Awesome, if you’re happy with the API then that sounds good enough for me. Even if its not home assistant, a decent API is important.
I’ll make it happen
I’ll make it happen
I have continued working on getting my system into HA… whilst @smallsam’s library is a great start, the lack of a zone-aware climate component really makes it difficult to integrate.
So I took the easy way out and used switches and sliders backed by curl commands, and a modified RESTful sensor by @mad_ady that stores multiple values from a REST call (jsonrest.py) to stitch it together.
And I do mean stitch: it probably isn’t the best way to do it, and sometimes my API requests timeout (unsure if it’s my wifi or not), but it’s a base that someone can build on…
I used a single shell command and build the JSON in the automations, so in future I can make an automation to turn on all bedrooms (for example), and send all zone open requests in the one JSON string, as opposed to multiple requests, which may overwhelm the tablet. Also, consistent naming of sensors/switches/input_number entities is important, as some string replacements are executed to reduce the number of automations required.
So, in configuration.yaml:
shell_command:
myair_setcmd: 'curl -X GET http://192.168.0.97:2025/setAircon?json={{json}}'
- platform: jsonrest
resource: http://192.168.0.97:2025/getSystemData
sensors:
myair_state:
friendly_name: AC State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.info["state"] }}'
myair_fanspeed:
friendly_name: AC Fan Speed
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.info["fan"] }}'
myair_mode:
friendly_name: AC Mode
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.info["mode"] }}'
myair_settemp:
friendly_name: AC Set Temperature
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.info["setTemp"] }}'
myair_zone1_state:
friendly_name: Zone 1 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z01["state"] }}'
myair_zone1_cover:
friendly_name: Zone 1 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z01["value"] }}'
myair_zone2_state:
friendly_name: Zone 2 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z02["state"] }}'
myair_zone2_cover:
friendly_name: Zone 2 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z02["value"] }}'
myair_zone3_state:
friendly_name: Zone 3 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z03["state"] }}'
myair_zone3_cover:
friendly_name: Zone 3 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z03["value"] }}'
myair_zone4_state:
friendly_name: Zone 4 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z04["state"] }}'
myair_zone4_cover:
friendly_name: Zone 4 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z04["value"] }}'
myair_zone5_state:
friendly_name: Zone 5 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z05["state"] }}'
myair_zone5_cover:
friendly_name: Zone 5 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z05["value"] }}'
myair_zone6_state:
friendly_name: Zone 6 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z06["state"] }}'
myair_zone6_cover:
friendly_name: Zone 6 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z06["value"] }}'
myair_zone7_state:
friendly_name: Zone 7 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z07["state"] }}'
myair_zone7_cover:
friendly_name: Zone 7 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z07["value"] }}'
myair_zone8_state:
friendly_name: Zone 8 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z08["state"] }}'
myair_zone8_cover:
friendly_name: Zone 8 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z08["value"] }}'
myair_zone9_state:
friendly_name: Zone 9 A/C Zone State
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z09["state"] }}'
myair_zone9_cover:
friendly_name: Zone 9 A/C Zone Airflow
value_template: '{{ states.sensor.myair.attributes.aircons.ac1.zones.z09["value"] }}'
switch:
- platform: command_line
switches:
myair_power:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22info%22:%7B%22state%22:%22on%22%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22info%22:%7B%22state%22:%22off%22%7D%7D%7D'
command_state: '/bin/true'
value_template: "{{ is_state('sensor.myair_state', 'on') }}"
myair_zone1:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z01%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z01%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone1_state', 'open') }}"
myair_zone2:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z02%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z02%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone2_state', 'open') }}"
myair_zone3:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z03%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z03%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone3_state', 'open') }}"
myair_zone4:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z04%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z04%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone4_state', 'open') }}"
myair_zone5:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z05%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z05%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone5_state', 'open') }}"
myair_zone6:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z06%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z06%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone6_state', 'open') }}"
myair_zone7:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z07%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z07%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone7_state', 'open') }}"
myair_zone8:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z08%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z08%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone8_state', 'open') }}"
myair_zone9:
command_on: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z09%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
command_off: 'curl -X GET http://192.168.0.97:2025/setAircon?json=%7B%22ac1%22:%7B%22zones%22:%7B%22z09%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
value_template: "{{ is_state('sensor.myair_zone9_state', 'open') }}"
input_select:
myair_modeselect:
options:
- cool
- heat
- vent
- dry
icon: mdi:air-conditioner
myair_fanselect:
options:
- low
- medium
- high
icon: mdi:fan
input_number:
myair_inputsettemp:
min: 16
max: 32
unit_of_measurement: ºC
icon: mdi:thermometer
myair_zone1:
name: Zone 1 Airflow
min: 5
max: 100
unit_of_measurement: "%"
step: 5
icon: mdi:fan
myair_zone2:
name: Zone 2 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone3:
name: Zone 3 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone4:
name: Zone 4 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone5:
name: Zone 5 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone6:
name: Zone 6 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone7:
name: Zone 7 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone8:
name: Zone 8 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone9:
name: Zone 9 Airflow
min: 5
max: 100
step: 5
icon: mdi:fan
And the automations to tie it all together (including updating H-A switch/slider states if changes are made using the MyPlace app), automations.yaml:
- id: setmyairmodeselector
alias: Set MyAir Mode Selector
initial_state: True
platform: state
entity_id: sensor.myair_mode
service: input_select.select_option
entity_id: input_select.myair_modeselect
data_template:
option: '{{ states.sensor.myair_mode.state }}'
- id: setmyairacmode
alias: Set MyAir AC mode
initial_state: True
platform: state
service: shell_command.myair_setcmd
data_template:
json: '%7B%22ac1%22:%7B%22info%22:%7B%22mode%22:%22{{ states.input_select.myair_modeselect.state }}%22%7D%7D%7D'
- id: setmyairfanselector
alias: Set MyAir Fan Selector
initial_state: True
platform: state
entity_id: sensor.myair_fanspeed
entity_id: input_select.myair_fanselect
data_template:
option: '{{ states.sensor.myair_fanspeed.state }}'
- id: setmyairacfan
alias: Set MyAir AC fan
initial_state: True
platform: state
data_template:
json: '%7B%22ac1%22:%7B%22info%22:%7B%22fan%22:%22{{ states.input_select.myair_fanselect.state }}%22%7D%7D%7D'
- id: setmyairtempselector
alias: Set MyAir Temp Selector
initial_state: True
platform: state
entity_id: sensor.myair_settemp
service: input_number.set_value
entity_id: input_number.myair_inputsettemp
data_template:
value: '{{ states.sensor.myair_settemp.state }}'
- id: setmyairacTemp
alias: Set MyAir AC Temp
initial_state: True
platform: state
data_template:
json: '%7B%22ac1%22:%7B%22info%22:%7B%22setTemp%22:%22{{ states.input_number.myair_inputsettemp.state }}%22%7D%7D%7D'
- id: setmyairzoneairflow
alias: Set MyAir Zone Airflow
entity_id: input_number.myair_zone1,input_number.myair_zone2,input_number.myair_zone3,input_number.myair_zone4,input_number.myair_zone5,input_number.myair_zone6,input_number.myair_zone7,input_number.myair_zone8,input_number.myair_zone9
platform: state
data_template:
json: '%7B%22ac1%22:%7B%22zones%22:%7B%22{{ trigger.entity_id|replace("input_number.myair_zone","z0") }}%22:%7B%22value%22:%22{{ trigger.to_state.state | int }}%22%7D%7D%7D%7D'
- id: setmyairzoneflowselector
alias: Set MyAir Zone Airflow Selector
entity_id: sensor.myair_zone1_cover,sensor.myair_zone2_cover,sensor.myair_zone3_cover,sensor.myair_zone4_cover,sensor.myair_zone5_cover,sensor.myair_zone6_cover,sensor.myair_zone7_cover,sensor.myair_zone8_cover,sensor.myair_zone9_cover
platform: state
data_template:
entity_id: '{{ trigger.entity_id | replace("sensor.","input_number.") | replace("_cover","") }}'
value: >
{% if trigger.entity_id == "sensor.myair_zone1_cover" %}
{{ states.sensor.myair_zone1_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone2_cover" %}
{{ states.sensor.myair_zone2_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone3_cover" %}
{{ states.sensor.myair_zone3_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone4_cover" %}
{{ states.sensor.myair_zone4_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone5_cover" %}
{{ states.sensor.myair_zone5_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone6_cover" %}
{{ states.sensor.myair_zone6_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone7_cover" %}
{{ states.sensor.myair_zone7_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone8_cover" %}
{{ states.sensor.myair_zone8_cover.state|float }}
{% elif trigger.entity_id == "sensor.myair_zone9_cover" %}
{{ states.sensor.myair_zone9_cover.state|float }}
{% endif %}
This is the base configuration to get it all in to HA, I haven’t hidden sensors, grouped entities into panels, started group automations etc. yet.
As for what it looks like… (blacked out zone names and unrelated sensors)
It seems that the jsonrest example I’m using may no longer be necessary. There’s a way to preserve JSON attributes with the stock RESTful plugin: https://home-assistant.io/components/sensor.rest/#fetch-multiple-json-values-and-present-them-as-attributes
You may want to look into it for future compatibility.
Thanks for sharing. is it also possible to set the turn off timer as well ? (eg- turn off in 30 minutes)
I’m sure it is, I haven’t implemented it though.
Awesome work on getting all that integrated! I’ve only just installed hass and have this same system so looking at something similar. A quick question on your comprehensive solution:
I was under the impression that the system’s airflow was managed automatically based on which zones you had active at any one time, so manually altering this would not be needed?
For my preferred type of use, it would be nice to simplify this down to perhaps a single input select with modes like ‘morning, weekend day, weekday, work from home day, evening, off’ that set all the zones and temperatures accordingly (kind of like manually triggering the ‘Plan’ functionality from the MyAir controller which is primarily how we use the system today). I will certainly have a go at this!
@mad_ady I’ve stopped using jsonrest, and querying the tablet directly from H-A due to timeouts causing all the sensors to go offline then come back. Now I have a script running on my H-A Pi that makes a request every 10s to the tablet and writes the JSON output to a file. My H-A is now using file senors to read the data in.
#!/bin/bash
while [ 1 ];
do
MYAIRDATA=`curl http://192.168.0.97:2025/getSystemData 2>/dev/null`
if [ $MYAIRDATA ];
then
echo $MYAIRDATA > /home/homeassistant/.homeassistant/myair.log
fi
sleep 10
done
@ricochet - airflow may be managed automatically if you have temperature sensors in each zone. My install doesn’t ($100 per zone for the sensor - ridiculous!), so it has one setpoint for the whole system and you can adjust the flow manually. Those Xiaomi Mijia temperature/humidity sensors seem cheap enough so my plan is to investigate integrating a bunch of them and let H-A perform that airflow automation function.
You could certainly set a plan/scene using what I have done as a base - I have two custom switches called “Turn on bedrooms” and “Living zones only”, which turn a group of zones on/off as specified. You can bundle multiple settings in the one API request. For example, the switches
input_boolean:
myair_livingzones:
name: Living zones only
initial: off
icon: mdi:sofa
myair_bedroomzones:
name: Turn on bedrooms
initial: off
icon: mdi:hotel
And the automations they drive:
- id: setmyairlivingzones
alias: Set Living Zones only
initial_state: true
hide_entity: true
entity_id: input_boolean.myair_livingzones
platform: state
to: 'on'
- service: shell_command.myair_setcmd
data_template:
json: '%7B%22ac1%22:%7B%22zones%22:%7B%22z01%22:%7B%22state%22:%22open%22%7D,%22z02%22:%7B%22state%22:%22close%22%7D,%22z03%22:%7B%22state%22:%22open%22%7D,%22z04%22:%7B%22state%22:%22close%22%7D,%22z05%22:%7B%22state%22:%22open%22%7D,%22z06%22:%7B%22state%22:%22close%22%7D,%22z07%22:%7B%22state%22:%22close%22%7D,%22z08%22:%7B%22state%22:%22open%22%7D,%22z09%22:%7B%22state%22:%22close%22%7D%7D%7D%7D'
- service: homeassistant.turn_off
- id: setmyairbedrooms
alias: Set Bedrooms on
initial_state: true
hide_entity: true
entity_id: input_boolean.myair_bedroomzones
platform: state
to: 'on'
data_template:
json: '%7B%22ac1%22:%7B%22zones%22:%7B%22z04%22:%7B%22state%22:%22open%22%7D,%22z06%22:%7B%22state%22:%22open%22%7D,%22z09%22:%7B%22state%22:%22open%22%7D%7D%7D%7D'
Hope this helps!
Perfect - thanks for the extra information, that’s very handy!
Re: temperature sensors, I didn’t even realise they were optional. When we got it quoted for install it wasn’t broken down by component so we did get one per zone as you suggested. $100 each is crazy though, I would have saved the $800 if I knew that!
Cheers
@speedst3r how or where do you run the script in your first step?
#!/bin/bash
while [ 1 ];
do
MYAIRDATA=curl http://192.168.0.97:2025/getSystemData 2>/dev/null
if [ $MYAIRDATA ];
then
fi
sleep 10
done
I run it with cron, on bootup of my RPi. (Running hassbian, script runs as the homeassistant user)
homeassistant@hass:~ $ crontab -l
@reboot /home/homeassistant/get-myair.sh &
Hey @speedst3r
Trying to get what you’ve done working on my newly installed system. Thanks for your work.
I’m getting stuck on the 255 character limit using either the jsonrest or the file method. I see a fair bit of talk about it in other threads and github issues that I’ve found, but haven’t found a solution for it (nor why such a small limit even exists).
How did you get around that issue?
@ShonkyCH, I’m now using file-based sensors - as above, using a bash script with a loop to output the JSON to a file and then reading the values directly into individual sensors…
- platform: file
file_path: /home/homeassistant/.homeassistant/myair.log
value_template: '{{ value_json.aircons.ac1.info["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.info["fan"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.info["mode"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.info["setTemp"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z01["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z01["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z02["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z02["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z03["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z03["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z04["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z04["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z05["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z05["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z06["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z06["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z07["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z07["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z08["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z08["value"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z09["state"] }}'
- platform: file
value_template: '{{ value_json.aircons.ac1.zones.z09["value"] }}'
Thanks. It was trying to parse the whole thing (I think). I have the sensors working including measured temp as I have the individual temperature sensors. It seems the value_json.aircons.ac1.info.setTemp doesn’t apply in that case.
So you need to look at the “value_json.aircons.ac1.info.myZone” and then pick value_json.aircons.ac1.zones.zxx.setTemp based on that.
Whilst the interface is fairly simple, getting all the values switches etc into HA might be a little complicated.
Can I ask what aircons you guys are controlling with this?
I have a Toshiba with the RBC-AMS54E-ES controller and a seperate zone controller.
Had looked at the Intesis wifi controllers but I would have to replace the existing wall controller… so sussing other options, and the MyAir system seems like a winner (if I can find a dealer in SA).
I have a ducted 14kW single phase Panasonic unit connected to a MyAir 5. I had it installed with MyAir straight away along with the individual temperature sensors.
You’ll have to ask your local MyAir installers if they’d be happy to retrofit to your existing system, I’m sure they would though. In terms of sheer compatibility, probably easiest to contact Advantage Air support. I’ve called them on the phone once about some functionality (enabling economy mode, fyi not possible via myair) and they were quite helpful.
We’re still not there on great integration with Home Assistant yet. Aside from the pymyair python library and cli tool (which I hope still works) this commit is the sum total of my work to date on the home assistant integration: https://github.com/smallsam/home-assistant/commit/e346b6e4e339c350a4d3d6c26e65f09dc3ef7977
that I spent time on last year. Too little time to code these days and little motivation as it’s Winter…
I’m not sure if you found the solution for the 255 character limitations. here is what i did:
I have tried above code, but it doesnt look like it’s working. i still get error in my automation jobs saying that we have exceeded character limitations. @dennis-au - did you get this to work in your own myair system ?
Hi All
Interesting reading about the integration of MyAir5 into HA. I’m looking at investing in an Advantage Air solution and potentially picking up the MyPlace solution with integrations into MyAir and MyLight.
I’ve just registered for the forum and keen to start looking at the API.
Great to see lots of interest and passion integrating the solution into HA.
I just thought I’d touch base and see if there is any recent progress with a component for HA from either @smallsam or @speedst3r? Great work guys on your efforts to date!!!
So if it helps anyone, this is my setup for my six zone MyAir system. This is based heavily on the work of @speedst3r with some modifications to get around the REST 255 character limit and so on. *EDIT corrected missing shell_command for Configuration.yaml.
Configuration.yaml:
input_select:
myair_modeselect:
options:
- cool
- heat
- vent
- dry
myair_fanselect:
options:
- low
- medium
- high
icon: mdi:fan
input_number:
myair_inputsettemp:
min: 16
max: 32
step: 1
unit_of_measurement: C
myair_zone1:
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone2:
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone3:
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone4:
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone5:
min: 5
max: 100
step: 5
icon: mdi:fan
myair_zone6:
min: 5
max: 100
step: 5
icon: mdi:fan
# Shell command for air conditioner control
shell_command:
myair_setcmd: 'curl -X GET http://your_unit's_ip_address:2025/setAircon?json={{json}}'
Sensors.yaml:
- platform: rest
resource: http://192.168.0.140:2025/getSystemData
scan_interval: 10
json_attributes:
- aircons
value_template: '{{ value_json.value }}'
sensors:
ac_power:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.info.state }}"
ac_temp:
value_template: "{{ '%.0f'%(states.sensor.ac_json.attributes.aircons.ac1.info.setTemp) | float }}"
ac_mode:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.info.mode }}"
ac_fan:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.info.fan }}"
ac_vent_master_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z01.state }}"
ac_vent_front_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z02.state }}"
ac_vent_middle_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z03.state }}"
ac_vent_rear_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z04.state }}"
ac_vent_theatre_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z05.state }}"
ac_vent_living_state:
value_template: "{{ states.sensor.ac_json.attributes.aircons.ac1.zones.z06.state }}"
Switches.yaml:
switches:
ac_power:
friendly_name: AC Power
value_template: "{{ is_state('sensor.ac_power', 'on') }}"
turn_on:
data_template:
json: '%7B%22ac1%22:%7B%22info%22:%7B%22state%22:%22on%22%7D%7D%7D'
turn_off:
data_template:
json: '%7B%22ac1%22:%7B%22info%22:%7B%22state%22:%22off%22%7D%7D%7D'
Automations.yaml:
initial_state: true
platform: state
entity_id: sensor.ac_mode
data_template:
option: '{{ states.sensor.ac_mode.state }}'
initial_state: true
platform: state
- service: homeassistant.update_entity
data_template:
}}%22%7D%7D%7D'
- delay: 00:00:07
initial_state: true
platform: state
entity_id: sensor.ac_fan
data_template:
option: '{{ states.sensor.ac_fan.state }}'
- id: setmyairacfan
initial_state: true
platform: state
data_template:
}}%22%7D%7D%7D'
- delay: 00:00:07
initial_state: true
platform: state
entity_id: sensor.ac_temp
data_template:
value: '{{ states.sensor.ac_temp.state }}'
initial_state: true
platform: state
data_template:
}}%22%7D%7D%7D'
- delay: 00:00:07
- id: ac_power
alias: AC Power
entity_id: switch.ac_power
platform: state
entity_id: sensor.ac_power
- delay: 00:00:07
It’s taken me some time to get this working and, as others have mentioned, this setup suffers from lag when updating states, however I’m happy to live with this until I can look at doing something better - and that will take some learning. In the meantime, my biggest issue has been locating everything I need in one post so thought I should share.
This is helpful, thanks. Good to see this thread has survived for a while. I have an eZone which is Advantage Air’s entry level platform… I was wondering if it would offer any of the same API capability as their higher end MyAir tools. Not sure yet but i’m keen to have a play around. I’ve set a MAC address reservation for my A/C on my router and I see the output when I navigate to the device on port 2025. Hopefully it’ll take on/off and zone fan speed commands as i’m not trying to do anything fancy!
Edit: Just had a look through the API document on the Advantage Air forum and I managed to switch my AC off and on via the URL using the commands there. This is my first step into a larger world! ![]()
