Nanit Baby Monitor Integration
i use node-red for my automations (there is a docker palette) - then just use a delay node (with send every hour to trigger)
@jaburges I didn’t realize nodered had a docker integration. That’s a game changer. I appreciate your guidance!
hi! any chance you could share your Node Red flow for restarting the docker container? I find i have to restart the nanit container once every hour or so manually and it would be great to automate this
[{"id":"ad39f89f.c3e3e8","type":"docker-container-actions","z":"649a53f0.e7366c","name":"Restart Nanit","config":"53cf1420.83fa9c","container":"nanit","action":"restart","options":"","x":1714,"y":222,"wires":[[]]},{"id":"3dd4cb7f.b91104","type":"inject","z":"649a53f0.e7366c","name":"every 30 mins","props":[{"p":"payload"}],"repeat":"1800","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":1514.0000457763672,"y":223.0000057220459,"wires":[["ad39f89f.c3e3e8"]]},{"id":"53cf1420.83fa9c","type":"docker-configuration","host":"10.10.10.10","port":"2375"}]
thanks for sharing this! however, i substituted my docker IP, port and container name but keep getting the following error in the debug node:
here’s what my settings look like:
EDIT: I also realised that the port should be 2375 to point to docker.sock but this didn’t work either :frowning:
have you allowed access to the docker.sock remotely?
from memory there is an extra line of code you need to add on the host machine. I can find it if you havent already done that
Ahh that’s probably what I’m missing! No idea what it could be. Would appreciate the assist if you could let me know :blush:
sorry, bud. any chance for that line of code? I can’t seem to figure it out
edit: /lib/systemd/system/docker.service
ExecStart=/usr/bin/docker daemon -H fd:// -H tcp://0.0.0.0:
sudo systemctl daemon-reload
sudo systemctl restart docker.service
thanks! but i actually just ended up using the BigSSH node to just issue a restart docker command over SSH every 30 mins. works like a charm.
Hey everyone, I am so stoked to see this working for yall. I confirmed I am able to stream the cameras through VLC but when I click on the cameras in HomeKit they spin and then say failed to load.
Any ideas? I feel like I am so close!
Ok, so here’s something to keep in mind. Looks like my trick to restart the container once every 30 mins using SSH has resulted in being locked out of the API. Am getting a ā€œconnections above limit errorā€
Anyone know if there’s anything to be done here or am I shit out of luck?
02 Aug 21 05:28 UTC ERR Unable to establish websocket connection error="websocket: bad handshake" url=wss://api.nanit.com/focus/cameras//user_connect
02 Aug 21 05:28 UTC INF Connected to websocket url=wss://api.nanit.com/focus/cameras/xxxxx/user_connect
02 Aug 21 05:28 UTC INF Requesting local streaming target=rtmp://192.168.1.241:1935/local/xxxxx
02 Aug 21 05:28 UTC WRN Failed to request local streaming, awaiting stream health check error="Forbidden: Number of Mobile App connections above limit, declining connection"
02 Aug 21 05:29 UTC INF Authorizing using user credentials [email protected] password=***********
02 Aug 21 05:29 UTC INF Authorized token=fce1****************************************3dc3
02 Aug 21 05:29 UTC ERR Unable to establish websocket connection error="websocket: bad handshake" url=wss://api.nanit.com/focus/cameras//user_connect
Just reduce the frequency that you restart and you should be fine. I have mine restarting every 4 hours (with 2 cameras) and I’ve never run into this issue. You probably just hit a daily or monthly limit.
Ah ok. Must be a monthly limit because I waited 48hrs with the container offline and I’m still getting the same error when trying to spin it up. Hopefully it isn’t a permanent ban!
Anyone have a walk through or how to get started here?
Was it a monthly, I have the exact same problem now :(. Used to work great
Still receiving:
Even after a couple of restarts or stopping the docker for a couple of days…
How is this suddenly an issue, and am I the only one here?
Please help :D.
p.s: The app is working fine on more than 3 devices, but even when those are closed. It still doesn’t work.
I’ve been working on this for hours now and I feel like I’m getting so close but need some help. My Nanit sensors still just say ā€œunknownā€ instead of the actual temperature and humidity readings. Docker logs look good, MQTT logs look good, but I’m missing something. Can anyone help?
Docker:
INF Successfully connected to MQTT broker broker_url=tcp://192.168.1.140:1883
INF Connected to websocket url=wss://api.nanit.com/focus/cameras/N301BKN2118R2V/user_connect
DBG Baby state updated baby_uid=d1ea4bba is_websocket_alive=true
DBG Sending message data="type:REQUEST request:{id:1 type:GET_SENSOR_DATA getSensorData:{all:true}}"
INF Requesting local streaming target=rtmp://192.168.1.191:1935/local/d1ea4bba
DBG Sending message data="type:REQUEST request:{id:2 type:PUT_STREAMING streaming:{id:MOBILE status:STARTED rtmpUrl:\"rtmp://192.168.1.191:1935/local/d1ea4bba\" attempts:1}}"
DBG Received message data="type:RESPONSE response:{requestId:1 requestType:GET_SENSOR_DATA statusCode:200 sensorData:{sensorType:TEMPERATURE isAlert:false timestamp:11627 valueMilli:18041 value:18} sensorData:{sensorType:HUMIDITY isAlert:false timestamp:11627 valueMilli:47298 value:47} sensorData:{sensorType:LIGHT isAlert:false timestamp:11627 valueMilli:357000 value:357} sensorData:{sensorType:NIGHT isAlert:true timestamp:11627 value:0}}"
MQTT HomeAssistant Add-On:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[11:59:36] INFO: Setting up user mqttuser
[11:59:36] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:59:37] INFO: Starting NGINX for authentication handling...
[11:59:38] INFO: Starting mosquitto MQTT broker...
1636739978: mosquitto version 1.6.12 starting
1636739978: |-- *** auth-plug: startup
[11:59:38] INFO: Successfully send discovery information to Home Assistant.
[11:59:39] INFO: Successfully send service information to the Supervisor.
1636739978: Config loaded from /etc/mosquitto/mosquitto.conf.
1636739978: Loading plugin: /usr/share/mosquitto/auth-plug.so
1636739978:  ā”œā”€ā”€ Username/password checking enabled.
1636739978:  ā”œā”€ā”€ TLS-PSK checking enabled.
1636739978:  └── Extended authentication not enabled.
1636739978: Opening ipv4 listen socket on port 1883.
1636739978: Opening ipv6 listen socket on port 1883.
1636739978: Opening websockets listen socket on port 1884.
1636739978: Warning: Mosquitto should not be run as root/administrator.
1636739978: mosquitto version 1.6.12 running
1636740112: New client connected from 192.168.1.191 as Nanit (p2, c0, k30, u'mqttuser').
Hi All,
I’ve tried to read the docs and the thread but I’m a bit confused about using this on tvOS via AirPlay. Is that possible from this docker image? Or do I need an additional docker image to achieve this? Any recommendations if that’s the case? I have RTMP streaming working, just hope to have this on Apple TV.
Thanks so much for the effort on this! Super useful.
Cheers!
Hello all,
I’ve tried to make good sense of this but I’m really struggling, is there any walkthrough for a beginner? This is the main reason I am running HA.
