There are bugs open to Add config flow for mystrom & Add power sensor for MyStrom. Both are waiting for a review by the same person. The power sensor one has been pending since July 2021, I suspect that means people just use workarounds.
For the MyStrom device, one solution could be to just flash it with Tasmota. For that, you have to open it up (needs a triangle screwdriver), solder a USB-TTL converter, and flash from your computer (it’s doable, but not trivial if you haven’t done it before).
To make it work with the REST API, I used the following in the configuration.yaml:
switch:
- platform: mystrom
host: 192.168.178.199
- platform: rest
resource: http://192.168.178.199/report
method: GET
unit_of_measurement: W
device_class: power
state_class: measurement
value_template: "{{ value_json.power }}"
- platform: integration
source: sensor.mystrom_power1
name: "mystrom Energy Consumption"
unit_prefix: k
round: 3
Note that you have to place them in separate sections - switch & sensor. It checks every 30 seconds.
