Manbearpig92Kyle Same here - I only have humidity and temp. Did you ever get anywhere with this? I resorted to this method https://community.home-assistant.io/t/exposing-google-home-away-mode-to-home-assistant/429528 - it is only for the entire house though… if you have multiple thermostats, they are all combined in the home/away so if you are wanting to have presence per thermostat, this method will not work unless you setup multiple “houses” for each thermostat not ideal but I guess it could work.
