I was able to get this working on hassio with extra steps:
- First, you need to access the bash shell of the homeassistant container. Protip: How to get shell in actual homeassistant (or addon) container when using Hassio
- Then run
apk add php8andapk add php8-curlto install php8 (with curl extension) into the homeassistant container. php8 comes with the json extension by default. - Download “nest.class.php”, “update_nest_target_humidity.php”, and “nest-api-php-workaround-login.php” (Manually create cache file required for nest-api to work with Nest accounts (not Google accounts). Ref: https://github.com/gboudreau/nest-api/issues/110 · GitHub) to your local machine.
- Create “/config/custom_scripts” folder on your hassio instance
- Edit “nest.class.php”. This fools nest to see your automation as a web browser client instead of a curl client. This also moves the temp cookie files to a persistent location “/config/custom_scripts”
- line 1474:
curl_setopt($ch, CURLOPT_USERAGENT, 'YOUR_USERAGENT_STRING'); - line 128:
$file = "/config/custom_scripts/nest_php_{$type}_{$suffix}"; - line 137:
$file = "/config/custom_scripts/nest_php_{$type}_{$unix_user}_{$suffix}";
- line 1474:
- Edit “update_nest_target_humidity.php”. Specifies your credentials and changes the library path to the same location as this file
- line 6: fill in your username
- line 7: fill in your password
- line 3:
require_once dirname(__FILE__) . '/nest.class.php';
- Edit “nest-api-php-workaround-login.php”. This puts in your credentials so that you don’t need to enter them everytime this script is executed. This updates the cache file location to /config/custom_scripts/ instead so that it’s persistent across home assistant reboots.
- line 11:
$username = 'YOUR_USERNAME_HERE'; - line 12:
$password = 'YOUR_PASSWORD_HERE'; - line 14:
$cache_file = '/config/custom_scripts/nest_php_cache_' . md5($username . $password);
- line 11:
- Upload the files to /config/custom_scripts
- Run
/usr/bin/php8 /config/custom_scripts/nest-api-php-workaround-login.phpfrom the bash shell prompt in the homeassistant container to generate the session cookie (will need to repeat this on a monthly cadence). Follow the steps from the script prompt - Run
/usr/bin/php8 /config/custom_scripts/update_nest_target_humidity.php -10 35to verify that it runs without an error - Update the shell command to use php8 and run from /config/custom_scripts/
update_nest_target_humidity: '/usr/bin/php8 /config/custom_scripts/update_nest_target_humidity.php {{states.sensor.dark_sky_temperature.state}} {{states.sensor.dark_sky_humidity.state}}'
