Hi, first of all thanks for your amazing work. I used your first version for a long time until it stops working. now I’m trying to set up this v2 but without success.
I have Hass.io running on a RPi 3+ and i followed your instructions about your folder structure… but when I reboot the system it starts in safe mode and I get this errors:
error from callback <bound method Listener.on_message of <Listener(Thread-3, initial daemon)>>: on_message() missing 1 required positional argument: ‘message’
12:56:43 – components/pushbullet/sensor.py (ERROR) - message first occurred at 12:48:43 and shows up 17 times
Can’t update remote details from Home Assistant cloud
12:48:51 – main.py (ERROR)
Don’t use ‘server_host’ options with Hass.io
12:48:20 – Hass.io (WARNING)
Any advise please?
In the homeassistant log file I have this error:
2020-04-07 12:47:15 ERROR (MainThread) [homeassistant.setup] Error during setup of component lovelace
File "/usr/src/homeassistant/homeassistant/setup.py", line 170, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 97, in async_setup
resource_collection = await create_yaml_resource_col(hass, yaml_resources)
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 222, in create_yaml_resource_col
ll_conf = await default_config.async_load(False)
File "/usr/src/homeassistant/homeassistant/components/lovelace/dashboard.py", line 186, in async_load
self._load_config, force
File "/usr/src/homeassistant/homeassistant/components/lovelace/dashboard.py", line 204, in _load_config
config = load_yaml(self.path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 61, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/local/lib/python3.7/site-packages/yaml/__init__.py", line 114, in load
return loader.get_single_data()
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 43, in get_single_data
return self.construct_document(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 47, in construct_document
data = self.construct_object(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 92, in construct_object
data = constructor(self, node)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 195, in _ordered_dict
nodes = loader.construct_pairs(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 147, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 226, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 400, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 122, in construct_sequence
for child in node.value]
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 122, in <listcomp>
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 116, in _include_yaml
return _add_reference(load_yaml(fname), loader, node)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 114, in _include_yaml
fname = os.path.join(os.path.dirname(loader.name), node.value)
File "/usr/local/lib/python3.7/posixpath.py", line 94, in join
genericpath._check_arg_types('join', a, *p)
File "/usr/local/lib/python3.7/genericpath.py", line 153, in _check_arg_types
(funcname, s.__class__.__name__)) from None
TypeError: join() argument must be str or bytes, not 'list'
Thanks!
