Unfortunately it doesn’t work dor me. Home Hassistant doesnt even start. I get the error below:
File “/usr/src/homeassistant/homeassistant/setup.py”, line 153, in _async_setup_component
hass, processed_config)
File “/usr/src/homeassistant/homeassistant/components/device_tracker/init.py”, line 115, in async_setup
legacy_platforms = await setup.async_extract_config(hass, config)
File “/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py”, line 100, in async_extract_config
for p_type, p_config in config_per_platform(config, DOMAIN)
concurrent.futures._base.CancelledError
File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main
"__main__", mod_spec)
File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 404, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 396, in main
exit_code = asyncio_run(setup_and_run_hass(config_dir, args))
File “/usr/local/lib/python3.7/asyncio/runners.py”, line 43, in run
return loop.run_until_complete(main)
File “uvloop/loop.pyx”, line 1451, in uvloop.loop.Loop.run_until_complete
File “/usr/src/homeassistant/homeassistant/main.py”, line 290, in setup_and_run_hass
log_no_color=args.log_no_color)
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 142, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip)
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 91, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 365, in _async_set_up_integrations
for domain in domains_to_load
File “/usr/src/homeassistant/homeassistant/setup.py”, line 50, in async_setup_component
return await task # type: ignore
File “/usr/src/homeassistant/homeassistant/setup.py”, line 126, in _async_setup_component
hass, config, integration)
File “/usr/src/homeassistant/homeassistant/config.py”, line 663, in async_process_component_config
component = integration.get_component()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 135, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File “/usr/local/lib/python3.7/importlib/init.py”, line 127, in import_module
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/config/custom_components/neato/init.py”, line 26, in
vol.Optional(CONF_VENDOR, default='neato'): CV.string
NameError: name ‘CV’ is not defined
