my file is now at: /config/custom_components/androidtv/media_player.py
Still getting this error: Platform not found: media_player.androidtv
You might need to add an empty file in the androidtv directory named __init__.py
The other error is due to imports changing. This line from homeassistant.components.media_player import (
needs to become from homeassistant.components.media_player.const import (
Didn’t help…
Tried all the same, upgraded to .88 made the changes pier and fahr suggested and getting the device offline error still. I even tried the suggestion made way further back by Kyle: Native support for Android TV / Android devices
Still getting this error, any help would be appreciated:
2019-02-21 17:40:10 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform androidtv
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 416, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/androidtv/media_player.py”, line 196, in setup_platform
adb_server_port=config[CONF_ADB_SERVER_PORT])
File “/config/deps/lib/python3.7/site-packages/androidtv/init.py”, line 230, in init
self.properties = self.device_info()
File “/config/deps/lib/python3.7/site-packages/androidtv/init.py”, line 325, in device_info
properties = self._adb_shell(‘getprop’)
File “/config/deps/lib/python3.7/site-packages/androidtv/init.py”, line 479, in _adb_shell_pure_python_adb
return self._adb_device.shell(cmd)
File “/config/deps/lib/python3.7/site-packages/adb_messenger/command/transport/init.py”, line 20, in shell
conn = self.create_connection(timeout=timeout)
File “/config/deps/lib/python3.7/site-packages/adb_messenger/device.py”, line 45, in create_connection
self.transport(conn)
File “/config/deps/lib/python3.7/site-packages/adb_messenger/command/transport/init.py”, line 15, in transport
connection.send(cmd)
File “/config/deps/lib/python3.7/site-packages/adb_messenger/connection.py”, line 77, in send
return self._check_status()
File “/config/deps/lib/python3.7/site-packages/adb_messenger/connection.py”, line 83, in _check_status
raise RuntimeError(“ERROR: {} {}”.format(repr(recv), error))
RuntimeError: ERROR: ‘FAIL’ 000edevice offline
So I did the changes that fahr mentioned but with the following file setup: /config/custom_components/media_player/androidtv.py
Now I get this error: Package androidtv setup failed. Component media_player cannot be merged. Expected a dict.
I did all of the changes above, but it wasn’t until I deleted the deps folder and rebooted 2 or 3 times to compiled new deps that it started working.
Did you delete the deps folder each time you restarted?
I’m still getting the following error:
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/config/custom_components/androidtv/media_player.py", line 183, in setup_platform
atv = AndroidTV(host, adbkey)
File "/config/deps/lib/python3.7/site-packages/androidtv/__init__.py", line 249, in __init__
File "/config/deps/lib/python3.7/site-packages/androidtv/__init__.py", line 446, in device_info
wifi_out = self.adb_shell('ip addr show wlan0')
File "/config/deps/lib/python3.7/site-packages/androidtv/__init__.py", line 262, in _adb_shell_python_adb
return self._adb.Shell(cmd)
File "/usr/local/lib/python3.7/site-packages/adb/adb_commands.py", line 376, in Shell
timeout_ms=timeout_ms)
File "/usr/local/lib/python3.7/site-packages/adb/adb_protocol.py", line 411, in Command
return ''.join(cls.StreamingCommand(usb, service, command, timeout_ms))
File "/usr/local/lib/python3.7/site-packages/adb/adb_protocol.py", line 439, in StreamingCommand
for data in connection.ReadUntilClose():
AttributeError: 'NoneType' object has no attribute 'ReadUntilClose'
I only deleted the folder once after updating the custom component for 88 described above.
Yeah I keep getting that same error Platform not found: media_player.androidtv no matter what I do…
This is how your media_player.py (former androidtv.py) should look to work.
(Some changes from line 33 and forward)
Provide functionality to interact with AndroidTv devices on the network.
Example config using an external ADB server:
media_player:
- platform: androidtv
host: 192.168.1.37
adb_server_ip: 127.0.0.1
adb_server_port: 5037
apps:
"amazon": "Amazon Premium Video"
Example config using purely Python:
media_player:
host: 192.168.1.37
adbkey: /config/adbkey
apps:
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/media_player.androidtv/
import logging
import functools
import os
import threading
import voluptuous as vol
from homeassistant.components.media_player import ( DOMAIN,
MediaPlayerDevice, PLATFORM_SCHEMA)
SUPPORT_NEXT_TRACK, SUPPORT_PAUSE, SUPPORT_PLAY,
SUPPORT_PREVIOUS_TRACK, SUPPORT_STOP, SUPPORT_TURN_OFF,
SUPPORT_TURN_ON, SUPPORT_VOLUME_MUTE, SUPPORT_VOLUME_STEP)
from homeassistant.const import (
ATTR_ENTITY_ID, CONF_HOST, CONF_NAME, CONF_PORT,
STATE_IDLE, STATE_PAUSED, STATE_PLAYING, STATE_OFF)
from homeassistant.exceptions import PlatformNotReady
from homeassistant.helpers import device_registry as dr
import homeassistant.helpers.config_validation as cv
REQUIREMENTS = ['androidtv==0.0.7']
_LOGGER = logging.getLogger(__name__)
CONF_APPS = 'apps'
CONF_ADBKEY = 'adbkey'
CONF_ADB_SERVER_IP = 'adb_server_ip'
CONF_ADB_SERVER_PORT = 'adb_server_port'
DEFAULT_APPS = {}
DEFAULT_ADBKEY = os.path.join(os.path.expanduser('~'), '.android', 'adbkey')
DEFAULT_NAME = 'Android'
DEFAULT_PORT = '5555'
DEFAULT_ADB_SERVER_PORT = 5037
def has_adb_files(value):
"""Check that ADB key files exist."""
priv_key = value
pub_key = '{}.pub'.format(value)
cv.isfile(pub_key)
return cv.isfile(priv_key)
ACTIONS = {
"back": "4",
"blue": "186",
"component1": "249",
"component2": "250",
"composite1": "247",
"composite2": "248",
"down": "20",
"end": "123",
"enter": "66",
"green": "184",
"hdmi1": "243",
"hdmi2": "244",
"hdmi3": "245",
"hdmi4": "246",
"home": "3",
"input": "178",
"left": "21",
"menu": "82",
"move_home": "122",
"mute": "164",
"pairing": "225",
"power": "26",
"resume": "224",
"right": "22",
"sat": "237",
"search": "84",
"settings": "176",
"sleep": "223",
"suspend": "276",
"sysdown": "281",
"sysleft": "282",
"sysright": "283",
"sysup": "280",
"text": "233",
"top": "122",
"up": "19",
"vga": "251",
"voldown": "25",
"volup": "24",
"yellow": "185"
KNOWN_APPS = {
"amazon": "Amazon Prime Video",
"dream": "Screensaver",
"kodi": "Kodi",
"netflix": "Netflix",
"plex": "Plex",
"spotify": "Spotify",
"tvlauncher": "Homescreen",
"youtube": "Youtube",
"zatto": "Zattoo"
SUPPORT_ANDROIDTV = (SUPPORT_NEXT_TRACK | SUPPORT_PAUSE |
SUPPORT_PLAY | SUPPORT_PREVIOUS_TRACK |
SUPPORT_TURN_OFF | SUPPORT_TURN_ON |
SUPPORT_VOLUME_MUTE | SUPPORT_VOLUME_STEP |
SUPPORT_STOP)
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_HOST): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_PORT, default=DEFAULT_PORT): vol.All(cv.port, cv.string),
vol.Optional(CONF_ADBKEY): has_adb_files,
vol.Optional(CONF_APPS, default=DEFAULT_APPS): dict,
vol.Optional(CONF_ADB_SERVER_IP): cv.string,
vol.Optional(
CONF_ADB_SERVER_PORT, default=DEFAULT_ADB_SERVER_PORT): cv.port
ACTION_SERVICE = 'androidtv_action'
INTENT_SERVICE = 'androidtv_intent'
KEY_SERVICE = 'androidtv_key'
SERVICE_ACTION_SCHEMA = vol.Schema({
vol.Required(ATTR_ENTITY_ID): cv.entity_ids,
vol.Required('action'): vol.In(ACTIONS),
SERVICE_INTENT_SCHEMA = vol.Schema({
vol.Required('intent'): cv.string,
SERVICE_KEY_SCHEMA = vol.Schema({
vol.Required('key'): cv.string,
DATA_KEY = '{}.androidtv'.format(DOMAIN)
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the androidtv platform."""
from androidtv import AndroidTV
if DATA_KEY not in hass.data:
hass.data[DATA_KEY] = {}
host = '{0}:{1}'.format(config[CONF_HOST], config[CONF_PORT])
name = config.get(CONF_NAME)
if CONF_ADB_SERVER_IP not in config:
atv = AndroidTV(host)
if not atv.available:
# "python-adb" with adbkey
if CONF_ADBKEY in config:
adbkey = config[CONF_ADBKEY]
else:
adbkey = DEFAULT_ADBKEY
adb_log = " using adbkey='{0}'".format(adbkey)
else:
adb_log = ""
else:
# "pure-python-adb"
atv = AndroidTV(
host,
adb_server_ip=config[CONF_ADB_SERVER_IP],
adb_log = " using ADB server at {0}:{1}".format(
config[CONF_ADB_SERVER_IP], config[CONF_ADB_SERVER_PORT])
_LOGGER.warning(
"Could not connect to Android TV at %s%s", host, adb_log)
raise PlatformNotReady
if host in hass.data[DATA_KEY]:
_LOGGER.warning("Platform already setup on %s, skipping.", host)
else:
device = AndroidTVDevice(atv, name, config[CONF_APPS])
add_entities([device])
_LOGGER.info("Setup Android TV at %s%s", host, adb_log)
hass.data[DATA_KEY][host] = device
def service_action(service):
"""Dispatch service calls to target entities."""
params = {key: value for key, value in service.data.items()
if key != ATTR_ENTITY_ID}
entity_id = service.data.get(ATTR_ENTITY_ID)
target_devices = [dev for dev in hass.data[DATA_KEY].values()
if dev.entity_id in entity_id]
for target_device in target_devices:
target_device.do_action(params['action'])
def service_intent(service):
target_device.start_intent(params['intent'])
def service_key(service):
target_device.input_key(params['key'])
hass.services.register(
DOMAIN, ACTION_SERVICE, service_action, schema=SERVICE_ACTION_SCHEMA)
DOMAIN, INTENT_SERVICE, service_intent, schema=SERVICE_INTENT_SCHEMA)
DOMAIN, KEY_SERVICE, service_key, schema=SERVICE_KEY_SCHEMA)
def adb_decorator(override_available=False):
"""Send an ADB command if the device is available and not locked."""
def adb_wrapper(func):
"""Wait if previous ADB commands haven't finished."""
@functools.wraps(func)
def _adb_wrapper(self, *args, **kwargs):
# If the device is unavailable, don't do anything
if not self.available and not override_available:
return None
# "python-adb"
if not self.androidtv.adb_server_ip:
# If an ADB command is already running, skip this command
if not self.adb_lock.acquire(blocking=False):
_LOGGER.info('Skipping an ADB command because a previous '
'command is still running')
return None
# More ADB commands will be prevented while trying this one
try:
returns = func(self, *args, **kwargs)
except self.exceptions:
_LOGGER.error('Failed to execute an ADB command;'
' will attempt to re-establish the ADB'
' connection in the next update')
returns = None
_LOGGER.warning(
"Device %s became unavailable.", self._name)
self._available = False # pylint: disable=protected-access
finally:
self.adb_lock.release()
# "pure-python-adb"
else:
try:
returns = None
_LOGGER.warning(
return returns
return _adb_wrapper
return adb_wrapper
class AndroidTVDevice(MediaPlayerDevice):
"""Representation of an Android TV device."""
def __init__(self, atv, name, apps):
"""Initialize the Android TV device."""
self.androidtv = atv
self._name = name
self._apps = KNOWN_APPS
self._apps.update(dict(apps))
self._app_name = None
self._state = None
self._muted = None
self._available = self.androidtv.available
self._properties = self.androidtv.properties
self._unique_id = 'androitv-{}-{}'.format(
name, self._properties['serialno'])
# whether or not the ADB connection is currently in use
self.adb_lock = threading.Lock()
# ADB exceptions to catch
# "python-adb"
from adb.adb_protocol import (
InvalidChecksumError, InvalidCommandError,
InvalidResponseError)
from adb.usb_exceptions import TcpTimeoutException
self.exceptions = (AttributeError, BrokenPipeError, TypeError,
ValueError, InvalidChecksumError,
InvalidCommandError, InvalidResponseError,
TcpTimeoutException)
else:
# "pure-python-adb"
self.exceptions = (ConnectionResetError,)
@adb_decorator(override_available=True)
def update(self):
"""Update the states of the device."""
# Check if device is disconnected.
if not self._available:
# Try to connect
self._available = self.androidtv.connect()
if self._available:
_LOGGER.info("Device %s reconnected.", self._name)
# If the ADB connection is not intact, don't update.
return
success = self.androidtv.update()
if not success:
_LOGGER.warning(
return
self._app_name = self.get_app_name(self.androidtv.app_id)
if self.androidtv.state == 'off':
self._state = STATE_OFF
elif self.androidtv.state == 'idle':
self._state = STATE_IDLE
elif self.androidtv.state == 'playing':
self._state = STATE_PLAYING
elif self.androidtv.state == 'paused':
self._state = STATE_PAUSED
def get_app_name(self, app_id):
"""Return the app name from its id and known apps."""
if app_id is None:
return None
for app in self._apps:
if app in app_id['package']:
app_name = self._apps[app]
break
else:
app_name = None
return app_name
@property
def name(self):
"""Return the name of the device."""
return self._name
@property
def state(self):
"""Return the state of the device."""
return self._state
@property
def is_volume_muted(self):
"""Boolean if volume is currently muted."""
return self.androidtv.muted
@property
def volume_level(self):
"""Return the volume level."""
return self.androidtv.volume
@property
def source(self):
"""Return the current playback device."""
return self.androidtv.device
@property
def app_id(self):
"""ID of the current running app."""
return self.androidtv.app_id
@property
def app_name(self):
"""Name of the current running app."""
return self._app_name
@property
def available(self):
"""Return True if entity is available."""
return self._available
@property
def supported_features(self):
"""Flag media player features that are supported."""
return SUPPORT_ANDROIDTV
@property
def unique_id(self):
"""Return the device unique id."""
return self._unique_id
@property
def device_info(self):
"""Return the device info."""
return {
'connections': {
(dr.CONNECTION_NETWORK_MAC, self._properties['wifimac'])
'identifiers': {
(DOMAIN, self._unique_id)
'name': self._name,
'manufacturer': self._properties['manufacturer'],
'model': self._properties['model'],
'sw_version': self._properties['sw_version'],
@adb_decorator()
def turn_on(self):
"""Instruct the tv to turn on."""
self.androidtv.turn_on()
@adb_decorator()
def turn_off(self):
"""Instruct the tv to turn off."""
self.androidtv.turn_off()
@adb_decorator()
def media_play(self):
"""Send play command."""
self.androidtv.media_play()
@adb_decorator()
def media_pause(self):
"""Send pause command."""
self.androidtv.media_pause()
@adb_decorator()
def media_play_pause(self):
"""Send play/pause command."""
self.androidtv.media_play_pause()
@adb_decorator()
def media_stop(self):
"""Send stop command."""
self.androidtv.media_stop()
@adb_decorator()
def mute_volume(self, mute):
"""Mute the volume."""
self.androidtv.mute_volume()
self._muted = mute
@adb_decorator()
def volume_up(self):
"""Increment the volume level."""
self.androidtv.volume_up()
@adb_decorator()
def volume_down(self):
"""Decrement the volume level."""
self.androidtv.volume_down()
@adb_decorator()
def media_previous_track(self):
"""Send previous track command."""
self.androidtv.media_previous()
@adb_decorator()
def media_next_track(self):
"""Send next track command."""
self.androidtv.media_next()
@adb_decorator()
def input_key(self, key):
"""Input the key to the device."""
self.androidtv.input_key(key)
@adb_decorator()
def start_intent(self, uri):
"""Start an intent on the device."""
self.androidtv.start_intent(uri)
@adb_decorator()
def do_action(self, action):
"""Input the key corresponding to the action."""
self.androidtv.do_action(action)
did you add/change anything in code or just an example of media_player component
The code above is the code i have in my custom_components/androidtv/media_player.py file
The block:
DOMAIN, MediaPlayerDevice, PLATFORM_SCHEMA, SUPPORT_NEXT_TRACK,
sholud be:
And change
REQUIREMENTS = ['androidtv==0.0.5']
To
If you havent yet.
i have changed this,
this changed was made a week ago by JeffLIrion and Frand in Fank’s HassioAddon
Ok, works for me any way.
One thing i noticed today on one of my installs after upgrading to .88 was that i had to change back to custom_components/media_player/androidtv.py, restart hassio, and then the log stated that i had to change to custom_components/androidtv/media_player.py, and after that change and restart it worked again.
same thing happened to me yesterday,
Thanks to Kyle’s suggestion to reboot hass.io I can get my android tv to connect but now having some issues with the firetv. Anybody seeing this issue? I can power it off and on once but after that all commands stop working. The log is flooded with this message for the FireTV:
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 221, in async_update_ha_state
await self.async_device_update()
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File “/config/custom_components/androidtv/media_player.py”, line 268, in __adb_decorator
return func(self, *args, **kwargs)
File “/config/custom_components/androidtv/media_player.py”, line 329, in update
File “/config/deps/lib/python3.7/site-packages/androidtv/init.py”, line 419, in update
screen_on, awake, wake_lock_size, _current_app = self.get_properties(lazy=True)
File “/config/deps/lib/python3.7/site-packages/androidtv/init.py”, line 669, in get_properties
self.device = re.findall(DEVICE_REGEX_PATTERN, stream_block, re.DOTALL | re.MULTILINE)[0]
IndexError: list index out of range
So now my config has no errors but when I press one of my buttons I get:
Failed to call service media_player/androidtv_key.
any news ?
I have added the platform in this directory: custom_components/androidtv/media_player.py
This is my config:
host: 10.253.125.205
name: TV Woonkamer
apps:
netflix: "Netflix"
I have added the authorization keys in /root/.android
I use the docker image: homeassistant/home-assistant:0.89.0b1
The file I have used is from this repo: https://github.com/JeffLIrion/home-assistant/blob/androidtv/homeassistant/components/media_player/androidtv.py
I have a Philips TV with Android 9. The message I keep getting is:
2019-03-03 15:20:00 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform androidtv
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
return fut.result()
File "/config/custom_components/androidtv/media_player.py", line 180, in setup_platform
Suggestions?
I try to setup. I do “pip3 install androidtv” with homeassistant user (I use Hassbian in 0.88.1). I pasted the component file in “.homeassistant/custom_components/media_player/androidtv.py”. But when HASS restart I have this error message :
Error loading custom_components.media_player.androidtv. Make sure all dependencies are installed
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py”, line 147, in _load_file
module = importlib.import_module(path)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 958, in _find_and_load_unlocked
File “”, line 673, in _load_unlocked
File “”, line 673, in exec_module
File “”, line 222, in _call_with_frames_removed
File “/home/homeassistant/.homeassistant/custom_components/media_player/androidtv.py”, line 33, in
ImportError: cannot import name ‘SUPPORT_TURN_OFF’
Can you help me please ?
