Many thanks for the work put in to get this up and running - initial tests are good, but will do some more comprehensive testing tomorrow as it is getting late here. Once again thankyou to yourself and dshokouhi
@dshokouhi and @JeffLIrion, I just want to thak you. It’s fully working!!! The only exception is battery level that is not being exposed. Never the less to be honnest the main goal was to have this witthout workarounds in home assistant.
Again thank you!
@grantc can you please confirm that you get your battery level exposed?
I think I know what the battery issue is I’ll try to submit a fix for that later today. Glad to hear it is working and thanks again to @JeffLIrion for all of his help!
ok I think I got the battery level to show up now, my branch was a bit out of date and I remember seeing a bug fix for vacuums that did not have mapping. This branch now includes the most recent HA changes as well.
Just wondering if anyone has been able to initiate a clean in “eco” mode on the VR200? It always uses, turbo/full power mode and drains the battery too quick. They only way I can see this being possible is via “neato_custom_cleaning” call and this does not work. Eco mode is an option in the Vorwerk app.
also if you do not have any maps, try setting category: 2 as well
edit:
One last thing
If you guys are able to interact with the parent library please post the state output here…this may be more helpful so we can see what service version your vacuums are using. You can run the state command whiles its idle and when its cleaning with the specifications you desire. This can help us understand what values to use.
We may need to fine tune things for Vorwerk if its not working like Neato.
These are the official Neato docs that we base everything off.
