Music Assistant: Timeout while waiting for authentication callback
I’m having a hell of a time trying to get Music Assistant Server set up and I have no idea where I could be going wrong.
  • I have a Pi4 running Home Assistant (2024.12.0) in Docker on my LAN but it can only be controlled through DuckDNS. I can SSH the system for maintenance over the LAN. Aside from HA sometimes locking me out of my own system if I turn off my VPN on my desktop PC, it’s generally running pretty smoothly.
  • I have a mini PC running Music Assistant Server in Docker on the same LAN (in host network mode, of course). The logs state: “Loaded plugin provider Home Assistant”.
  • I am able to load both the HA webserver page and the Music Assistant Server webpage from a third PC, however I run into problems trying to link the two during configuration – While trying to set up Home Assistant as a plugin provider using the Music Assistant page, I am brought to a new tab to log into Home Assistant. After entering my credentials, it asks for a confirmation number from my two-factor authentication app. I have tried countless times and every single time I’m either told that my code was no good, or that there was a “timeout while waiting for authentication callback”. The same message is mirrored in the MA Docker log.
    “Error handling message: config/providers/get_entries: Timeout while waiting for authentication callback.”
-The Home Assistant Music Assistant integration claims that it is successfully configured after adding it, but then fails setup and continually re-tries to reach MA (probably because of the lack of authentication, I’m guessing).
I’m pretty sure I’ve followed the setup directions to the T so I thought I’d ask here before throwing in the towel.
Thanks.
Hello Quixote,
Is there any particular reason you didn’t ask in the thread for Music assistant? The people that are watching that thread are all either interested. users of, or authors of Music Assistant. They are likely your best resource.
There is also a discord server for it. Not certain if this invite link still works, but here it is.
Thanks. I wasn’t aware that there is a dedicated thread for Music Assistant. I’ll try posting there instead.
