Network UPS Tools add-on
It doesn’t appear that either repo is working colindunn/hassio-addons or hassio-addons/addon-nut (or just isn’t visible in the add on store).
Any thoughts on how to install?
I installed colindunn’s repo last week. Its working fine for me.
You need to add the repo before it will show it the store:
https://github.com/colindunn/hassio-addons
@hijinx, I have installed it in the past, but isn’t available and is erroring.
Am I missing something?
2019-04-10_09-36-47
Cannot install the NUT server on Hassio
@ASCIInaut any thoughts? I would really appriecate it.
The repo owner needs to update the config.json to add:
  "arch": [
    "aarch64",
    "amd64",
    "armv7",
    "i386"
This is mandatory for hassio addons now.
I had the same error. It was solved by powercycling the UPS.
https://github.com/colindunn/hassio-addons no longer exists
:frowning:
Sadly I dont have a fork of this repo. Maybe someone else forked it?
I do have the addon installed and running (x86 only)… is there any way to reverse engineer a repo?
Alternatively we can hope/pray/beg that the hassio community addon that is in beta will will progressed…
Maybe there is hope? :slight_smile:
I noticed that the nut repo has the original developers email address so I contacted them to see if I can get the addon code (dockerfile, config json etc). :crossed_fingers:
i have same problem add-on can’t find the USB cable attached to the RPi how i solve it ?
I have similar problem with my CyberPower UT850EG. The add-on can never find it after I connect the device or reboot the host, but when I try to restart the add-on after a day or two everything starts to work fine :man_shrugging:t3:
thank you i will try it
Me too, no current load e no current wattage. I see 14 sensors but not the 2 more important for me.
I used this configuration
users:
  • username: hassio
    password: *******
    instcmds:
    • all
      actions:
      devices:
  • name: apcsmart
    driver: usbhid-ups
    port: auto
    config:
    mode: netserver
    shutdown_host: ‘false’
APc smart ups id 18 SMT SMT18UPS_09-2 firmware UPS 09.2
