Native HA Backups - Hanging on Uploading to locations
Yes definitely, I looked everywhere. I could not see any obvious errors in logs. Do you have anywhere you would suggest looking? Especially if I have the issue again.
SUPERVISOR LOGS
2025-07-20 12:09:43.320 INFO (MainThread) [supervisor.backups.manager] Found 5 backup files
2025-07-20 12:09:43.349 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"
2025-07-20 12:09:43.374 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2025-07-20 12:09:43.374 INFO (MainThread) [supervisor.ingress] Loaded 12 ingress sessions
e[32m2025-07-20 12:27:26.614 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-20 12:27:27.411 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)e[0m
e[32m2025-07-20 12:27:57.914 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)e[0m
e[32m2025-07-20 12:27:57.915 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[31m2025-07-20 10:44:01.588 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-241611' coro=<_websocket_forward() done, defined at /usr/src/supervisor/supervisor/api/ingress.py:380> exception=ClientConnectionResetError('Cannot write to closing transport')>
  File "/usr/src/supervisor/supervisor/api/ingress.py", line 387, in _websocket_forward
    await ws_to.send_bytes(msg.data)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client_ws.py", line 252, in send_bytes
    await self._writer.send_frame(data, WSMsgType.BINARY, compress=compress)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/_websocket/writer.py", line 72, in send_frame
    raise ClientConnectionResetError("Cannot write to closing transport")
aiohttp.client_exceptions.ClientConnectionResetError: Cannot write to closing transporte[0m
e[32m2025-07-20 11:00:05.356 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-07-20 04:01:46.256 INFO (MainThread) [supervisor.api.backups] Downloading backup 6b5735bbe[0m
e[32m2025-07-20 04:01:48.613 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[31m2025-07-20 04:01:48.646 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-20 04:03:29.415 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[31m2025-07-19 08:01:48.587 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[33m2025-07-19 03:08:00.026 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c454e10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-19 03:08:05.037 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c4565d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-19 03:08:10.041 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff7c454050>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
[32m2025-07-18 08:14:07.128 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-07-18 08:14:07.129 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-07-18 08:14:07.810 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-18 08:14:07.810 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-07-18 08:14:07.811 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-07-18 08:17:29.944 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[33m2025-07-18 08:27:48.923 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.737 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.870 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.871 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.872 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.873 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.875 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:48.876 WARNING (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Error WebSocket message received while proxying: ServerTimeoutError('No PONG received after 15.0 seconds')e[0m
e[33m2025-07-18 08:27:49.525 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missed an Home Assistant Core API response.e[0m
e[32m2025-07-18 08:27:54.681 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.790 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.791 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.793 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.794 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.796 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.800 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[32m2025-07-18 08:27:54.801 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_vscode] Home Assistant WebSocket API closede[0m
e[33m2025-07-18 08:27:54.831 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!e[0m
e[32m2025-07-18 08:27:55.591 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_observer applicatione[0m
e[32m2025-07-18 08:27:57.533 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_observer applicatione[0m
e[32m2025-07-18 08:27:57.785 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugine[0m
e[32m2025-07-18 08:27:59.030 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0 - 172.30.32.6e[0m
e[32m2025-07-18 08:28:04.617 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.696 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.709 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.721 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.727 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.736 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.740 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-18 08:28:04.832 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[22:33:07] INFO: e[32mUsing udev information from hoste[0m
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[22:33:07] INFO: e[32mStarting local supervisor watchdog...e[0m
s6-rc: info: service legacy-services successfully started
e[32m2025-07-17 22:33:10.233 INFO (MainThread) [__main__] Initializing Supervisor setupe[0m
e[32m2025-07-16 18:12:25.306 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0 - 172.30.32.6e[0m
e[31m2025-07-16 18:12:25.779 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/states/binary_sensor.backups_stale: [Errno None] Can not write request body for http://172.30.32.1:8123/api/states/binary_sensor.backups_stalee[0m
e[31m2025-07-16 18:12:25.780 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.backups_stalee[0m
e[32m2025-07-16 18:12:25.807 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[31m2025-07-16 18:12:25.850 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.33.3
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/integrations/aiohttp.py", line 157, in sentry_app_handle
    reraise(*_capture_exception())
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/utils.py", line 1746, in reraise
    raise value
  File "/usr/local/lib/python3.13/site-packages/sentry_sdk/integrations/aiohttp.py", line 140, in sentry_app_handle
    response = await old_handle(self, request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 198, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 208, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 225, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 289, in core_proxy
  File "/usr/src/supervisor/supervisor/api/proxy.py", line 227, in websocket
    await server.prepare(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_ws.py", line 214, in prepare
    protocol, writer = self._pre_start(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_ws.py", line 317, in _pre_start
    assert transport is not None
AssertionErrore[0m
e[32m2025-07-16 14:15:41.367 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-16 14:15:41.388 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-16 14:15:50.194 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-07-15 18:13:33.589 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-15 18:13:33.613 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-15 18:13:33.629 INFO (MainThread) [supervisor.discovery] Loaded 1 messagese[0m
e[31m2025-07-15 08:17:28.547 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[31m2025-07-13 16:17:28.438 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[33m2025-07-12 21:23:17.872 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954af390>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:23:22.877 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954af750>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:23:27.882 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954aee90>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:24:17.162 INFO (MainThread) [supervisor.host.info] Updating local host informatione[0m
e[33m2025-07-12 21:24:17.873 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954afb10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:24:17.937 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2025-07-12 21:24:17.951 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2025-07-12 21:24:18.149 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[32m2025-07-12 21:24:18.160 INFO (MainThread) [supervisor.host.manager] Host information reload completede[0m
e[33m2025-07-12 21:24:22.878 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ada90>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:24:27.883 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:17:42.553 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connectione[0m
e[33m2025-07-12 21:17:52.679 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connectione[0m
e[31m2025-07-12 21:17:52.681 ERROR (MainThread) [supervisor.store] Could not reload repository 69755fa6 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[31m2025-07-12 21:17:52.682 ERROR (MainThread) [supervisor.store] Could not reload repository 8bce8ef4 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[31m2025-07-12 21:17:52.682 ERROR (MainThread) [supervisor.store] Could not reload repository 68e874ae due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")e[0m
e[33m2025-07-12 21:18:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:15:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa1b42c10>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 21:15:22.876 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ae0d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:15:24.026 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-07-12 21:15:24.026 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[33m2025-07-12 21:15:27.878 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ad6d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2025-07-12 21:15:30.680 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2025-07-12 21:15:30.681 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-07-12 21:15:30.682 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2025-07-12 21:15:30.687 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2025-07-12 21:15:30.687 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connectione[0m
e[32m2025-07-12 21:15:30.688 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2025-07-12 21:15:30.700 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-07-12 21:15:30.700 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-07-12 21:15:30.991 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-12 21:15:30.993 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-07-12 21:15:30.993 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[33m2025-07-12 21:16:17.871 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[32m2025-07-12 20:15:24.013 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-07-12 20:17:28.361 INFO (MainThread) [supervisor.backups.manager] Found 4 backup filese[0m
e[31m2025-07-12 20:17:28.380 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/31e48303.tar: "filename './backup.json' not found"e[0m
e[32m2025-07-12 20:17:36.473 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-07-12 20:17:38.392 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backupe[0m
e[32m2025-07-12 20:17:38.399 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backupe[0m
e[33m2025-07-12 20:28:17.865 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:28:22.881 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0xffff954ae0d0>: Failed to resolve 'o427061.ingest.sentry.io' ([Errno -3] Try again)")': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:28:52.889 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0xffff954ad1d0>, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=30)')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:18.558 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954aec10>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:21.626 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954ae490>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:29:24.698 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954aed50>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:16.926 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aef4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:19.995 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:30:23.067 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf250>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:15.291 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf250>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:21.435 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa6aaf4d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[33m2025-07-12 20:31:27.579 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff954afc50>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
e[32m2025-07-12 20:31:49.409 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_d5369777_music_assistant applicatione[0m
e[32m2025-07-12 20:31:49.599 INFO (MainThread) [supervisor.api.proxy] [d5369777_music_assistant] Home Assistant WebSocket API closede[0m
e[32m2025-07-12 20:31:59.979 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_d5369777_music_assistant applicatione[0m
e[32m2025-07-12 20:32:00.576 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/music-assistant/server with version 2.5.5e[0m
e[33m2025-07-12 20:32:07.232 WARNING (MainThread) [supervisor.api.middleware.security] No API token provided for /coree[0m
e[32m2025-07-12 20:32:12.570 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-12 20:32:12.579 INFO (MainThread) [supervisor.api.proxy] WebSocket access from d5369777_music_assistante[0m
e[32m2025-07-12 20:32:12.588 INFO (MainThread) [supervisor.api.proxy] [d5369777_music_assistant] Home Assistant WebSocket API proxy runninge[0m
e[33m2025-07-12 20:32:19.803 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffffa1b425d0>: Failed to establish a new connection: [Errno 113] Host is unreachable')': /api/5370612/envelope/e[0m
DNS LOGS
[INFO] 127.0.0.1:59703 - 35077 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000150383s
[INFO] 127.0.0.1:57909 - 43259 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000144716s
[INFO] 172.30.32.1:42435 - 21465 "A IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.008798613s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. A: read udp 127.0.0.1:38812->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:35244 - 10851 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000282556s
[INFO] 172.30.32.1:42435 - 22173 "AAAA IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.013432014s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. AAAA: read udp 127.0.0.1:60488->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:44335 - 10334 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000200635s
[INFO] 127.0.0.1:43211 - 52908 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000133298s
[INFO] 172.30.32.1:42435 - 21465 "A IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.006838926s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. A: read udp 127.0.0.1:56302->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.1:42435 - 22173 "AAAA IN ap-southeast-1-0.ui.nabu.casa. udp 47 false 512" - - 0 12.006912347s
[ERROR] plugin/errors: 2 ap-southeast-1-0.ui.nabu.casa. AAAA: read udp 127.0.0.1:39452->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.2:35647 - 9759 "A IN o427061.ingest.sentry.io. udp 42 false 512" - - 0 12.006458804s
[ERROR] plugin/errors: 2 o427061.ingest.sentry.io. A: read udp 127.0.0.1:40406->127.0.0.1:5553: i/o timeout
