It depends on your device, and some adjustments need to be done if your device has not been integrated yet.
What device are you using ?
Lot of sensors and controls are available in the Cozytouch API, at least everything you can have in the official app will be accessible in the integration, but much more sensors are published and not used by the app.
I have an NPE-240A2 and I just ordered a NaviLink Lite. I also have a logic analyzer as well as a capable digital storage oscilloscope. I think I am going to set things up initially using this integration, but for fun I also think I am going to have a go at examining the RS-485 traffic. I’ll let you know what I find out .
oh - can you say more about examining the RS-485 traffic? i have another device i want to do that on. i have a couple of USB to RS-485 connectors but haven’t used them yet, haven’t figured out where to start actually. that’s the next rabbit hole i’m going down
I am a little confused by the name of these items and what the on/off button is or isn’t?
what is the difference between inlet temp and hot water temp?
is the button my hot power button / circulation being on or a true power on/off button to the unit as a whole?
i didn’t see the note about dip switches until after i had installed the navilink lite and i would prefer not to re-open as our unit it is a little difficult to get too, so hoping can someone clarify if I have the full set of entities?
A few questions regarding this integration. Thanks to @nikshriv for your work on this.
I’ve installed the Navilink Lite and the integration and seem to have access to the entities exposed by the integration, including the hot button recirc switch.
My unit doesn’t have a remote temp sensor installed but does have the dedicated recirc circuit. Can this work without a remote temp sensor? If not, any pointers to a workable wireless solution?
If it can work without the remote temp sensor, are there any particular settings that I should look at on the water heater itself? Temp differential would see it has no effect if there is no temp sensor.
The recirc pump does not run more than a couple of minutes when the recirc is triggered. I’ve increated fixture distance to 400 feet but doesn’t seem to have any effect. Water at the fawcet is luke warm at best when running on cycle of every 30 min.
I have a NHB-150H boiler. The temp setting, inlet temp and outlet temp don’t work - I assume because for a boiler (not DHW) the topics in the AWS MQTT are different… Any idea what they could be? Or is the only way to sniff communications between the mobile app and cloud somehow?
I’ve been playing around with adding NWP500 support to the existing custom integration. If you’re interested and willing to test my code of questionable quality, I can add these for you as well.
NWP500 support required extensive changes because it doesn’t use the same MQTT topics or structure as anything else. (They implemented a completely new messaging scheme for it.)
I have NWP500 support reasonably stable now, in a fork of @nikshriv’s original NaviLink custom integration.
Here’s what’s changed:
Added NWP500 support.
Rewrote reconnection logic to be very robust.
Rewrote config flow; instead of picking which devices to poll, all devices on the account are polled by default, and you can disable a device in Home Assistant to stop polling it.
Rewrote temperature conversions.
I’ve been running this on my NWP500 unit for several months now and it has been stable.
Here’s what I haven’t tested:
Support for non-NWP500 models. (Although I tried to ensure that nothing was broken.)
Whether the upgrade flow works when upgrading from a previous version.
Multiple devices on one account.
NWP500 models that have a built-in recirculation pump / hot button support. (Mine doesn’t have it.)
Here’s a README that describes what’s supported for the NWP500: README_NWP500.md
