Also some extra info for anyone trying to get Nx Witness camera streams into HA - here are some steps:
Create a ‘Digest’ user in Nx Witness with Live Viewer Access - instructions below are for version 5, but version 6 is similar:
https://support.networkoptix.com/hc/en-us/articles/7724435803415-How-to-Enable-Digest-Authentication-for-3rd-Party-Applications -
Add a ‘Generic Camera’ device in HA using the following format for URLs:
Still Image URL - https://{server ip}:7001/ec2/cameraThumbnail?cameraId={camera id}&time=now
Stream Source URL - rtsp://{server ip}:7001/{camera id}?stream=1
This is the low res stream - use stream=0 for high res -
Choose ‘digest’ for authentication and enter the user/password you created earlier.
Make sure you uncheck the ‘Verify SSL certificate’ option unless you’re using a custom cert for your Nx Server.
