I’m seeing this in my log and none of my weather station values are working:
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 178, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 146, in async_setup_entry
async_add_entities(await hass.async_add_executor_job(get_entities), True)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 133, in get_entities
dc_data = data_class(auth)
File "/usr/local/lib/python3.7/site-packages/pyatmo/home_coach.py", line 15, in __init__
super(HomeCoachData, self).__init__(authData, urlReq=_GETHOMECOACHDATA_REQ)
File "/usr/local/lib/python3.7/site-packages/pyatmo/weather_station.py", line 24, in __init__
resp = self.authData.post_request(url=self.urlReq)
File "/usr/local/lib/python3.7/site-packages/pyatmo/auth.py", line 158, in post_request
f"{resp.status_code} - "
pyatmo.exceptions.ApiError: 403 - Forbidden - Application does not have the good scope rights (13) when accessing 'https://api.netatmo.com/api/gethomecoachsdata'
It was working fine until recently and I activated it under Configuration/Integrations I also have my client_id and secret in the configuration.yaml file.
Apparently the Netatmo API runs on Azure which might have some difficulties in the European data centres due to the high demand since the Corona outbreak.
I’m facing the same issue, that the integration suddenly stops working, if I reboot HA. I deleted the integration and tried to re-add but it doesn’t work as I get the same error with Nabu Casa.
I’m running 0.108.8.
I’m having the exact same problem as Henry. It’s not Azure related.
I’m using the weather station, setup via integrations page, have never had any config for it in config.yaml. It works for a few days then just stops working, i stop getting values.
I remove integration, re-add and have to do this many times, i get the " Oops… an error occured" from Nabu Casa. Eventually it will reauthenticate then work for a few days-
