MyQ 403 Auth Errors after 2023.9
They are probably simply banning IPs (besides looking in these forums to brake the integration after every fix).
I don’t think they’re banning IPs. My Tesla integration works fine through my Wifi, which would be the same IP as HA. (ISP public IP address)
A workaround that worked for me. Just bought a MyQ 819LMB of kijiji for $40 and now have MyQ running local with a newer Yellow triangle and older Purple button Chamberlin garage doors.
Also the chamberlin remotes are dry contact if you want to hook them up to a shelly. You can get control over your doors that way but you would have to add a sensor to the door to know if it is open or close.
The 953ESTD works only with yellow triangle garage door openers but will controll three doors. The 953EV will control three doors from Yellow, Green or purple.
I’m paying the bastages for the monthly fee for our Tesla’s, but I also now fail again to login even after I made the useragent fix a month a go. It failed after last update so I suspect something in HA libraries is doing it.
Please see here for the latest update: The Current State of MyQ - From the codeowner
With all the myq issues I am looking at alternatives, as are many other people. I stumbled upon aqara’s new T2 dual relay, https://www.amazon.com/Aqara-Requires-Contact-Boilers-Supports/dp/B0CC2B8C37
Looks like it supports garage doors, has anyone else tried this?
I know a lot of people are looking at the ratgdo but I personally like options from amazon for the free shipping so any other options that are on amazon I’m open to, TIA!
It should work, but ratgdo offers several advantages for a security 2.0 door: discrete open and close commands, light control, opener door status, solderless install.
With any of the relay options on a security 2.0 door, you will need to solder leads to an opener remote or wall panel controller - just more extra expense. What you end up with is a toggle, not discrete open and close. The toggled door direction can get out of sync with door status, so you need to code accordingly.
Are you able to record a video of how to wire it properly? I know there’s a diagram in the ratgo site, but it’s hard to picture how to wire it
Thanks for the explanation. I wasnt aware ratgdo gave you discretes as well! Will be eyeing this solution!
