My Garden Irrigation
I have tried this solution but many errors come out.
I finally solved it. Thanks to pask23.
FIX LAYOUT: (in file “view_garden_version2.yaml”)
change:
  # Display columns correctly using layout-card
  - type: custom:layout-card
    layout: horizontal
    cards:
with:
    layout_type: custom:horizontal-layout
    cards:
Fantastic. Thanks lion06.
Just a quick note here to apologise at my lack of responses but I am still finding it hard to make any time for HA at the moment.
I do definitely plan to address all the issues in the coming weeks but until then thanks to everyone who is responding with answers to queries.
Also I should add that I brought my system out of hibernation last week in preparation of the good weather and my setup seems to be running as expected, so if you are having issues and want to persevere it should work.
Note that I have not yet updated layout-card because as @gianni_Barin and @lion06 have seen it is a breaking change.
So apart from the strange date issue which doesn’t cause me a problem but is solved for those where it does (and is better code which I will incorporate!) by @cecet23 and the removal of deviceID: this there is nothing else that should prevent the system working.
Hello. I just installed this project and after several corrections the only thing that it’s not working is the scheduling start, even selecting every day, the start time and end time are correct but it doesn’t start, if I select the manual start it works. Can someone help?
My HA is at 2021.3.4
Regards
I’ve updated the code on Github for correct start date/time as suggested by @cecet23.
I think that is the issue causing most problems especially to people finding this project recently for the first time. To be honest I don’t know why it was causing some people problems. It can’t be a simple time zone issue as I know people in different time zones to me are using it successfully. If anyone does know the answer I’m very interested!
I’m pretty sure that everything else is down to breaking changes in Lovelace custom cards.
I’m my case the end time is correct but the irrigation doesn’t start and it imediatly updates next run time.
Thanks for the work you do.
Wrong end time.
immagine
I have this issue and cannot solve it.
have you tried to change “Maximum Time to Run a Zone” in general settings?
If you could just please try your V1.0 and see if it’s still working for you…
…probably it’s just something in water time calculation that doesn’t work anymore, but I can’t figure it out :worried:
I’ll try to find time to look at it. It is probably some breaking change in HA. I haven’t used v1 for well over a year (a long time in the life of HA!).
When did it last work for you?
thank you very much.
I used it until… october I think.
I switched it back on 2 weeks ago, and cycles did not start.
Not just scheduled cycles, also manual cycles, so schedules are probably ok.
I think the problem should be in garden_irrigation.yaml and yes, I think because of some breaking change that I didn’t notice.
Hello everyone, after several attempts and changes made following your advice it almost seems to work. What still doesn’t work is the button to stop irrigation, the button to start in test doesn’t give any results, and I don’t see the numbers to change the start time. Some idea?
I changed to 30 minutes. Error remains.
good morning everyone, even after updating the package released by Klogg, I can’t get the irrigation to work properly, but my only problem is that the pop-ups don’t open to fix the start and end times. The Browser mod is updated to version 1.3.0.
Anyone else still have the same problem?
Thanks so much
The new package will still need you to delete the device id sections as stated above, as Klogg has not implemented that part as yet, then it should work if you have not done that bit as yet.
[quote=“pask23, post:1263, topic:99686”]
  1. search in the repository github project of @Koggly (https://github.com/kloggy/HA-Irrigation-Version2 ) all occurrences of deviceID :
The result is 17 files.
  1. for each file, delete the entry
Copy to clipboard
 deviceID:
   - this
see here
