I dont understant why docker not working. Try to figure it out. Try some google tutorial on how to run docker and debug the start afterwards it should work. btw you cant passthrough a GPU to a container
Have you tryed to go through troubleshooting on the end of my first post?
yes but no way.
docker-compose isnโt a recognize command.
and if i use another command, i have this error:
root@FRIGATE:~/dockfrigate# docker-compose up -d frigate
unknown shorthand flag: 'd' in -d
See 'docker --help'.
Usage: docker [OPTIONS] COMMAND
docker-compose is a Docker CLI plugin
Options:
--config string Location of client config files (default
"/root/.docker")
-c, --context string Name of the context to use to connect to the daemon
(overrides DOCKER_HOST env var and default context
set with "docker context use")
-D, --debug Enable debug mode
-H, --host list Daemon socket(s) to connect to
-l, --log-level string Set the logging level
("debug"|"info"|"warn"|"error"|"fatal") (default "info")
--tls Use TLS; implied by --tlsverify
--tlscacert string Trust certs signed only by this CA (default
"/root/.docker/ca.pem")
--tlscert string Path to TLS certificate file (default
"/root/.docker/cert.pem")
--tlskey string Path to TLS key file (default "/root/.docker/key.pem")
--tlsverify Use TLS and verify the remote
Management Commands:
completion generate the autocompletion script for the specified shell
compose Docker Compose
Run 'docker COMMAND --help' for more information on a command.
To get more help with docker, check out our guides at https://docs.docker.com/go/guides/
So i have tried also:
root@FRIGATE:~/dockfrigate# docker run docker-compose.yml
Unable to find image 'docker-compose.yml:latest' locally
docker: Error response from daemon: pull access denied for docker-compose.yml, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
Have you checked that the docker daemon is running? show me
journalctl -xe
Linux NUC-i3 5.11.22-1-pve #1 SMP PVE 5.11.22-2 (Fri, 02 Jul 2021 16:22:45 +0200) x86_64
Sep 10 09:46:32 FRIGATE systemd[1]: systemd-tmpfiles-clean.service: Consumed 9ms CPU time.
-- Subject: Resources consumed by unit runtime
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit systemd-tmpfiles-clean.service completed and consumed the indicated resources.
Sep 10 10:15:01 FRIGATE CRON[878]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 10 10:15:01 FRIGATE CRON[879]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 10 10:15:01 FRIGATE CRON[878]: pam_unix(cron:session): session closed for user root
Sep 10 11:15:01 FRIGATE CRON[882]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 10 11:15:01 FRIGATE CRON[883]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 10 11:15:01 FRIGATE CRON[882]: pam_unix(cron:session): session closed for user root
Sep 10 12:15:01 FRIGATE CRON[885]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 10 12:15:01 FRIGATE CRON[886]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 10 12:15:01 FRIGATE CRON[885]: pam_unix(cron:session): session closed for user root
Sep 10 13:15:01 FRIGATE CRON[889]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 10 13:15:01 FRIGATE CRON[890]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 10 13:15:01 FRIGATE CRON[889]: pam_unix(cron:session): session closed for user root
Sep 10 13:36:50 FRIGATE dockerd[349]: time="2021-09-10T13:36:50.865825158Z" level=error msg="Not continuing with pull after error: errors:\ndenied: requested access to the resource is denied\nunauthorized: authentication required\n"
Sep 10 13:36:50 FRIGATE dockerd[349]: time="2021-09-10T13:36:50.866773973Z" level=info msg="Ignoring extra error returned from registry: unauthorized: authentication required"
Sep 10 14:15:01 FRIGATE CRON[920]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 10 14:15:01 FRIGATE CRON[921]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 10 14:15:01 FRIGATE CRON[920]: pam_unix(cron:session): session closed for user root
Yeah thats mean something with permission. You need to follow some google guide to make it work and then go back to my tutorial
