Need help with Switch override for motion sensor for turning on lights
That is really just visual, nothing is set in the nodes. If you post what you have, I will fix it for you.
First select/highlight all the nodes of your flow. On the right, in node red, the hamburger menu. You will see export, select that option. When the dialog box opens select copy to clip board.
Read this post for how to post code on the forum, then post your code.
