Based on your behavior in that other thread you must watch a lot of those documentaries.
I think I’d cut down on them if I were you.
Sorry for the late replay.
I’m from the Netherlands so “luchtvochtigheid berekenen” is Dutch
But back on topic.
I now use the latest version of Home Assistant with Hassio as Docker-image on a synology.
The code calculate the average humidity of my bathroom sensor. I don’t have made it my self.
In Fact i can’t code at all.
I will change the time trigger.
One last question
alias: Luchtvochtigheid berekenen
It is the first line of my automation.yaml. Does it need a - before alias?
Without going into the details, yes, the first line of every automation definition should start with a dash. It doesn’t matter which parameter of the automation gets the dash, but it must be the first of the lines that define an individual automation. So it could be:
- alias: abc
or it could be:
- trigger:
alias: abc
Either is fine, as long as the first line of the individual automation definition starts with the dash.
Thank you will try this.
