Have you reconfigured the MQTT integration with discovery ?
Yes, i have this
I don’t have any alarm_contrl_panel from mqtt discovery, so i add one in configuration.yaml of HA :
When I click on armed or disarmed, I can see the status evolving in MQTT but nothing in the logs of the container …
It is as if the MQTT customer of the container does not listen to the topic.
PS : I use Myfox2MQTT docker-container
Can you tell me what I can test or bring as an action on my side to make it work?
Thank you so much
Can you install “MQTT explorer” on you PC and check homeassistant/alarm_control_panel config topic.
Thanks for your help.
I installed MQTT Explorer and here is the result:
I could noticed that the armament of the alarm goes through “armed_away” and nothing happens …
On the other hand, if I push the value “armed” and “disarmed” in the topic myfox2mqtt/22865/command, the alarm activates/deactivates well
And for your topic, i don’t get it …
alarm_control_panel doesn’t exists for me… this is the trouble ?
Have you got an Idea ?
