ah ok learning always
i had another question i setup the local TTS so i installed the Piper and whymo and set up the local TTS under voice assistant
and i tried to find it in node read under domain tts but its not there do you know how to add it there or where it is… i though it was speak but i guess thats to talk into it… and i trying to figure that out too
i bought 2 Raspi espmuse boards so i wanna make a speak device but also i wanna do Text to speech using the local voice assistant but i cant find it in node red
[{"id":"91a50fe440a29a39","type":"api-call-service","z":"33e857f1856f9992","name":"Text-To-Speech To Devices","server":"efdc12b5.8e0cb","version":5,"debugenabled":false,"domain":"tts","service":"speak","areaId":[],"deviceId":[],"entityId":["media_player.raspiaudio_muse_proto","media_player.raspiaudio_muse_proto_2"],"data":"{ \"message\": msg.payload, \"entity_id\": \"tts.piper\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","output_location":"","output_location_type":"none","x":640,"y":1800,"wires":[[]]},{"id":"f7d8aa63268fdb10","type":"inject","z":"33e857f1856f9992","name":"Start","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"run","payload":"0","payloadType":"num","x":150,"y":1800,"wires":[["de2c15d81f1614e3"]]},{"id":"de2c15d81f1614e3","type":"ha-sensor","z":"33e857f1856f9992","name":"Caller Id Number","entityConfig":"ca004c017702ee1d","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":350,"y":1800,"wires":[["91a50fe440a29a39"]]},{"id":"efdc12b5.8e0cb","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"ca004c017702ee1d","type":"ha-entity-config","server":"915baa48.9b1898","deviceConfig":"","name":"Caller Id Number","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Caller Id Number"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"915baa48.9b1898","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
thats what i playing with at the moment i tried the tts.piper i found that in the developer states page
