I have the same problem as above.
The command ‘/bin/ash -o pipefail -c apk add --no-cache openssl’ returned a non-zero code: 8
Tried
apk Update
as described above. Get No Error in terminal.
Homeassistant running in Proxmox i5
Tried
apk Update
Thank you for your support
When I try to add the repository
I get this error message
Cmd(‘git’) failed due to: exit code(128) cmdline: git clone -v --recursive --depth=1 --shallow-submodules – hassio-addons/dss_monocle-gateway at master · sdesalve/hassio-addons · GitHub /data/addons/git/83279deb stderr: 'Cloning into ‘/data/addons/git/83279deb’… fatal: repository ‘hassio-addons/dss_monocle-gateway at master · sdesalve/hassio-addons · GitHub’ not found ’
Try to restart your host. Hassio cannot download from GitHub
You can try also beta version
I’m trying to install the add on, but it’s showing the error message
I have already run the commands below
apk update
apk add --no-cache wget curl libstdc++ nano net-tools openssl ca-certificates
I also tried the beta version, it displays the same message
Setup: NUC Ultratop INTEL
OS: Home Assistant OS 2024.6.2
Have you tried to install both version?
Beta and regular?
