Hi again,
i have been trying to read the data from a tasmota flashed rf bridge to no avail, i have read loads on here about it and still cant get it to work, have implemeted loads of differnent ideas, but just cant get it to work
initially i tried rules in tasmota , that never seemed to work or even run, and i tried loads of different aproaches.
now to me the value template seems like the best answer initially ( maybe python script when i can get it to actually work ) to extract the DATA part of my sensors,
i am getting mqqt messages from tasmota , but no matter how i try i just cant seem to get my hassio to create an entity or state i can use.
this is what i have:
so in tasmota first, this is the data from the movement sensor when activated
21:31:11 MQT: tele/RFBridge/RESULT = {“Time”:“2020-01-31T21:31:11”,“RfReceived”:{“Sync”:16590,“Low”:550,“High”:1610,“Data”:“CDC35C”,“RfKey”:“None”}}
i tried many times the rules to make it only send the data i needed which is the CDC35C
but my tasmota never seemed to like a rule
so now at home assistant mqqt under developers, when i subscribe to
Listening to
i get the same data as tasmota above but laid out a bit nicer.
in my configuration.yaml
i have this
- platform: mqtt
state_topic: “tele/RFBridge/RESULT”
value_template: >-
{% if value_json.RfReceived.Data == ‘CDC35C’ %}
{{‘ON’}}
{{states(‘binary_sensor.frontroom_motion’) | upper}}
off_delay: 15
device_class: motion
which i would expect to make me a sensor or something but it doesnt work , i ahve tried also many variations of this , and syntax .
can anyone help me , the data is coming over mqqt without a problem i just cant get the value template to read it correctly , i think lol
