trying to set this up, this might be the most crucial bit, it would need to follow the template.
checking Timer - Home Assistant though shows no option for a template… which leaves me in the same situation.
or would
timer:
radio_timer_delay
name: Radio timer delay
duration: {{states('input_number.radio_timer_delay')|int}}
do it? If I see this: Setting duration of timer with data_template not working
a timer with a fixed duration is created, and then started with a template in the duration section. Would these be added somehow, or does the template replace the fixed duration…? a bit confusing this is
like:
- alias: 'Increase volume loop'
id: 'Increase volume loop'
initial_state: 'off'
platform: event
event_type: timer.finished
event_data:
entity_id: timer.radio_timer_delay
# platform: time #(_pattern)
# minutes: '/1'
# seconds: 00
## seconds: >
## /{{states('input_number.radio_timer_delay')|int}}
condition:
- condition: template
value_template: >
{{is_state('input_boolean.snooze','on')}}
value_template: >
{{states('sensor.alarmclock_radio_volume')|float < 1 }}
- service: timer.start
data_template:
duration: >
- service: media_player.volume_set
entity_id: media_player.googlehome_master_bedroom
data_template:
volume_level: >
{% set level =
states('sensor.alarmclock_radio_volume')|float +
states('input_number.increase_volume')|float %}
{% if level < 1 %} {{ level }}
{% else %} 1
{% endif %}
- alias: 'Start radio delay timer'
id: 'Start radio delay timer'
platform: state
entity_id: input_number.radio_timer_delay
condition:
data_template:
duration: >
timer:
radio_timer_delay:
duration: 30
started by this script:
wakeup_radio:
alias: Wakeup radio
sequence:
- service: script.play_wakeup_radio
- service: automation.turn_on
entity_id:
- automation.increase_volume_loop
- automation.start_radio_delay_timer
new post for clarity: its working!
script:
radio_timer_delay:
alias: Radio timer delay
sequence:
data_template:
duration: >
automation
platform: event
event_data:
condition:
value_template: >
value_template: >
- service: script.radio_timer_delay
data_template:
volume_level: >
{% set level =
{% else %} 1
{% endif %}
timer:
radio_timer_delay:
duration: 30
all set to fire with this little script:
script:
wakeup_radio:
alias: Wakeup radio
sequence:
entity_id: automation.increase_volume_loop
made a kill_switch to rule them all:
- alias: 'Alarm clock off'
id: 'Alarm clock off'
initial_state: 'on'
platform: state
entity_id:
- input_boolean.snooze
- input_boolean.alarmclock_wd_enabled
- input_boolean.alarmclock_we_enabled
- input_boolean.lullaby_radio
- input_boolean.wakeup_radio
to: 'off'
condition:
condition: template
value_template: >
{{states('media_player.googlehome_master_bedroom') == 'playing'}}
- service: media_player.turn_off
- service: timer.cancel
- service: automation.turn_off
thanks @123 for inspiring me. Was able to cut your second bullet KISS, as possible.
skank
December 13, 2020, 2:50pm
23
I’m looking to do something similar.
Im not sure if i should use timer or not.
What i have so far.
2 input booleans, one for wekkermode and one for wekkeractief
these automations
- id: 'wekker_slaapkamer_detecteer_tijd'
alias: Wekker slaapkamer tijd
description: 'Detecteer wekker tijd'
platform: template
value_template: "{{ states('sensor.time') == states('sensor.wekker_tijd_slaapkamer') }}"
condition:
condition: state
entity_id: input_boolean.wekkermode_slaapkamer
state: 'on'
service: input_boolean.turn_on
entity_id: input_boolean.wekkeractief_slaapkamer
- id: 'wekker_slaapkamer_geactiveerd'
alias: 'Wekker slaapkamer geactiveerd'
platform: state
to: 'on'
entity_id: timer.wekker_slaapkamer
When the wekker(alarm) is active… i want to have a button “turn off” or “snooze”
When the alarm goes off i want my hub to play music and turn on nightlight.
I think i m gonna add this in a script and as condition have it my boolean alarm active
However the music should have the sound go up from 0 to for example 5 (google hub)
and stay at 5 until i press snooze or off
Pressing of isnt hard, but snooze is
Need some help here…
Especially to turn music up from 0 to 5 and keep 5
(in steps)
And how to snooze and then it redoes the same thing
Hope its clear
using this nowadays:
play_wakeup_radio:
alias: Play wakeup radio
mode: restart
sequence:
entity_id: >
{{states('sensor.wakeup_radio')}}
volume_level: >
{{states('input_number.wakeup_radio_volume')}}
- service: media_player.play_media
entity_id: >
media_content_id: >
{{states('sensor.radio_station_wake_up')}}
media_content_type: music
- delay: >
{{states('input_number.increase_volume_delay')|int}}
- alias: Increase volume AS LONG AS the conditions are true
repeat:
while:
- condition: state
entity_id:
- input_boolean.increase_volume
state: 'on'
{{states(states('sensor.wakeup_radio')) == 'playing'}}
{{states('sensor.wakeup_radio_volume')|float < 1}}
sequence:
entity_id: >
volume_level: >
{% set level =
states('sensor.wakeup_radio_volume')|float +
{% if level < 1 %} {{level|round(2)}}
{% else %} 1
{% endif %}
- delay: >
- delay: >
{% set delay = states('input_number.snooze_delay')|int * 60 %}
{% set spent = (now() - state_attr('script.play_wakeup_radio','last_triggered')).total_seconds() %}
{{ [0, delay-spent] | max }}
entity_id: >
please see if this does what yo want?
