I am not sure what I did - but i was able to get this to work, so please disregard.
I am trying to make media_player
entity by standard androidtv
integration
media_player:
- platform: androidtv
host: 192.168.1.71
But I am unable to get media_player.samsung_tablet
entity.
Any hints?
What do you have in your logs ?
[13:57:47] INFO: Starting the Android Debug Bridge server...
[13:57:48] INFO: Connecting to device: 192.168.1.71...
unable to connect to 192.168.1.71:5555: Connection refused
And why on port 5555? In configuration I do have:
What did you put in you config.yaml for the android tv platform ?
media_player:
host: 192.168.1.71
adb_server_ip: 127.0.0.1
adb_server_port: 5037
host: 192.168.1.72
(of course both devices do have Connection refused
error)
USB debugging activated and key confirmed?
Activated on both. Also ports opened on routers (most probably completely unnecessarily).
But… what key?
You have to accept the connection between your hassio instance and your android device.
Please try :
- revoke all debug authorizations on your android device (developer mode)
- restart your android devices
- restart HASSIO
- when hassio is restarted, you should have a confirmation on your android devices to accept the connection.
Done. No confirmation on Android.
But still, isn’t it important that:
- it is trying to connect on port 5555 and
- what is most mystic to me, that I have no entity
media_player.tablet_a
And in the addon config ? Can you show us ?
Are you sure about the IPs ? Are they fixed ?
100%
And I see them on router as active
Can you manage to connect through ADB ? I mean with a cmd line and the ADB debug tool (outside of hassio) ?
You can try with adb tool (https://forum.xda-developers.com/attachment.php?attachmentid=4623157&d=1540039037) and the cmd : adb connect 192.168.1.71
after first execution adb connect 192.168.1.71
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
second
empty host name
third
Ping
but no RSA key
The integration should have generated one for you. Did you already have a key ?
Could you please tell me in which step I should get it?
