Just got the CCGTV couple days ago - itās my first Android TV device. Do you need to do the ADB enabling stuff and then enable it using the standard āandroidtvā integration? Thanks.
Once you restart homeassistant after adding androidtv integration to your config, you should see pop on your android tv to allow adb connection just accept it and you should be good along with above minor change.
Hi @sacdroid Could you please let me know exactly what you did to get Chromecast with Google TV reporting status correctly? How do I update the androidtv component to 0.51 to support the new chromecast? How do I make the necessary changes to have the new chromecast device report playback status correctly?
You can set anything with intents. Just as an example: go to developer tools -> services and start playing with the newly created mediplayer. You could, for example, turn on or off the television or run more complex things like playing the latest episode of Desperate Housewives.
Hi there,
Iām using my nvidia shield as a media player (native android component). If I start youtube it shows the cover art all fine. However prime video only gives me a black backgroundā¦it seems like it is not fetching the imageā¦
Is this a kown issue with the amazon prime video app?
If anybodyās interested, if youāre not using HassOS (i.e. Container) and need an adb server container, I found a modified adb image based on the add-on, by peexl, source. Unfortunately, this is only for amd64. I modified it for armhf so it can be used on raspberry pi. Use tag armhf. Source is here. Image is here.
Hello, this is my first post, but Iām reading this forum since christmas, as this is the day when I started my Raspberry Pi and Home Assistant adventure. My main goal is to automate my cave equipment for wife to handle
I managed with Onkyo amplifier, Optoma projector, Tuya and sonoff light switches ā¦ but stuck with Nvidia shield. I can use shield.kodi or shield.chromecast integrations, but they have limited possibilities. Iām trying to use androidtv integration, but shield entity is not showing. No mater I use ADB server integration or Python ADB approach.
Here is my configuration.yaml, please advice. ADB in Shield enabled, message accepted, static IP set, device restarted multiple times.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ADB - Android Debug Bridge
The Android Debug Bridge server program
Add-on version: 0.7.0
You are running the latest version of this add-on.
System: Home Assistant OS 5.10 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.1.5
Home Assistant Supervisor: 2021.01.7
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to DEBUG
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adb.sh: executing...
[cont-init.d] adb.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:24:53] INFO: Starting the Android Debug Bridge server...
[21:24:54] INFO: Connecting to device: 10.0.0.2...
connected to 10.0.0.2:5555
[21:26:24] INFO: Connecting to device: 10.0.0.2...
already connected to 10.0.0.2:5555
[21:27:55] INFO: Connecting to device: 10.0.0.2...
Hi! Did you find any solution to Amazon Prime Video and Google play music only close, but not open? I have the same issue with an app called Viaplay (com.viaplay.android)
