My Garden Irrigation
Hi Klogg i hate to be a pain but everything seems to be working fine except the mini graph card area for high temperature, i have done all the requirements listed, with the change of
entity: sensor.dark_sky_forecast_daytime_high_temperature_0d
to -
entity: sensor.dark_sky_daytime_high_temperature_0d
and the sensor.dark_sky_minutely_summary change as well.
i believe i have the dark sky loaded correctly as it states "weather outlook - overcast for the hour but no graph card display.
i’ve notice in the temperature graph yaml there is a line -
entity: sensor.dark_sky_current_temperature, where is this taken from with dark sky as i have no entity with that name listed to pull from ? my monitored conditions below…
  • platform: darksky
    api_key: “”"""""""""""""""""""""""""
    forecast:
    • 0
      monitored_conditions:
    • icon
    • summary
    • temperature
    • temperature_high
    • temperature_low
    • apparent_temperature
    • apparent_temperature_high
    • apparent_temperature_low
    • precip_type
    • precip_probability
    • precip_accumulation
    • precip_intensity
    • precip_intensity_max
    • daily_summary
    • minutely_summary
Any help would be appreciated…
Yes there is an omission from the readme which must have happened when I restructured everything (now updated).
In the custom:mini-graph-card find the line:
- entity: sensor.dark_sky_current_temperature
and change it to
- entity: sensor.dark_sky_temperature
I have just improved the settings lines.
I was never happy using multiple-entity-row because the pop up to edit settings was inconsistent. If you clicked the state you got the pop up as I designed it but if you clicked the name you got the HA system style pop up.
Also I couldn’t restrict the number of decimal places.
Four Lovelace files have been changed:
item_settings_line.yaml
section_settings_general.yaml
section_settings_rainfall
section_settings_temperature
There is no longer a requirement for the custom card multiple-entity-row
My UI doesn’t look as nice as this. Am I missing something? see screenshot below:
Oswald font - see the docs
What hardware are you using for the popup sprinklers on the lawns please? I looked at the eZyvalve™4 but it looks as if it doesn’t provide that must water pressure to work on anything but a mirco irrigation?
Cheers
Mark
Rainbird and I have max three sprinklers off each valve.
I have the Oswald font in resources already, is there anything else that you can think of?
I got the UI right… I had to restart HA… a reload/check configuration wasn’t enough.
Can the CSS file be downloaded and stored locally rather than fetching from google everytime? Could be an improvement? what are people thoughts on this?
I’m afraid this is beyond my limited CSS knowledge…
Hi klogg in the garden_weather_temperature.yaml i notice the dark sky entity is set too current, is this correct or should it be sensor.dark_sky_temperature for those fields.
Yes!
Good catch, I’ll update the docs.
Thanks!
And one more change in the section_settings_temperature.yaml i can see, which needs to be sensor.dark_sky_daytime_high_temperature_0d, plus there was one of these in the garden_weather_temperature.yaml that needed to be changed as well, i just keep spotting them, hope this is ok pointing it out, it’s all a new curve for me but i think i’m getting there.
No problem, thanks for spotting them.
I’ve updated the readme in a way that should cover all occurrences :wink:
Thank you @klogg for this great project. I used version 1 last year and it worked phenomenal. Version 2 has grown in functionality with beautiful UI. Just wanted to thank you for your hard work.
You’re very welcome, I’m just glad it is useful for others.
@klogg I am using your ver.1 with some light modifications (using own meteo station) for a long time. Thank you for your excellent work. As I am quite happy with it I´ve decided to upgrade to ver.2.
I run Hassio 110.1.
Technically I dis copy/paste I disabled all related to SmartWeather - replaced by precipitation data from my house station and its history. Next step would be to replace dark_sky by a local temperature and its history.
I have installed all custom integrations as described.
I believe that prerequisites are fullfilled, dark_sky changes as well.
Nonetheless I see only this on UI:
Irrig v2
It looks like lovelace goes to garden/cycles/page_cycles.yaml and shows dividers only :frowning: There are no errors or warnings in the log and I am not able to detect what is wrong.
Have you ever met the same issue?
Any advice will be great?
Update
There are yaml files in Templates and even view_garden_version2.yaml with errors
where all errors are bad indentations
First of all I have no idea if it makes any difference but I am still on v109 of HA.
As for the ‘bad indentations’ I am not sure why you get those errors. Are you sure there have not been any errors introduced while copying the files to your config?
I don’t recognise that error page either, are you using yaml mode? I would guess it should also work perfectly well if set up through the UI but I don’t do it that way.
Perhaps you could post one of the files that gives you an error?
I use yaml mode.
One of yaml files with those errors
# lovelace_gen
title: Garden
path: garden
# icon: mdi:flower
# icon: mdi:tree
icon: mdi:sprinkler-variant
# theme: irrigation_theme
panel: true
cards:
  - type: custom:layout-card
    layout: horizontal
    cards:
      #=== SYSTEM STATUS
      - !include templates/garden/status/page_status.yaml
      #=== SCHEDULES
      - type: vertical-stack
        cards:
          - type: conditional
            conditions:
              - entity: input_boolean.irrigation_master_control_switch
                state: "on"
            card:
              !include templates/garden/cycles/page_cycles.yaml
          - type: conditional
            conditions:
                state: "on"
            card:
              type: custom:hui-element
              card_type: custom:state-switch
              entity: sensor.irrigation_ui_selected_cycle
              default: cycle1
              states:
                cycle1:
                  !include
                    - templates/garden/cycles/section_cycle1_2_schedule.yaml
                    - cycle: 1
                cycle2:
                  !include
                    - cycle: 2
                cycle3:
                  !include templates/garden/cycles/section_cycle3_schedule.yaml
      #=== SETTINGS
        cards:
          - type: conditional
            conditions:
                state: "on"
            card:
              !include templates/garden/settings/page_settings.yaml
          - type: conditional
            conditions:
                state: "on"
            card:
              entity: sensor.irrigation_ui_selected_settings
              default: general
              states:
                general:
                  !include templates/garden/settings/general/section_settings_general.yaml
                rainfall:
                  !include templates/garden/settings/rainfall/section_settings_rainfall.yaml
                temperature:
                  !include templates/garden/settings/temperature/section_settings_temperature.yaml
If I click on the red exclamation mark it shows
bad indentation of a mapping entry at line 47, column 28:
                        - cycle: 1
There are a lot of files with exclamation mark.
As I am digging deeper, it is not only bad indentation but other errors too.
I am sure that errors are not introduced during copying.
List of files is here
/view_garden_version2.yaml
/templates/titles.yaml
/templates/garden/cycles/item_cycle_zone_duration_line.yaml
/templates/garden/cycles/page_cycles.yaml
/templates/garden/cycles/section_cycle1_2_schedule.yaml
/templates/garden/cycles/section_cycle3_schedule.yaml
/templates/garden/settings/general/item_settings_notify_users.yaml
/templates/garden/settings/general/section_settings_general.yaml
/templates/garden/settings/page_settings.yaml
/templates/garden/settings/rainfall/section_settings_rainfall.yaml
/templates/garden/settings/temperature/section_settings_temperature.yaml
/templates/garden/status/current/section_status_current_status.yaml
/templates/garden/status/history/section_status_history.yaml
/templates/garden/status/last_run/section_status_last_run.yaml
Please check that you have all necessary custom cards and integrations installed, especially lovelace_gen
