I would like to know if it’s possible to define sources for the android TV component so that I can load an app directly from the source dropdown list ? (I don’t have the FireTV, for which it seems to be possible)
I haven’t seen any post/documentation about that, and since I don’t know how the media player sources really work, I don’t know if it’s possible.
Thank you!
Hello guys. I have a AndroidTV box with tuner for watching TV ( T2&S2 ). Everything goes OK but, have a little problem with the state of app ATV7 (com.pineone.sb), when i open it to watch the tv, in the state i have Live TV ‘paused’, and when i turn off the box, in the state have Live TV ‘playing’.
Can i inverted this role?
This is my basic conficuration:
media_player:
# Use the Python ADB implementation
- platform: androidtv
host: 192.168.1.167
device_class: androidtv
apps:
com.google.android.leanbacklauncher: "Android Home"
com.pineone.sb: "Live TV"
and this is the adb response when i call GET_PROPERTIES
Output of command 'GET_PROPERTIES' from 'media_player.android_tv': {'screen_on': True, 'awake': True, 'audio_state': 'idle', 'wake_lock_size': 1, 'current_app': 'com.pineone.sb', 'media_session_state': None, 'device': 'hdmi', 'is_volume_muted': False, 'volume': 9}
TV OFF
TV ON
Greetings
Solved.
I also gave the GET_PROPERTIES command with the TV turned off and I saw that it signaled a wake_lock_size different from the one before, so I tried to configure it like this.
media_player:
host: 192.168.1.167
apps:
state_detection_rules:
'com.pineone.sb':
- 'playing':
'wake_lock_size': 1
- 'standby':
'wake_lock_size': 2
Can someone please point me to a more detailed tutorial on how to get the most out of this component? I’m looking for more detailed info on how to control specific apps and the general behaviour.
Thanks!
You can make automations using template trigger like:
- alias: "Netflix automation"
value_template: "{% if is_state('media_player.android_tv', 'playing') and is_state_attr('media_player.android_tv', 'app_name', 'Netflix') %}true{% endif %}"
I had to restore my Hassio and now I keep getting the " androidtv/adb_command. Service not found."
My button in lovelace is coded as follows:
- type: custom:card-modder
card:
type: entity-button
icon: mdi:arrow-left-bold
entity: media_player.shield
hold_action: none
tap_action:
action: call-service
service: androidtv.adb_command
service_data:
entity_id: media_player.shield
command: LEFT
style:
I got the androidtv from ha-androidtv-master folder in my custom_component
Not sure what is causing this, I had this issue before but don’t remember how I ended up fixing it.
It looks like the androidTV component got updated recently. I now have a list of apps as sources in my media player entity. I really love this feature !
However, is there a way to customize the list of apps appearing here ? Most of them are running processes that I don’t need to see.
Edit:
If I may add another suggestion: the AndroidTV component should be able to expose the sources (app list) even if the player is in standby mode, just like the PS4 component, so that one could launch an app in just 1 click!
Thanks !
I added the ones I needed in the app: list but I am still seeing all the other sources as well. I thought if I turned off get_sources it would only show the ones I mapped but that was not the case, with get_sources: false I get nothing.
The app
option is only here to give a friendly name for the package / processes.
For instance replace com.plexapp.android
by Plex
But it is not used to generate the app/source list.
Is it possible to turn on android TV using media control component?
Yes
Does anyone know how to control the Android TV (Xiaomi Mi Box S specifically) through ip/tcp and/or Bluetooth? I cannot use the ADB because of the restrictions in combination with the USB port (with an ethernet adapter)
I thought my google skills were on point, but I am having a hard time finding the network api, while there are some Android apps that do control it over the network.
nmap shows some open ports:
Nmap scan report for xxx.xxx.xxx.xxx
Host is up (0.0011s latency).
Not shown: 994 closed ports
PORT STATE SERVICE
8008/tcp open http
8009/tcp open ajp13
8080/tcp open http-proxy
8443/tcp open https-alt
9000/tcp open cslistener
9090/tcp open zeus-admin
Where 8008 and 8009 seem to be for the build-in Chromecast (according to google)
How? I am only able to turn off. But after that the entity becomes unavailable. So i am not able to turn on
Hi, api was finnaly able to get this working whit both the adb python and adb server options. The component works just but there is a huge delay at any interaction (pause, launch apps, recovery states…) like a good 5 to 7 seconds
I have other media players added from the same tv and the actions are instant. Is this a specific adb problem? Any way to fix it ?
Is this delay present with both the Python ADB and ADB server configurations? Is one approach faster than the other?
Now I see where you’re getting…
AndroidTV has problems on some devices, that aren’t able to handle wake-on-lan. In my case the tv component (Sony Bravia with PSK) takes this into account.
My only idea would be to set up a wakelock. Not ideal, but better than nothing.
Yes. I did more testing and the delay (5-9 seconds) is present on everything related whit the media player (update device status, play/pause, switch sources, volumen up/down/mute).
The delay is there interacting whit the media players cards or calling one of the media player functions whit services
I can confirm that sending anything whit the adb_command is instant. Also i cant see a diference of speed whit python adb or server adb because the delay is not always consistent ( goes from sometimes 3 seconds to 9 seconds).
How the ‘“select source” service launch the apps? If i try to open netflix from the sources takes like 3 to 5 seconds, whit adb command -> am start -n com.netflix.ninja/.MainActivity is instant
Also, i have just tried this beta version https://github.com/JeffLIrion/ha-androidtv whit unfortunately the same results
@Sxkre, How would I go about sending commands via adb instead of the regular way, which are awfully slow? Also, anyway to merge this with Google Cast integration card, and pull the metadata?
Go to services —> androidtv.adb _command. For netflix the example is am start -n com.netflix.ninja/.MainActivity
I find the package name to launch whit this ( u need to adb shell on your tv first)—> dumpsys package | grep hbo | grep Activity (change hbo for the app name and a couple of process will show up. Just try one of them whit am start -n and the app will launch
Hi, I’m using below code in a glance card configured to open app with tap_action
and close the app with hold_action
type: glance
entities:
- entity: script.start_netflix
icon: 'mdi:netflix'
tap_action:
service: script.start_netflix
hold_action:
service: script.stop_netflix
- entity: script.start_primevideo
icon: 'mdi:amazon'
tap_action:
service: script.start_primevideo
hold_action:
service: script.stop_primevideo
- entity: script.start_playmusic
icon: 'mdi:play-circle-outline'
tap_action:
service: script.start_playmusic
hold_action:
service: script.stop_playmusic
show_name: false
show_state: false
columns: 3
my script
start_netflix:
sequence:
- data:
entity_id: media_player.android_tv
source: com.netflix.ninja
service: media_player.select_source
alias: Start Netflix
stop_netflix:
sequence:
- data:
source: '!com.netflix.ninja'
alias: Stop Netflix
start_primevideo:
sequence:
- data:
source: com.amazon.amazonvideo.livingroom
alias: Start Prime Video
stop_primevideo:
sequence:
- data:
source: '!com.amazon.amazonvideo.livingroom'
alias: Stop Prime Video
start_playmusic:
sequence:
- data:
source: com.google.android.music
alias: Start Play Music
stop_playmusic:
sequence:
- data:
source: '!com.google.android.music'
alias: Stop Play Music
Netflix is working fine, but Amazon Prime Video and Google play music is just closing, but not opening.
One more thing, how can I use the hold action in original remote to get more options like context menu when I press the middle enter button?
