Hi all, can you please let me know if there is anybody out there that managed to make this work recently? I am not able to see any device discovered and not able to connect to the port 8525 in any way as explained in some posts.
Here are the instructions that I found around for the step that I am stuck and not managed to make this working, mainly related to networking I guess, port 8525:
In the instructions here: https://github.com/rinne/broadlink-hub-hass-component
“In configuration menu of your Home Assistant, add Broadlink Hub integration. If your Broadlink Hub runs as a Hassio add on, the hostname should be local-broadlink-hub-hassio-addon and the port 8525.”
In the instructions here: https://github.com/rinne/broadlink-hub-hassio-addon
“If you expose the TCP port of the add-on outside Hassio, you can access it directly using a web browser and see your Broadlink devices.”
In one comment above is also written:
- Add external port to allow you to connect it directly with your web browser.
- Test it with your web browser. If it’s correctly configured, you should see your switches there.
Here are my current config:
As can be seen from the picture, there is nobody listening on port 8252 on the host neither.
As a note, under “Network” group, I could not enable 8252/tcp in any way. As can be seen it is marked under “Host” as “Disabled”*
I tried in that field to write “localhost”, “192.168.2.12”, “enable”, “enabled” but all with no success.
Enabled logging in the Broadlink Hub Add-on and here is the error:
Error: Unrecognized device type 0x279d
at Socket.message (/node-service/node_modules/broadlink-core/index.js:312:14)
at Socket.emit (events.js:315:20)
at UDP.onMessage [as onmessage] (dgram.js:919:8)
No clue what does it mean…
Any help here would be appreciated as I have a house full of Broadlink TC2’s and not able to integrate them in HA.
Thank you!
PS: Kiitos paljon Timo for working so hard to this, even that does not work for me,yet, but that will not cancel your huge effort that it seems that you put to make it this far.
