All files now Uploaded To Github
Hey klogg,
thank you for the great job and the quick fix.
I just ran into an error when I cancel the irrigation.
Fehler beim Aufrufen des Service script/irrigation_cancel_irrigation. not a valid value for dictionary value @ data[‘entity_id’]
Can you help me fixing this?
Thank you for the fix! Seems to be working a charm.
Appreciate all you effort with this project!
Thanks for the update!
When you get a chance, can you try cancelling a cycle.
It seems to work for me but @Misterbrot1966 is having an issue with it.
Okay I reuploaded all Files and restartet everything, seems to work fine now!
Thank you very much!
Everything works now.
Thanks again for your amazing work
Cancelling seems to work as intended - Seems Misterbrot1966 reloaded and the issue is solved too.
Yep i agree all seems to be working so far, except when watering a zone the countdown timer does not count down, after a refresh it will jump down to where the countdown is ie:- 10min to 5m left but does not continue the countdown, this also happened in the previous versions but i thought i would wait for the update to make sure, anyone else having this issue ?
Once again great work Klogg and thanks again …Your a rough diamond from a galactic star.
Yeah, timers in the front end can be a bit hit and miss in my experience. Unfortunately I don’t have a solution other than to refresh if it is not displaying correctly.
Thanks for the compliment
Could I get a link to your fork? I also need more than 8 zones
No worries, and as a update the timers work ok on the HA companion app on the iPhone but no real loss on the laptop, just me wanting to look at the countdown being a bit of a curtain twitcher wanting to see everything.
Hi @Mship.
I haven’t updated it yet with the latest changes, seems that there are a lot of issues with the 113 and i want to see how it goes.
Thank you very much. If I dont need 16 zones can you direct me to the files that need modification?
@Athan When you do come to chance it you will need to also look in garden_ui_initialise.yaml
. I don’t think it will actually affect you because you already have everything initialised but it has some script repeats hardcoded as ‘8’.
Look for count: 8
(I don’t know how a fork
works so maybe you’d have been alerted to this anyway but I thought I’d mention it as it is a bit obscure.)
No modifications needed. Just change the No Of Zones like you do at the original package
Thank you for the heads up @klogg. I will look at it. I just downgrade to 112. Too many issues to 113 !!!, and this is a live system to me. I’ll keep an eye to your latest info and see how it goes.
Yes, it’s a live system for me too.
I was a bit nervous about making all the changes for 113 but it seem to have gone ok so far
Take your time though… winter will be here before we know it…
And as soon as I had typed that I wondered why I hadn’t templated the repeat count!!
Probably still getting used to the new structures. (That is my best excuse!).
I’m pretty sure that is possible, let me check and update the files…
@Mship
I’d hold off until I have checked this. It will be a lot simpler.
I hope to do it tonight…
