
show_state: true
show_label: true
label: '[[[ return variables.from_grid_label ]]]'
styles:
grid:
- grid-template-areas: '"i s" "i l"'
- grid-template-rows: 1fr 1fr
- grid-template-columns: 4rem auto
card:
- height: 80px
- box-shadow: none
- border: none
- padding: 0px 0px 0px 0px
icon:
- height: 3rem
- color: var(--energy-grid-consumption-color)
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
- text-align: center
label:
- font-size: 0.8rem
- align-self: start
- type: vertical-stack
cards:
- type: custom:apexcharts-card
card_mod:
style: |
ha-card {
background: none;
border: none;
box-shadow: none;
height: 80px;
padding: 0px;
stacked: true
chart_type: donut
header:
show: false
floating: true
apex_config:
plotOptions:
pie:
customScale: 1.8
chart:
height: 85px
offsetX: 0
offsetY: 18
legend:
show: false
series:
- entity: '[[[ return variables.from_pv_entity ]]]'
color: var(--energy-solar-color)
show:
datalabels: false
- entity: '[[[ return variables.from_grid_entity ]]]'
show:
datalabels: false
entity: '[[[ return variables.house_consumed_entity ]]]'
layout: vertical
show_name: false
show_state: true
show_icon: true
show_label: true
label: '[[[ return variables.house_consumed_label ]]]'
styles:
card:
- height: 60px
- margin-top: '-70px'
- background: none
- border: none
- box-shadow: none
state:
- font-weight: bold
- font-size: 0.8rem
label:
- font-size: 0.8rem
icon:
- height: 1.5rem
- color: grey
icon: mdi:recycle
show_icon: true
show_name: false
show_state: true
show_label: true
label: '[[[ return variables.from_pv_label ]]]'
styles:
grid:
- grid-template-areas: '"s i" "l i"'
- grid-template-columns: auto 4rem
card:
- height: 80px
- box-shadow: none
- border: none
icon:
- height: 3rem
- color: var(--energy-solar-color)
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
label:
- font-size: 0.8rem
- align-self: start
Mushroom-inspired Solar Energy Card
The card shows
- the energy produced by your pv in the center area
- the energy fed to grid in the left area
- the energy that goes to your home / home-battery in the right area
Variables:
- solar_produced_entity = entity that has the daily value of your pv production
- solar_produced_label = text to display for that entity
- to_grid_entity = entity that has the daily value of energy fed to grid from your pv
- to_grid_label = text to display for that entity
- to_home_entity = entity that has the daily value of energy to your home / home-battery from pv
- to_home_label = text to display for that entity
YAML-Code
variables:
solar_produced_entity: sensor.solar_produced_daily
solar_produced_label: Solar
to_grid_entity: sensor.grid_exported_daily
to_grid_label: ins Netz
to_home_entity: sensor.stromeigenverbrauch_heute
to_home_label: ins Haus
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
- border: none
- box-shadow: none
grid:
custom_fields:
karte:
- overflow: visible
custom_fields:
karte:
card:
card_mod:
style: |
ha-card {
padding: 0px 0px 0px 0px;
mode: vertical
keep:
background: false
border_radius: true
box_shadow: false
margin: false
cards:
- type: grid
columns: 3
square: false
cards:
label: '[[[ return variables.to_grid_label ]]]'
entity: '[[[ return variables.to_grid_entity ]]]'
icon: mdi:transmission-tower-import
show_icon: true
show_name: false
show_state: true
show_label: true
styles:
grid:
card:
- height: 80px
- box-shadow: none
- border: none
icon:
- height: 3rem
- color: var(--energy-grid-return-color)
- transform: rotateY(180deg)
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
label:
- font-size: 0.8rem
- align-self: start
cards:
card_mod:
style: |
ha-card {
background: none;
border: none;
box-shadow: none;
height: 80px;
padding: 0px;
stacked: true
chart_type: donut
header:
show: false
floating: true
apex_config:
plotOptions:
pie:
customScale: 1.8
chart:
height: 85px
offsetX: 0
offsetY: 18
legend:
show: false
series:
- entity: '[[[ return variables.to_home_entity ]]]'
color: var(--energy-battery-out-color)
show:
datalabels: false
- entity: '[[[ return variables.to_grid_entity ]]]'
show:
datalabels: false
entity: '[[[ return variables.solar_produced_entity ]]]'
layout: vertical
show_name: false
show_state: true
show_icon: true
show_label: true
label: '[[[ return variables.solar_produced_label ]]]'
styles:
card:
- height: 60px
- background: none
- border: none
- box-shadow: none
state:
- font-weight: bold
- font-size: 0.8rem
label:
- font-size: 0.8rem
icon:
- height: 1.5rem
- color: darkorange
icon: mdi:home-battery
show_icon: true
show_name: false
show_state: true
show_label: true
label: '[[[ return variables.to_home_label ]]]'
styles:
grid:
card:
- height: 80px
- box-shadow: none
- border: none
icon:
- height: 3rem
- color: var(--energy-battery-out-color)
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
label:
- font-size: 0.8rem
- align-self: start
I really like the above designs, thanks. They look great on a Web Page, but when I see them on the Home Assistant App on an iPhone 15 Pro Max, the Apex Chart is off. Any idea?
get you every working this in an auto-entities template. Iām using differnet popups and create all lights with a group but the card_mod is not working there (maybe formating problem).
Any ideas?
- type: custom:auto-entities
show_empty: true
card:
type: entities
sort:
methode: name
filter:
template: >-
{% set elements = expand('group.grp_licht_wz') |
map(attribute = "entity_id") | list %} [ {% for
element in expand(elements) %}
'type': 'custom:mushroom-light-card',
'entity': element.entity_id,
'layout': 'horizontal',
'use_light_color': true,
'show_brightness_control': true,
'show_color_temp_control': true,
'show_color_control': true,
'collapsible_controls': true,
'card_mod': {
'style':
"mushroom-state-info$:
.container: |
.primary {
flex-shrink: 1;
flex-grow: 1;
padding-left: 5px;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.secondary {
flex-shrink: 1;
flex-grow: 0;
margin-right: 10px;
padding: 0 5px;
{% else %}
{% endif %}
{% else %}
{% else %}
{% endif %}
{% endif %}
.container {
display: flex;
z-index: 1;
margin-left: 10px;
margin-right: -8px;
{% else %}
{% endif %}
:host {
z-index: 1;
{% else %}
{% else %}
{% endif %}
{% endif %}
:host {
z-index: 1;
{% else %}
{% else %}
{% endif %}
{% endif %}
mushroom-slider$: |
.container {
position: absolute;
{% else %}
{% endif %}
left: 68px;
top: 18.2%;
mushroom-slider$: |
.container {
position: absolute;
{% else %}
{% endif %}
left: 68px;
top: 18.2%
mushroom-slider$: |
.container {
position: absolute;
{% else %}
{% endif %}
left: 68px;
top: 18.2%
.actions {
display: flex;
flex-grow: 0;
flex-shrink: 0;
display: flex;
mushroom-shape-icon {
--icon-border-radius: var(--control-border-radius);
ha-card {
--icon-symbol-size: 30px;
{% endfor %} ]
mhā¦ could you please try this?
variables:
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 0px
grid:
custom_fields:
karte:
- overflow: visible
custom_fields:
karte:
card:
card_mod:
style: |
ha-card {
mode: vertical
keep:
background: false
border_radius: true
box_shadow: false
margin: false
cards:
- type: grid
columns: 3
square: false
cards:
show_icon: true
show_name: false
show_state: true
show_label: true
styles:
grid:
card:
- height: 80px
- box-shadow: none
- border: none
icon:
- height: 3rem
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
label:
- font-size: 0.8rem
- align-self: start
cards:
card_mod:
style: |
ha-card {
background: none;
border: none;
box-shadow: none;
height: 80px;
padding: 0px;
stacked: true
chart_type: donut
header:
show: false
floating: true
apex_config:
plotOptions:
pie:
customScale: 1.8
chart:
height: 85px
offsetX: 0
offsetY: 18
legend:
show: false
series:
show:
datalabels: false
show:
datalabels: false
layout: vertical
show_name: false
show_state: true
show_icon: true
show_label: true
styles:
grid:
- grid-template-areas: '"top" "i" "s" "l" "bottom"'
- grid-template-rows: 1fr 1fr auto auto 1fr
card:
- height: 80px
- margin-top: '-80px'
- background: none
- border: none
- box-shadow: none
state:
- font-weight: bold
- font-size: 0.8rem
label:
- font-size: 0.8rem
icon:
- height: 1.5rem
- color: darkorange
show_icon: true
show_name: false
show_state: true
show_label: true
styles:
grid:
card:
- height: 80px
- box-shadow: none
- border: none
icon:
- height: 3rem
state:
- font-weight: bold
- font-size: 1rem
- align-self: end
label:
- font-size: 0.8rem
- align-self: start
Does this work better?
