Sorry no. hopefully it can be built in into the component
Anyone set up some notification when print paused? I’ve just added a filament sensor to mine and it would be great to get a push when it’s time to change!
Hey rpitera,
I am having a similar issue with my temperature readouts.
They currently read out in *F, and about twice the appropriate value. (!?)
Can you give a bit more detail where to place the value_template code?
I tried placing it in my customization yaml beneath the friendly_name entry for each sensor, but it had no effect.
I do not have a sensors.yaml, and I wasn’t able to add it in my congfiguration.yaml without breaking it. (Perhaps I have the syntax wrong?)
Hi
I’m in the process of linking my octopi to HA. Would you mins sharing your config to get the camera stream in HA?
I’m using the “Enclosure” plugin with Octopi, which allows you to control the Rpi GPIO’s from Octoprint. Any idea how to control these (lights, fans, etc) via HA?
I added this code to my sensors.yaml file and it did not change the result in the front end. Any suggestions?
How do you guys see the bed temps? I only get the hotend temps…
Using an Ender3 with latest Marlin firmware.
- platform: octoprint
monitored_conditions:
- Current State
- Temperatures
- Job Percentage
I have this and it works
number_of_tools: 1
bed: true
sensors:
- 'Current State'
- 'Job Percentage'
- 'Temperatures'
- 'Time Elapsed'
- 'Time Remaining'
As soon as I add: camera_view: live
my octoprint camera stops showing in lovelace…
- type: picture-glance
camera_image: camera.octoprint
camera_view: live
entities:
- switch.3d_print_light
But if I don’t use it, it just shows a still image that refreshes every 5 secs or so.
