I am running apcupsd on a different machine from my Home Assistant OS. What I am trying to do is just monitor when apcupsd is on batter power and am havving some problems with the configuration. I set up the NUT add-on with the following;
The actual apcupsd doesn’t have a username or password but the add-on yells at me if I don’t enter anything.
Anyway, I restart the add-on and go to do the integration. When I do that and try to connect to localhost or even 127.0.0.1 it gives the error: Failure getting NUT ups alias, Socket error.
I’m really not sure what to do at this point? Can anyone help? Thank you
Not sure I’m following what you mean. I have the UPS connected to my server that is running apcupsd and it’s monitored through the tray icon (Windows Server). I also have other windows machines monitoring that instance to see if it’s running on AC or battery (reason I did that is to have them shutdown in the event that AC Power is lost).
The add-on starts fine but I still can’t get the integration to connect to the add-on.
Is there still some else I need to install on my server connected to the UPS? I don’t know what you mean by ‘NUT Server’. Thanks and sorry if this is something simple I’m just not comprehending.
Can you explain how to install nut-server locally?
The APC UPS connected via local USB is seen under Settings>System>Hardware and also under lsusb.
I have HASS OS standalone installed on a NUC/Dell Wyse thin client.
I have SSH access with the CONFIG labelled USB and authorized keys, but I dont know how to install nut, nut-client and nut-server because apt(-get) does not work.
Although I got the NUT server and integration to work on my HassIO/Rasp Pi setup, it dragged my Z-wave mesh to a crawl. Never did figure out why. I ended up running apcupsd server on a separate PI and using the addon to monitor it with Home Assistant. Has been working really well with my TrippLite UPS.
