Even after other reboots and with HA updated to the last current version, the cameras are still not working.
This is the situation in the logs:
Logger: libav.mpegts
Source: components/stream/worker.py:349
First occurred: 19:32:31 (938 occurrences)
Last logged: 19:49:27
Packet corrupt (stream = 0, dts = 6594887066)
Packet corrupt (stream = 0, dts = 6595067066)
Packet corrupt (stream = 0, dts = 6595247066)
Packet corrupt (stream = 0, dts = 6595427066)
Logger: libav.mp4
Source: components/stream/worker.py:225
First occurred: 19:36:41 (3 occurrences)
Last logged: 19:44:36
dimensions not set
Logger: libav.hls
Source: components/stream/worker.py:448
First occurred: 19:34:48 (13 occurrences)
Error when loading first segment 'https://prodvpn-eu-5.netatmo.net/restricted/...'
skipping 14 segments ahead, expired from playlists
keepalive request failed for 'https://prodvpn-eu-5.netatmo.net/restricted/...' with error: 'I/O error' when opening url, retrying with new connection
Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
Logger: libav.tls
First occurred: 19:34:48 (3 occurrences)
Last logged: 19:44:07
The specified session has been invalidated for some reason.
Logger: homeassistant.components.stream.stream.camera.netatmo_ingresso
Source: components/stream/__init__.py:340
Integration: Stream (documentation, issues)
First occurred: 19:34:07 (6 occurrences)
Last logged: 19:42:56
Error from stream worker: Error demuxing stream: [Errno 1414092869] Immediate exit requested: 'https://prodvpn-eu-5.netatmo.net/restricted/...'; last error log: [tls] The specified session has been invalidated for some reason.
Error from stream worker: Stream ended; no additional packets
Error from stream worker: Error opening stream (EXIT, Immediate exit requested) https://prodvpn-eu-5.netatmo.net/restricted/...
Logger: libav.hls
First occurred: 19:32:39 (9 occurrences)
Last logged: 19:42:48
skipping 25 segments ahead, expired from playlists
keepalive request failed for 'https://prodvpn-eu-5.netatmo.net/restricted/...' with error: 'I/O error' when opening url, retrying with new connection```
Logger: libav.tls
First occurred: 19:33:35 (3 occurrences)
Logger: libav.h264
First occurred: 19:35:17 (4 occurrences)
Last logged: 19:41:25
error while decoding MB 86 17, bytestream -5
error while decoding MB 96 54, bytestream -5
Invalid NAL unit 0, skipping.
error while decoding MB 83 36, bytestream -5
Logger: libav.extract_extradata
First occurred: 19:41:25 (1 occurrences)
Logger: libav.hls
Source: components/stream/worker.py:372
First occurred: 19:38:25 (2 occurrences)
Last logged: 19:38:25
skipping 18 segments ahead, expired from playlists
Logger: libav.tls
First occurred: 19:38:25 (1 occurrences)
Not sure if this could be of any help
